Welcome to the North American Subaru Impreza Owners Club Sunday July 12, 2020
Old 04-30-2011, 12:57 PM   #26
calgearhead
Member#: 133745
1998 Lifted Outback
Green + Dirt
If the 1st gen Legacy is just below the STi quickness wise and easier to install (and probably cheaper) why is no one using that minus jamal is wasn't thrilled for what it sounds like. Guess I'll be looking into replacing my 19:1 Outback rack with a regular Legacy though. Anyone know the difference between the two racks (Leg vs Outback)?
calgearhead is offline   Reply With Quote
Old 04-30-2011, 10:39 PM   #27
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
Originally Posted by Patrick Olsen View Post
That's per my '97 FSM. I don't know if the '95 would be different.
Missed that one, thanks. The stock steering wheel on the Lego is definitely smaller than the WRX then
LatentWagen is offline   Reply With Quote
Old 05-02-2011, 06:32 PM   #28
girodisc
Member#: 177674
I have an 05 rack but I have the crossmember. I had to cut the steering linkage in half and weld a hybrid using the STi rack side and the Legos steering side. I actually have to take it out and extend it now that my engine has spacers on the X member to drop it down to lower my COG. It feels much better then stock especially with the Whiteline bushings in there. Before autocrossing was spent flailing my arms wildly turning the wheel and now its much easier. I plan to go a step further someday and make a burly version of the quick steer brackets that Perrin did by moving the tie rod location closer to the hubs pivot point allowing for more movement of the wheels for less movement of the steering wheel.
Johann @ Girodisc
girodisc is offline   Reply With Quote
Old 05-09-2011, 08:27 PM   #29
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
I'm running an 04 STi rack with the Legacy column. As far as I can tell the STi rack should bolt into the Legacy x-member (I'm using an 04 STi x-member with the swap) and there is more than enough adjustment in the STi rod ends to account for the narrower track.
Making the correct adapter to go from the STi rack to the Legacy column is very easy, you just swap the rack end from the STi linkage onto your Legacy linkage.
You can find my full writeup here with photos showing how to swap over the linkage end.
Dan Cech is offline   Reply With Quote
Old 06-17-2020, 12:10 AM   #30
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Coming back to this topic again. I'm looking into getting a PSR quick rack. They make GC and GD versions, not a BD version. I think that the easiest option would be to do the GC rack, because I wouldn't have to worry about adapting the steering shaft. Can anyone confirm that is correct? (PSR is over in Poland, so there's a bit of a language barrier as we exchange messages on FB.)
USDM STi Steering rack in bg5 legacy? sti-zy wagon Subaru Conversions 0 02-14-2008 11:59 AM
Has anybody put an Infinity Perfect 12 in an STI spare tire enclosure? nhluhr Car Audio, Video & Security 7 11-08-2006 02:32 PM
Has anyone put a Truck-Subwoofer box in the Spare Tire Hole? syphon Car Audio, Video & Security 1 04-07-2005 08:35 AM
Has anyone tried RevLabs solid steering rack bushings? Rail Brakes, Steering & Suspension 5 10-26-2004 12:10 AM
Has anyone put USDM STi springs in a GC8? Thug Brakes, Steering & Suspension 1 05-04-2004 02:40 PM
