Welcome to the North American Subaru Impreza Owners Club Sunday July 12, 2020
Old 09-14-2017, 11:05 AM   #1201
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Originally Posted by N-Bomb View Post
Just to be clear, since my tuner/mechanic says otherwise - the VF-36 and VF-37 use the same flange, yes? As in one would be entirely drop-in for the other?
Your tuner is right and wrong...
The exhaust inlet and outlet flanges are the same however the VF36 uses a RHF5H form factor CHRA while the VF37 uses the RHF55. The two are not interchangeable. If you are converting a ball bearing VF turbo such as a VF34, VF22 etc you need to use a VF36 housing. For journal bearing turbos live VF48, VF52 etc you need to use VF37 housing.
Sometimes pictures help:
Right RHF5HB (VF36) Left RHF55 (VF37) You can see that the tail length of the VF37 is quite a bit longer than the VF36. If you put the turbine housings side by side you will see that while flanges are same length from exhaust flange to V-band face is longer for the VF36.
The Kinugawa housings for MHI based turbos are from VF36 turbine housings. You'll see "5HB" lettering cast on the inlet flange. The VF37 wil have "55" in the same place. The RHF5H and TD05/TD06 CHRA's happen to have the same (well almost the same) tail length and the same V-band size so you can machine a VF36 housing to fit an MHI turbo without much difficulty.
-soobaviator
soobaviator is offline   Reply With Quote
Old 09-14-2017, 11:21 AM   #1202
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
Default Stock loction Twin scroll turbo option thread
correct. twinscrolls share the same flange type.
Titter is offline   Reply With Quote
Old 09-15-2017, 12:46 PM   #1203
N-Bomb
Member#: 309465
1999 GC + ver 9 swap
Silverish
Thanks for the picture! However I'm still unclear - the turbos - the entire units, not just the housings or CHRAs, are not interchangable? Meaning if I took one entire turbo out, and wanted to put an entire of the other in, the UP/DP/oil lines/vacuum lines/etc wouldn't match?
N-Bomb is offline   Reply With Quote
Old 09-15-2017, 01:24 PM   #1204
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Right, you can swap an entire VF37 for a VF36. The components are not interchangeable however. That was the point for those looking to modify/convert other turbos.
-soobaviator
Old 09-16-2017, 05:53 AM   #1205
PrinceVegeta
Member#: 428946
2008 JDM WRX
The VF36 and VF37 uses the same flange, meaning to say, you can use the same uppipe for either turbos. This is my understanding and experience.
I swapped from a VF49 (Non Ball Bearing) to VF53 (BB) previously with no problems
PrinceVegeta is offline   Reply With Quote
Old 09-16-2017, 02:14 PM   #1206
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Yes, all the STI Spec C type RHF55 and RHF5HB TS are interchangeable as far as mounting.
The RHF5H turbos, VF38, VF44, VF45 are a different manifold, uppipe and downpipe from the STI. Those are from EJ20X/Y motors and won't fit the STI exhaust parts.
Old 09-19-2017, 02:21 AM   #1207
N-Bomb
Member#: 309465
Silverish
Okay cool. I was fairly sure that was the case. I just wanted to be sure before I hunt up a VF-36.
Thanks for confirmation
Old 05-23-2020, 07:43 AM   #1208
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Hi all
Bumping this thread to extol the virtues of the blouch 1.5xtr stock location twin scroll with respect to boost threshold.
Running this on my v8 ej207 with Grb sti tmic and all other supporting mods - 3 port bcs and full 3Ē catless tbe - e85
From a data log I pulled a couple of days ago, Iím achieving 20psi by 3000rpm, 23psj by 3250rpm and 24psi by 3500rpm
There is still some fine tuning to go on my carberry rom
This is all in 4th gear on a ppg built 5 speed (audm 99/00 wrx transmission with 3.54 final drive)
In third gear boost threshold is 200rpm higher.
Iím extemely and pleasantly surprised by the above results and canít speak highly enough of this turbo for the ej207.
Will post an update when I complete some more fine tuning.
Mick
*Edit - I should note the reason I believe the boost is limited to 20psi by 3000rpm and 23psi by 3250 is my target boost table which I was conservative with when setting up - I will update once Iíve completed the final target boost table with higher boost levels lower in the rpm
dr20t is offline   Reply With Quote
Old 05-24-2020, 07:13 PM   #1209
Mortal2None
Member#: 190077
2006 Subaru LGT BP
The 1.5xtr 10CM T/S will likely be my next turbo.
Mortal2None is offline   Reply With Quote
Old 05-26-2020, 04:14 PM   #1210
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
What is the longevity of those turbos like ?
I have seen some friends here in the states have reliability issues back in 2014-2016 with them.
Gigs90 is offline   Reply With Quote
Old 05-26-2020, 09:49 PM   #1211
Bansheeboy11
Member#: 182415
1999 RS
We ran one really hard for 2-3 years on my buddies car, made around 400whp and never had any issues.
Bansheeboy11 is offline   Reply With Quote
Old 05-26-2020, 11:04 PM   #1212
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Good to hear! Hope to eventually push mine to 28/29 psi once I install my headstuds and maybe cams
Mick
Old 05-27-2020, 09:15 AM   #1213
Bansheeboy11
Member#: 182415
1999 RS
Yeh his car was in the 26-28 range with e85 if i recall, really solid powerband too.
Old 06-05-2020, 12:18 PM   #1214
dud3tt3
Member#: 497730
Glad to see more information out here on twin-scrolls.
I'm pushing 451whp & 409tq @22psi on 93 out of the Blouch 1.5 XT-R T/S. Granted it required dual ewg's to get there. I'm seeing peak spool around 4300rpms. Then the S2 cams take over right after 5500rpms. I'm pleasantly happy with these results. Will eventually go E85 but just for cleaner aspect not for more power.
dud3tt3 is offline   Reply With Quote
Old 06-05-2020, 06:03 PM   #1215
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Those numbers are super impressive on 98 wow!
I really think the key here is the twin ewg. On the Blouch 1.5, the compressor wheel has enough potential flow for close to 500whp (71mm comp wheel is good for close to 500whp at the right PR and efficiency etc), limited by the clipped gt29 turbine wheel slightly AND more importantly, the mhi style housing.
Twin gates remove a hell of a lot of pre turbo EMAP / Backpressure, thus allowing greater AVCS optimization and therefore better VE
Iím a big fan of this style and should I get up going for more power once studs are done, Iíll definitely be going at least a single 48mm gate with divider (rhd car makes it extremely hard to fab twin gates on twin scroll header due to steering knuckle)
Mick
Old 06-05-2020, 08:54 PM   #1216
dud3tt3
Member#: 497730
I would highly recommend that you reconsider running dual. Especially with twin-scroll, from what I understand, running a single EWG will suffice, but you'll want to bleed off pressure from both tubes. Granted, I've read strong arguments on both sides. Some say its negligible others are adamant on dual ewgs for twinscrolls. I understand they are pricey, but I would seriously ask your tuner or an expert.
Old 06-05-2020, 08:56 PM   #1217
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Thanks mate. I am my tuner
Issue is not the cost - itís the physical space constraint for the dual gates. Will sus it out when i get to that stage
Point is though that the ewg definitely helps with ebp up top and will allow more timing / avcs overlap and therefore VE
Mick
Old 06-05-2020, 10:07 PM   #1218
dud3tt3
Member#: 497730
Mick
LOL well, then you know what you're doing and will have a better idea/understanding of what the car wants/needs. I also, read over rhd....****. you are very limited on space. here's how I did it...(although it likely will not help you any)
Old 06-05-2020, 10:08 PM   #1219
dud3tt3
Member#: 497730
can't seem to get the photo to work....but if you're curious, check out my Instagram @dud3tt3
Old 06-29-2020, 11:16 PM   #1220
suprabats
Member#: 357908
Hi all
Mick
What boost will it hold until 8000 rpm?
suprabats is offline   Reply With Quote
Old 06-30-2020, 06:05 AM   #1221
dr20t
Member#: 311246
2000 AUDM GC8 WRX
Royal Silver
Itís holding 24psi but torque drops off around 7500rpm. I do have some more timing headroom up top though which could be causing it. Just havenít been game to add more timing until I hit the dyno and measure torque differential.
Old 06-30-2020, 06:59 PM   #1222
ether947
Member#: 297799
2003 WRX
EJ207 version 8
Hi all
From a data log I pulled a couple of days ago, Iím achieving 20psi by 3000rpm, 23psj by 3250rpm and 24psi by 3500rpm ...
Would you happen to know what your boost curve is on 93? My VF37 has always felt a little lazy until 4k-ish.
ether947 is offline   Reply With Quote
Old 07-06-2020, 03:18 PM   #1223
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Poor Man's Panamera
Needs more EJ25X.
bicycle_wreck is offline   Reply With Quote
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
twin scroll turbo with dual ball bearing options pjhe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 12-14-2006 09:40 PM
DP options for twin scroll turbo? John2.5RS Subaru Conversions 7 08-24-2006 12:14 AM
Anyone running a stock evo twin scroll turbo on a wrx? mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-09-2006 11:29 PM
