Welcome to the North American Subaru Impreza Owners Club Tuesday January 31, 2023
Old 12-24-2014, 02:19 AM   #26
15wrx_ism
Member#: 409262
This is how it should be done! Not hooked up to brake lights or tail lights
15wrx_ism is offline   Reply With Quote
Old 12-24-2014, 02:27 AM   #27
eolivas
Member#: 397836
2015 WRX STi
Lightening Red
I totally agree, we need a DIY. I wish the OP would give us a hand.
eolivas is offline   Reply With Quote
Old 12-27-2014, 12:10 AM   #28
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
So if we go with a relay would the diagram be like this? (don't mind the x y z wire going to relay and so forth since i don't have a pin-out. Used it as a demonstration.)
Can we wire it to the same harness (i have a limited) like Zurcaled did using no relay? I was planning on switching out the OEM 21w 7440 with an LED bulb (they're about 5w), so not worried about blowing any fuses.
So like this???
Subie FA20 is offline   Reply With Quote
Old 01-02-2015, 07:08 PM   #29
Toastypinoy
Member#: 360301
2013 Impreza Sport
Satin White Pearl
Yea a step by step DIY would be helpful.
Toastypinoy is offline   Reply With Quote
Old 01-02-2015, 09:09 PM   #30
eolivas
Member#: 397836
2015 WRX STi
Lightening Red
I second that.
Old 01-02-2015, 10:19 PM   #31
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Ran an independent switch today and it works. I used a test light and no issues.
Used Switch: SPST 16A 125V Illuminated Round Rocker Switch with Red LED - Radioshack
Quick explanation:
Jdm harness has a power and ground.
Grounded to a bolt stud by tail light with a m6 x 1 nut. That's going to be my ground from the harness
Power from harness is going to the front of vehicle. Very easy and took 15 min to run. Take apart the trunk left side lining and run a long wire. Ran underneath the kick panel sills.
Ran the power to the front of the vehicle to fuse panel area. The switch is mounted in the dummy hole to the left of the trunk release.
That switch has 3 prongs: power (fuse), lead (to jdm fog), and ground.
Tapped with ez atm fuse tap into cig lighter 10amp. Used a 5amp fuse for the jdm fog.
Grounded to a metal bolt below steering wheel. It's a 10mm bolt and easy to see once you remove the plastic cover over the fuse panel
Obviously connected the lead to the final (middle) prong.
Used a test power/ground light in the trunk where the wires are and the second I hit the rocker switch, it lit up
Very easy and about hour labor wiring all including taking everything apart.
Hope this helps.
Old 01-03-2015, 05:02 AM   #32
MrLebreen
Member#: 344816
2012 Impreza 2.0i
Damn any chance there's an aftermarket front foglights install? Want to go from no fogs to fogs
MrLebreen is offline   Reply With Quote
Old 01-03-2015, 10:18 AM   #33
ronjr8102
Member#: 216040
2013 Impreza 2.0i5dr
dark metallic grey
There are a few routes you can take.
Diode Dynamics sells glass fogs with adapter plugs, or (what I did) can get just the adapter plugs and get 2010 Outback fogs from Rock Auto, relay and switch from an online Subaru site and just cut out the blank spot on the switch panel, the wires and plugs are already there.
Also found out that some 2010? Ford and 2008? Nissan fog lights are the same style.
Also will need 2 screws and clips from Subaru to hold the lights in.
I didn't get the light trim, just popped out the center cover off the big black plastic piece (it is already two pieces)
Sent from my SAMSUNG-SM-N910A using NASIOC mobile app
ronjr8102 is offline   Reply With Quote
Old 01-03-2015, 11:24 AM   #34
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Updated With Pics On Post #31
Old 01-04-2015, 10:46 AM   #35
fl1p
Member#: 407265
Originally Posted by ZURCALED12 View Post
Is there any chance you can explain how to remove the panel? I've got a '15 WRX and it's go the same panel.
fl1p is offline   Reply With Quote
Old 01-04-2015, 01:04 PM   #36
BoxerSport2.0
Member#: 308400
2016 WRB WRX
2012 Impreza Sport - Sold
Herr ya go this should help. How to Install 2012+ Subaru Impreza Factory OEM F…: http://youtu.be/m0-zZXS0k88
Sent from my HTC6500LVW using NASIOC mobile app
BoxerSport2.0 is offline   Reply With Quote
Old 01-04-2015, 01:06 PM   #37
BoxerSport2.0
Member#: 308400
2016 WRB WRX
This link will also be useful for you! Good luck! How to Install 2012+ Subaru Impreza Factory OEM F…: http://youtu.be/m0-zZXS0k88
Old 01-04-2015, 07:08 PM   #38
ronjr8102
Member#: 216040
dark metallic grey
Just push from the back after opening the fuse block door below it (I think, did it about 8 months ago )
Old 10-09-2015, 02:26 AM   #39
Dtaggart
Member#: 431581
Default Switch
Quick explanation:
Hope this helps.
Where did you get that switch and how did you get it to fit so well?
Dtaggart is offline   Reply With Quote
Old 04-18-2017, 06:11 PM   #40
ZURCALED12
Member#: 309754
2012 Impreza Sport L
Ice Silver Metallic
Originally Posted by eolivas View Post
Zurcaled,
Hello, I would like to know if it is possible to adapt your layout to a 2015 STi. I have the fog light assembly installed already. However, I don't want to use it as an additional brake light, I want to use it as intended... A rear fog. I tried to drop you an email but got an error. Do you have another email?
Any help you may provide me will be greatly appreciated.
Thanks in advance.
Damn! I just saw this, sorry for the real late reply. My new email is: [email protected]
ZURCALED12 is offline   Reply With Quote
Old 04-18-2017, 06:14 PM   #41
ZURCALED12
Member#: 309754
Ice Silver Metallic
Oh, my bad I see now. Good job nice and clean install.
Old 04-19-2017, 01:48 PM   #42
eolivas
Member#: 397836
2015 WRX STi
Lightening Red
No worries. I'll drop you a email today.
Old 09-24-2017, 05:02 PM   #43
clippedin
Member#: 474797
2016 Impreza Sport
Crystal White Pearl
... really appreciate this thread, just finished installing for our 5 dr! ordred the switch from 86speed, the switch wont fit the 2016 impreza panel so had to relocate and use the slot below
clippedin is offline   Reply With Quote
Old 11-06-2022, 11:23 AM   #44
lordnikon
Member#: 532029
2013 Impreza Sport
I want to do something like this, but that switch on the panel is for a front fog light not rear fog.
lordnikon is offline   Reply With Quote
