#1 |
Member#: 525135
![]() I bought my car two weeks ago, it had no issues because everything was rebuilt to stock on it. It starts up with one too two clicks. But it does have a intake down pipe and exhaust it has a check engine light because of the o2 sensor from the down pipe. No tune as of now. But three days ago I go to start my car. But it doesn’t start. I noticed my fuel pump isn’t priming. I was looking all threw the forms and did everything other people has said, I checked all my fuses none of them are blown. I checked to see if I was getting power too the fuel pump relay. And then I checked if I was getting power underneath the passenger side in the back that goes straight to the fuel pump with a 12v circuit tester. And I’m getting power. I have checked all my grounds and there all secure. The owner recently replaced it with an oem one. It randomly started working yesterday out of nowhere so I took it for a drive the parked it then it stopped working again. I’m am very confused on what is going on. The car has a brand new wiring harness and brand new ecu. This car was put back to stock before he sold it to me. I don’t know what could be the issue.
#2 |
Member#: 531990
![]() How to Make Sure Your Visual Content Drives Traffic
How to Create and Attribute Lead Source in Microsoft Dynamics https://bmmagazine.co.uk/business/ho...your-business/ |
#3 |
Member#: 531720
![]() If you checked your fuse and relay I would try looking at your fuel pressure regulator and maybe try changing the fuel filter. But it sounds like a burnt pump.
#4 | |
Member#: 532487
![]() Quote:
i have a similar problem where after i put gas in my 2007 Subaru WRX the car cranks but won’t start. so i turn it off than on, and crank it again and she sputters than eventually after i turn the key on, and crank it enough (3-4 times) it’ll start. but she misfires for a few minutes till i rev it or start driving and the misfire goes away. would that be also fuel pump not priming ? Sent from my iPhone using Tapatalk |
#5 | ||
Member#: 532487
![]() Quote:
i have a similar problem where after i put gas in my 2007 Subaru WRX the car cranks but won’t start. so i turn it off than on, and crank it again and she sputters than eventually after i turn the key on, and crank it enough (3-4 times) it’ll start. but she misfires for a few minutes till i rev it or start driving and the misfire goes away. would that be also fuel pump not priming ? the entire fuel system is aftermarket (braided lines, perrin rails, id1050x injectors, and aem high flow pump) Sent from my iPhone using Tapatalk |
#6 |
Member#: 379520
Vehicle:2005 Wrx WRB |
![]() I recently had a similar problem. I do have an aftermarket pump and it’s hardwired so different from stock setup. But my wiring near the pump was bad. I would pull out the pump and check the connections from the actual pump make sure those are fine. I could wiggle mine and it would work and stop working as well. Check the wires right under the fuel pump cover as well. I guess I should mention my car is an 05 WRX I’m not sure what year your car is.
