Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 11-18-2001, 08:53 PM   #1
LttLDGN
Member#: 5478
Question Anybody Install Pulleys on WRX?
wondering if anybody did the install for the pulleys yet...
was going to hold a pipe and crank the engine... but there seems to be clearance problems...
so.. any tips/suggestions would be appreciated... thanks
jerome
LttLDGN is offline   Reply With Quote
Old 11-18-2001, 09:42 PM   #2
SuicidalLabRat
Member#: 4096
noun [ ve·hi·cle ]
a carrier,as of infection
5th gear;
E-brake;
brakerbar with a 3-4 foot cheater ( just a simple pipe or some such ) on the end of it.
SLR-
SuicidalLabRat is offline   Reply With Quote
Old 11-19-2001, 03:42 AM   #3
LttLDGN
Member#: 5478
thanks alot guys... did you get to it from above or from under..with a lift??
Old 11-19-2001, 08:58 AM   #4
jimb
Member#: 9923
2005 Legacy GT
RIP MBP WRX
I'm procrastinating putting my 2 pulley set on. Still kind of paranoid about the whole harmonic damper argument. Little side question here, if the engine is so supposed to be so well balanced, why does it shake at idle? Anyhow, I'll probably throw the pulleys on in conjunction with a couple other mods, just so I'm sure I feel some kind of improvement and I don't feel so bad about blowing so much cash.
-jb
jimb is offline   Reply With Quote
Old 11-19-2001, 10:44 AM   #5
sorny
Member#: 10116
2002 WRX Sedan
I'm pretty sure that I read in Subaru's little magazine they put out that the EJ20 Turbo doesn't have a balancer. I assumed that's one of the reasons it idles so rough (besides the rough cam grinds).
sorny is offline   Reply With Quote
Old 11-19-2001, 11:21 AM   #6
jmott
Member#: 6713
2007 Prius
brown
it shakes at idle cuz its an engine
and only 4 cylinders
-jb
jmott is offline   Reply With Quote
Old 11-19-2001, 12:56 PM   #7
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
No, it's not just that. I've had many straight 4's (mostly Honda) and ALL of which idled MUCH smoother than the WRX. I couldn't even tell the car was on.
the idle on a loaner WRX I had (DEMO) was rough as hell (it was beating to death to), whereas my WRX (broken in properly) is a lot smoother (still rougher than a GSR motor for example). I just think it's because it's firing left to right.
-C
TypeC is offline   Reply With Quote
Old 11-19-2001, 01:32 PM   #8
Obscure411
Member#: 5719
2008 Impreza 5-Door
That is a typical characteristic of a flat-4 engine. The engine will move side to side and will transmit some of this vibration to the chassis.
Either way, it's a small price to pay for a well-balanced engine.
Obscure411 is offline   Reply With Quote
Anybody install springs on a 2004? Jeff_DML Brakes, Steering & Suspension 1 11-24-2003 09:33 PM
UR Underdrive pulley on WRX MikeWRX Car Part Reviews 9 11-04-2001 10:52 AM
RESULTS! UR Pulley on WRX McKenzie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 06-12-2001 03:11 PM
Sunroof-has anyone installed one on WRX Speedy General Forum Archive 13 04-04-2001 01:51 AM
