Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2018
Old 02-05-2011, 03:29 PM   #76
Maxwell Power
Member#: 190729
Originally Posted by Wagun View Post
Could you post a pic of one installled?
sure thing
it's like where's waldo...
Maxwell Power is offline   Reply With Quote
Old 02-06-2011, 01:41 PM   #77
Wagun
Member#: 106433
2004 WRX wagon
Originally Posted by Maxwell Power View Post
sure thing
Thanks! ...obviously this is N/A for a TMIC, correct?
Wagun is offline   Reply With Quote
Old 02-06-2011, 01:59 PM   #78
Maxwell Power
Member#: 190729
No. depending on the type of intercooler we do it differently. It can also go in the intake manifold.
Old 02-07-2011, 10:19 PM   #79
Wagun
Member#: 106433
2004 WRX wagon
Where on the intake? Got a pic of that?
Old 02-07-2011, 10:31 PM   #80
Maxwell Power
Member#: 190729
Got a pic of that?
no I don't. Sorry.
You put it wherever it fits based on the setup. there is room down by the PCV inlet under the throttle body in some configurations.
Old 02-08-2011, 09:19 PM   #81
Maxwell Power
Member#: 190729
Originally Posted by sleeperrex View Post
Mine was confirmed blown rings a couple of days ago (70% leakdown on cylinder 4). Kind of known for the last few months after i did a compression test and Cylinder 4 was 60psi. Haven't been driving it around.
35000 miles, STI head gasket, alchy with FPGreen. No headwork other than the regular 3angle valve job. no upgraded cams. At 380awhp.
Thing that sucks is i just had Dom at Maxwell power put in some Ablins gears. Can't say i've really got to enjoy the gears yet.
Paul?
Do you have a plan of attack? We could help you out with the next one man!
Old 02-08-2011, 09:22 PM   #82
Maxwell Power
Member#: 190729
on the EJ207 there is a spot for the sensor just below the throttle body next to the PCV valve bung.
Old 04-16-2011, 02:30 AM   #83
fazeracing
Member#: 142564
PM DScamp 4
Cleveland Steamers
Id like to see how everyones hybrid are doing,
I have 60 miles on mine and I blew a turbo seal
here are the mods will update as the miles go on...
-05 ej257 hybrid with combustion chambers matched
-Manley H-Beam rods
-CP 99.5 Pistons
-ACL Race rod and main bearings
-BC 272 Camshafts
-BC Springs and Ti Retainers
fazeracing is offline   Reply With Quote
Old 04-19-2011, 12:53 PM   #84
mulva
Member#: 62539
2002 WRX Wagon
2009 Impreza OBS
Mileage since installed: 10,000 miles
Type Engine and Internals: EJ25, Manley 100mm 8.5:1 pistons, Manley I-Beam rods, ACL Race bearings, ARP head studs. VF43 and supporting mods.
Valve-train: stock 2002 WRX heads and cams. The heads were completely rebuilt, with new valve seals, valves and seats were refaced, and the heads were shaved and shimmed.
Head Gasket Choice: OEM
Current Status: 270whp/305wtq. Not daily driven. Never burns oil during autocross or track days. No engine issues since going hybrid.
mulva is offline   Reply With Quote
Old 04-19-2011, 02:05 PM   #85
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
I find that it would be usefull to have a thread dedicated to users of hybrid motors, instead of having to have multiple threads bookmarked to find the information you want (with the exception to stikys) Also any other things that did occur in the future, like tuning issues or oil consumption (I know there are a few threads on consumption).
Mileage since installed: +40,000 /4 years
Type Engine and Internals: JE Pistons 8.5:1 Compression, Eagle H beam Rods, Stock head bolts, ACL Race Bearings
Valve-train: Crower 272/272 cams, Ferrea Valvesprings and retainers, Ferrea Valves, ported 2.0 heads. (No port matching)
Head Gasket Choice: Cometic .027 head gaskets.
Current Status: Has made over 500whp on race gas for the past couple years, currently on a 600whp tune up. Have had no problems what-so-ever with tuning. It takes timing just fine, and with good gas it lives great. Going to continue to push it until something finally fails.
Follow this format so it is clear to read.
*Please forgive me if there is already a thread covering this.
RealStreet is offline   Reply With Quote
Old 05-05-2011, 05:49 PM   #86
DegNY
Member#: 226576
2002 Civic/97impreza
Midnight Blue/Green
I am ISO some updates on the people who posted here, as I am looking into a hybrid build. Anyone have some updates?
DegNY is offline   Reply With Quote
Old 05-10-2011, 11:08 PM   #87
DegNY
Member#: 226576
Midnight Blue/Green
So no updates or new builds?
Old 05-13-2011, 11:27 AM   #88
naTe02
Member#: 76257
2002 Subaru WRX
This is for a 2002 WRX:
Mileage since installed: 55,000
Type Engine and Internals: EJ257 w/ Stock Internals
Valve-train: Stock 2.0L heads, STi Cams
Head Gasket Choice: Stock STi
Tune: Tuned by Engine Logic's in Houston - 226Hp/258tq
I had the engine built at a friend's garage, then tuned at Engine Logic's.
The engine has been reliable, no problems so far.
naTe02 is offline   Reply With Quote
Old 05-13-2011, 10:10 PM   #89
ledzeppelin240
Member#: 227951
2004 Impreza WRX
^Is that on the tdo4?
ledzeppelin240 is offline   Reply With Quote
Old 05-16-2011, 01:32 PM   #90
naTe02
Member#: 76257
2002 Subaru WRX
Yes it is.
Old 06-20-2011, 01:46 AM   #91
Halls
Member#: 241214
2002 wrx
wrb
-Manley H-Beam rods
-CP 99.5 Pistons
-BC 272 Camshafts
-TGV Deletes
-Vishnu Fuel Rails
-XS Engineering Fuel Regulator
-Gates Racing timing belt
-Tomei timing belt guide
-blouch 20g 7cm with 2.4"
-samco turbo inlet
-aps cai 65mm
- Ngk bkr7elx .028
-walbro 255
- harmin motive ewg up
- tial 44mm ewg 1 bar spring
- Borla Xr1 Catless
- Grimmspeed Ebc
- DW 750cc
Did you torque the bolts IAW the Subaru specifications, none of this Goodentight shyte. Those torques are there for reasons.
Sticky bump.
Halls is offline   Reply With Quote
Old 08-09-2011, 07:48 PM   #92
03Sonicywrx
Member#: 236057
2003 6262 sonic bug
2013 wrb hatch
Mileage since installed: 4,000
Type Engine and Internals: EJ257 w/ Manley pistons
Valve-train: Stock 03 heads
Tune: Tuned by Ryan @ Area 1320
I'm running a Vf30 as of now and it pulls like a bat out of hell. I'm very much satisfied with my choice of a hybrid build rather then a fully built 2.0. The torque is there when wanted and plenty of it
It hasn't went through a drip of oil since the install, no CEL or any such issue. Still lower mileage but i can't see any flaws to happen in the future!!! Any issues in the process of stacking on mileage I'll be sure to post, but like i said so far it feels bulletproof.
Eventually I'll be installing a Dom 2.5 xt-r on a relatively "soft" tune to achieve an even funner subaru! Also at this time I'll be dropping some BC 272s in.
03Sonicywrx is offline   Reply With Quote
Old 08-17-2011, 12:35 AM   #93
03wrxyllw
Member#: 277176
so im about to start building my hybrid swap and i have a guy who wants to trade me his 100mm wiseco pistons w/ rings, eagle h beam rods, for my good stock 2.0 block but seeing as hybrid swap is already goin to be high comp i wanted to kno if his 9.6:1 piston will still be safe to run with this setup hopefully some one can give me some input if so all help is greatly appreciated
I also wanted to kno if any one else would do this trade thank you
03wrxyllw is offline   Reply With Quote
Old 08-17-2011, 01:32 AM   #94
MainFrame
Member#: 218739
2002 WRX hybrid
9.6:1 would be great if you're going to be running e85, otherwise it might be a little high. You won't be able to run as much boost before it starts knocking on 93. It can be safe, that's all in the tune, but you might not be able to make as much power on pump gas.
MainFrame is offline   Reply With Quote
Old 08-17-2011, 03:41 AM   #95
03wrxyllw
Member#: 277176
ok thanks that works because i am thinking about putting a fuel cell in the trunk for a high boost tune just trying to figure out how to do all the plumbing and chit thanks for your help
Old 08-17-2011, 11:35 AM   #96
jetski247
Member#: 188171
04 sti baby
wrb
i had almost 100k on my stock sti pistons with zero cracked ringlands when i took my engine apart due to other problems. i was putting down 268 whp on a dyno dynamics tuned at hpt since they are the closest all wheel dyno, ran that tune for years with zero issues what so ever.
i even ran two full bad tanks of gas through it and could hear it deto but stayed out of boost.
i thought deto was the main cause of ringland failures which would mean bad gas or a bad tune.
jetski247 is offline   Reply With Quote
Old 02-05-2012, 04:46 PM   #97
sleeperrex
Member#: 19466
2002 wrx/hybrid
Paul?
Hey!
Yeah, its me. Been a long time as my hybrid has been out of commission for a little over a year. Started browsing the forums a little more using my lessons learned in the past. Seeing if there has been any new revelations. Looks like there has with the combustion chamber thingy.
Starting to browse around for a plan of attack.
Little side note, the tranny had somewhat fresh gear oil when i stopped driving it. Anything i should do maintenance wise. Hasnt been started in over a year.
sleeperrex is offline   Reply With Quote
Old 02-09-2012, 10:22 PM   #98
BluScubi
Member#: 162726
2009 LGT
QSM
2002 WRX current mileage 110,00
33,000 miles over 3.5 years
Stock STI short block
Stock 2.0L heads, cleaned and valve job prior to install
OEM STI head gaskets
Status: Running Strong. Jorge tuned 264 WHP, 294 WTQ at 17.5 psi on a VF43 with supporting mods
I'm looking to add a couple parts and get a retune in the near future. The IAT relocation mod, is it only beneficial if you're running a front mount?
BluScubi is offline   Reply With Quote
Old 02-10-2012, 12:10 AM   #99
Millhouse118
Member#: 236886
Ok so im thinking of taking this "hybrid route". From what i have learned, stock STi bottom end with ported 2.0 heads, ARP head bolts, stock STi gaskets, bigger turbo and you should be safe? Im new to the F/I side of Subaru so im learning all this any help is appreciated!
Millhouse118 is offline   Reply With Quote
Old 02-10-2012, 12:28 AM   #100
RexWagonWA
Member#: 221945
Default Hybrid users
Find a good local tuner.
I would recommend CNC headwork to match the EJ257 short block. Rebuild the heads for longer life.
Look into larger turbos recommended by your tuner. Larger fuel pump, injectors, and intercooler are another good step.
E85 shows some great results if it is available locally.
GLWYB
RexWagonWA is offline   Reply With Quote
OFFICIAL: LG-VX9100 users, post here! psychoskip Off-Topic 3 06-17-2010 12:46 PM
Samsung Instinct users post here sube-trex Off-Topic 8 06-17-2010 08:45 AM
VF34 Users Post here! Assassin4457 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 91 09-28-2006 12:44 AM
Any long term users of Torco RTF? edmundu Transmission (AT/MT) & Driveline 8 08-15-2005 01:53 AM
Long term users of FMIC's Wombat North Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-10-2003 06:49 PM
