Welcome to the North American Subaru Impreza Owners Club Tuesday November 13, 2018
Old 12-21-2008, 09:56 PM   #1
jester696
Member#: 135952
04 XTi
Default Changing spark plugs...need to change all 4?
My CEL came on and it was a misfire from cylinder 4. I want to change the spark plug to see if that is all I need to do. Can I buy just 1 spark plug that is a different brand than the others without it affecting anything? There are NGK's in my car right now.
Thanks,
J
jester696 is offline   Reply With Quote
Old 12-21-2008, 10:21 PM   #2
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
Just replace all of them, spark plugs are cheap.
boost junkie is offline   Reply With Quote
Old 12-21-2008, 10:45 PM   #3
rico_q808
Member#: 155896
Chapter/Region: HIIC
2006 WrX
bLuE
what he said..
rico_q808 is offline   Reply With Quote
Old 12-21-2008, 11:02 PM   #4
beanbeanbean
Member#: 132935
02 rwx
round
could be the coil
beanbeanbean is offline   Reply With Quote
Old 12-22-2008, 12:02 AM   #5
STIBungy
Member#: 51684
I would suggest reseating the connectors to the coilpacks first, then swap coilpacks and then spark plugs, if the previous steps dont help you track down the issue.
STIBungy is offline   Reply With Quote
Old 12-22-2008, 12:10 AM   #6
tekfoc
Member#: 21392
2016 C63S AMG MB
Iridium /MB C300 4MATIC
while your at it do a compression test.
tekfoc is offline   Reply With Quote
Old 12-22-2008, 09:10 PM   #7
Spitfire8o5
Member#: 188654
99 2.5RS Coupe
TimeAttack DC #117
Compression checks do wonders and let you know what other cylinders are going down hill.. And don't just change one if anything uneven fireing can lead to worse things hahaha
Spitfire8o5 is offline   Reply With Quote
Do I need to replace all 4 tires? (Sort of urgent I guess) formula91 Tire & Wheel 9 12-17-2007 06:11 AM
Need to get all 4 wheels in the air for diff/tranny fluid changes? cMags Service & Maintenance 17 10-11-2007 06:35 PM
Need to replace all 4?? mars636 Tire & Wheel 3 09-08-2006 11:33 PM
in the process of priming turbo. do i need to unplug all 4 coil pack? VajraTLR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-30-2005 10:05 PM
1 blown tire, do I need to replace all 4? Capt Crunch Tire & Wheel 17 06-06-2004 06:23 PM
