Welcome to the North American Subaru Impreza Owners Club Thursday February 22, 2018
Old 12-29-2005, 08:11 PM   #1
VajraTLR
Member#: 13156
2004 WRX
JBP
Default in the process of priming turbo. do i need to unplug all 4 coil pack?
i was wondering if i could just unplug 1 coil wire and crank the engine without starting the engine, or do i have to unplug all 4 coil wires?
VajraTLR is offline   Reply With Quote
Old 12-29-2005, 08:52 PM   #2
sheikthin
Member#: 77592
* missdawn = MILF
now with 25% less pistons
see your OTHER post for the answer
sheikthin is offline   Reply With Quote
Old 12-30-2005, 02:04 AM   #3
ChgoJay
Member#: 71722
Disconnect the fuel pump.
ChgoJay is offline   Reply With Quote
Old 12-30-2005, 03:09 AM   #4
ninjaboy76
Member#: 33456
2015 WRX
WRBP
disconnect Ing. fuse. I believe it is number 11 in the fuse box under the dash.
ninjaboy76 is offline   Reply With Quote
Old 12-30-2005, 03:38 AM   #5
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
ditto
santofontana is offline   Reply With Quote
Old 12-30-2005, 03:16 PM   #6
Dragon Wagon
Member#: 101095
1997 leggy gt
Reo Red
no
Dragon Wagon is offline   Reply With Quote
Old 12-30-2005, 04:54 PM   #7
WShade
Member#: 74339
Thats what I did.
WShade is offline   Reply With Quote
Old 12-30-2005, 08:00 PM   #8
gsteclipse33
Member#: 72859
i was informed by a reliable source that u really dont nedd to prime the turbo
gsteclipse33 is offline   Reply With Quote
Old 12-30-2005, 08:00 PM   #9
gsteclipse33
Member#: 72859
i didnt and have 15 k on it with no problems
Old 12-30-2005, 10:05 PM   #10
sheikthin
Member#: 77592
* missdawn = MILF
unless your installation instructions tell you to....just for warranty issues....search for experiences...
03 WRX All 4 Coil Packs, Intake Manifold, Crank Sensor, Knock Sensor 45k Miles on All mrtrex Engine/Power/Exhaust 46 05-02-2010 11:12 AM
Do I need to replace all 4 tires? (Sort of urgent I guess) formula91 Tire & Wheel 9 12-17-2007 06:11 AM
In the process of removing all exhaust shielding... breakfasteatre Legacy Forum 15 09-10-2007 01:10 PM
in the process of building a VF30 setup. when all is said and done which BOV? 280hp_REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-15-2006 11:05 PM
1 blown tire, do I need to replace all 4? Capt Crunch Tire & Wheel 17 06-06-2004 06:23 PM
