Welcome to the North American Subaru Impreza Owners Club Friday September 21, 2018
Old 02-01-2009, 05:59 PM   #1
TurboWRX32
Member#: 107557
2006 WRX
Steel Gray
Default Bosch 1000cc Injector's?
My buddy was mentioning these to me cause he is putting them in his VW golf. Does anyone know if we can run these in our cars at all? I have a 2006 WRX. I need to buy injectors anyway and can get a killer deal on these. Any input would be very helpful. Thanks
TurboWRX32 is offline   Reply With Quote
Old 02-01-2009, 08:18 PM   #2
STIBungy
Member#: 51684
You just need to make sure that they are high impedance injectors and you have the plugs for it. You may have to make some modifications to the rails or get different o-rings to get them to fit.
What's a killer deal? I have a set of modded and flow tested top feeds that flow about 980cc.
STIBungy is offline   Reply With Quote
Old 02-01-2009, 08:22 PM   #3
MasterKwan
Member#: 98961
2003 WRX
You have to actually tune for them and make sure they physically fit the rails and TGV housings too.
Old 02-01-2009, 10:39 PM   #4
TurboWRX32
Member#: 107557
2006 WRX
Steel Gray
PM sent about those injectors.
I am getting retuned for my custom rotated mount borg warner. So I need injectors anyway. I was curious if anyone else has tried these out at all. They are high impedence not 100% sure on the o-rings and everything. I know most subaru owners just go with Deatsch Werks but they are a bit high for the deal that I am getting on these other ones if they will fit.
Old 02-01-2009, 10:40 PM   #5
STIBungy
Member#: 51684
What BW turbo do you have? I'm interested in your dyno numbers when you get tuned.
Old 02-02-2009, 01:33 PM   #6
TurboWRX32
Member#: 107557
2006 WRX
Steel Gray
I am running the S256. Right now at 14lbs its putting down 315 thats with the stock fuel system and clutch.
Old 03-07-2009, 10:12 PM   #7
Tony1
Member#: 204092
2001 8 second Integr
Red
Just an update, we have these now in drop in applications for the top fee WRX application. www.InjectorDynamics.com
Tony1 is offline   Reply With Quote
Old 03-08-2009, 01:46 AM   #8
JSarv
Member#: 163445
l33t *******
[email protected]
I'm running them in my 02 right now - Thanks to Tony - Running them with E85
Bosch 1000's >>>>>>>>>>>>>>>>>> Matched Pro-modded stockers x100000000000E9999
Anyway you get the point.
I do believe Tony will have a plug and play setup this week... Idle is so F'n great with these things its not even funny..
Anyway I'm done talking them up - but in comparison I've used quite a few injectors - mainly Honda stuff - and these have the best consistency and best feedback/performance I've seen hands down...
-Jerod
JSarv is offline   Reply With Quote
Bosch 1000cc Injectors - Drop in? JSarv Built Motor Discussion 932 05-18-2011 11:28 PM
FS : Grimmspeed Intake Manifold w/ extras, ID 1000cc bigboy Engine/Power/Exhaust 17 07-17-2010 02:39 PM
FS: Injector Dynamics 1000cc Fuel Injectors Bosch dcheyne55 Engine/Power/Exhaust 17 02-22-2010 05:15 PM
Id Bosch 1000cc injectors TDagen Engine/Power/Exhaust 9 02-01-2010 04:32 PM
does my Supra fuel pump raise my stock injector's cc flow? annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-15-2002 08:09 AM
