Welcome to the North American Subaru Impreza Owners Club Sunday October 25, 2020
Old 10-12-2020, 08:10 PM   #1
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Default Wrx p0519 iacv
Hey all, my 05 Wrx (ej205) threw a cel p0519 and could use some suggestions.
Everything was fine friday, then i started it saturday and instantly idled funny and high. I let the car warm up then took it for a test drive. Below about 5mph, in first or reverse, the car sputtered, but drove perfectly fine once going above 5mph. After about 5 minutes of driving, cel came on, checked it with my accessport, p0519 idle control system malfunction, cleared ecu and same thing happened.
I took the iacv valve off, cleaned it and put it back on with new oem gasket. Same problem. Does this mean i need to replace the iacv valve? Or do i need to keep driving it? Could it be a gummed up throttle body? Idle screw adjustment? Tps sensor? Something else?
Please help, i dont want to start just replacing parts 😂
4eat05 is offline   Reply With Quote
Old 10-13-2020, 08:06 PM   #2
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Well today i cleared the code again because i hate seeing the light on, and the car no longer studders or hesitates in drive or reverse, and the cel hasnt come back on, but it still idles high in park or neutral.
Any ideas aside from just replace the iacv valve and pray?
Old 10-13-2020, 08:21 PM   #3
subienoobie75
Member#: 513758
2004 impreza wrx
black
maybe look to see if your purge control valve on the fuel line just under the intake right by the alternator. i am rebuilding mine and honestly mines was doing the same when my purge valve was disconnected. yours could be damaged? just a thought. i know the fuel system is pretty complex but not impossible to figure out. on the stock hood about the middle of the drivers side should be a diagram of that system im talking about. i may not be a subie guru but im a tech so a little helpful maybe.
subienoobie75 is online now   Reply With Quote
Old 10-16-2020, 06:08 PM   #4
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Purge valve is still hooked up, no vacuum leaks i can find without a smoke machine.
I guess ill order a new iacv valve, since im not sure if tps sensor or anything else could possibly cause this?
Old 10-16-2020, 09:59 PM   #5
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 10-16-2020, 11:55 PM   #6
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
I have a good working condition idle control I can sell you, please pm if interested.
D-Rodman is online now   Reply With Quote
Old 10-19-2020, 12:36 PM   #7
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Cleaned it again eith gasoline, still drives great, no more stumbling, hesitation or trying to stall, but still idles high in park and neutral.
Anything else that could cause this?
Could tps sensor do this or park neutral safety switch while throwing a iacv cel instead of tps or park/neutral cel?
Old 10-19-2020, 03:30 PM   #8
rallymarty
Member#: 17418
1968 Camaro SS/RS
What is "high idle" RPM you're seeing? Automatics will usually rev a wee higher in P/N vs. in gear. If just a few hundred RPM difference, I don't think you have a problem.
Disclaimer: I don't own an autotragic WRX, but just see this with other auto trans vehicles I own.
rallymarty is online now   Reply With Quote
Old 10-21-2020, 10:33 AM   #9
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Idle around 1800 rpm in P and N, used to idle at like 800 rpm in p and n before this happened.
Cleaning iacv valve seemed to fix the hunting idle/hesitation/stumbling and no more cel, but still idle higher than before...
Old 10-21-2020, 01:14 PM   #10
D-Rodman
Member#: 110078
05 Saabaru JDM STi
I still have a good original Subaru idle control valve for sale, pm if interested.
Old Yesterday, 06:19 PM   #11
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Now im just getting a p0507 idle too high, no more p0519, what else could possibly cause these issues?
