Welcome to the North American Subaru Impreza Owners Club Wednesday September 18, 2019
Old 03-30-2016, 03:59 PM   #1
ir0nmanx
Member#: 432894
2016 WRX
World Rally Blue
Default Homelink not registering with garage door
Hey guys, I was wondering if anyone else has any issues syncing their garage door openers with homelink. I have a genie garage door system, my brother's 2015 wrx have not been able to use the homelink in his car to open/close the garage door. I have a 2016 wrx and it works fine with the garage door. I have already erased all the previous remotes on the garage door, was able to re-sync my homelink but not my brother's. I am able to sync other remotes with the system but not his. Any help/tips
thanks
ir0nmanx is offline   Reply With Quote
Old 04-02-2016, 10:59 PM   #2
Medic3195
Member#: 427407
Did you follow the directions with the learn feature at the opener itself. I believe you have to push the button on the actual door open and then follow directions, I believe you have to hold the homelink button in the car and it should close or open the door.
Medic3195 is offline   Reply With Quote
Old 04-03-2016, 10:22 PM   #3
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
go to www.homelink.com
You can put in your garage door info and it will show a video of how to program
RexyGirl is offline   Reply With Quote
Old 04-05-2016, 12:09 PM   #4
SUBIEx3
Member#: 444141
2016 WRX Premium
WR Blue Pearl
Ir0nmanx, I was also having issues with programing my genie garage to my Outback and Crosstrek. Here's what I did, follow the instruction in your manual for the garage door opener. Once that was complete I then had to go press a small button on the actual genie garage door motor then press the corresponding button on the home link. Here is a link i used.
https://www.geniedoor.com/homelink-g...er-programming
SUBIEx3 is offline   Reply With Quote
Old 08-18-2019, 03:25 PM   #5
KevinSA
Member#: 505424
We've had issues with our garage door, but it turned out that a previous contractor poured epoxy over the receiver. Luckily, we had another great company fix that and it all works like a charm now!
https://www.pooldeckraleigh.com/epoxy-flooring/
KevinSA is offline   Reply With Quote
