Welcome to the North American Subaru Impreza Owners Club Friday April 12, 2024
Old 07-30-2009, 10:42 PM   #1
carpfish
Member#: 116737
1996 impreza
blu e
Default Will an 05 sti steering rack fit in a 2001 Outback
In my wifes Outback The power steering has been a little jumpy, and slugish lately. It was low on fluid a couple of weeks ago so I topped it off. did not really help. I was changing the thermostat today and I noticed that the boot was tore were it connects to the tie rod. It was leeking fuid from it. I guessing seals are leaking in the rack? I just put in a Q rack in my sti no core credit for me. Anyway have the old rack from it laying in garage. Is there any chance it would fit into the Outback. Anybody know?
Thanks.
carpfish is offline   Reply With Quote
Old 08-10-2009, 10:02 AM   #2
apro1
Member#: 6165
It will
apro1 is offline   Reply With Quote
Old 08-10-2009, 10:10 AM   #3
Arnie
Member#: 1725
2002 Subaru Forester
SG silver
If its an 04 STi it will be a direct fit. if its an 05 STi then you'll need to quite a bit more, i.e. subframe swap, etc.
Arnie is offline   Reply With Quote
Old 08-10-2009, 10:22 AM   #4
Ls3
Member#: 160895
2003 Impreza WRX
2014 Impreza WRX
I just swapped in a 2005 STI rack + crossmember in. For fun I held up the 2005 rack to my 2003 crossmember and saw that it would bolt up. You just need two longer bolts for one side. M10x1.25x50mm should do the trick.
Ls3 is offline   Reply With Quote
Old 08-10-2009, 11:02 AM   #5
rice h8r
Member#: 94524
05/+ has a different style rack so I'm not sure bolting it up to a earlier style subframe would work perfectly.
rice h8r is offline   Reply With Quote
Old 08-10-2009, 02:01 PM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
The 05+ turbo crossmember would be needed.
Old 12-16-2009, 04:02 PM   #7
zmarko
Member#: 46882
05 LGT Wagon 5MT
01 OB H6 VDC
Sorry for the lengthy bump, but I just picked up an '01 Outback H6 VDC, and the steering is jumpy also. Is the '04 swap into the H6 model the same direct bolt in as the 4 cyl model? Thanks for any input.
zmarko is offline   Reply With Quote
Will an 04 sti steering wheel fit an 06? Gso2k Interior & Exterior Modification 2 07-20-2009 03:23 PM
Will an 06 sti gauge cluster fit in a 04 wrx? subiewrx001 Electrical & Lighting 3 11-09-2008 08:03 PM
will an 06 STI gauge cluster fit in a 04 wrx? subiewrx001 Interior & Exterior Modification 1 11-09-2008 03:46 PM
Will 04-05 STi steering wheel fit on 02 WRX w/o modification? txl146 Interior & Exterior Modification 10 04-10-2005 12:06 AM
Will a USDM STi steering rack fit on a WRX wagon? redobs Transmission (AT/MT) & Driveline 8 07-29-2004 03:04 PM
