Welcome to the North American Subaru Impreza Owners Club Tuesday February 19, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 01-17-2019, 06:05 PM   #76
anarekist
Member#: 468117
2017 WRX
DMG
been hearing alot about these codes, what oil are you guys all running?
anarekist is offline   Reply With Quote
Old 01-18-2019, 01:42 AM   #77
E_WRX
Member#: 482486
At first I was running 5w-30 Castrol. After the code came I changed mine to Subaru 5w-30 with oem filter. Code is still there cant seem to get it to go away no matter what I do. Seems like going back to stock and warranty claiming it is the only way.
E_WRX is offline   Reply With Quote
Old 01-18-2019, 01:51 AM   #78
E_WRX
Member#: 482486
Originally Posted by noobultimatum View Post
I don't think you realize how expensive that ordeal would be fore SoA...
I do know how expensive the ordeal would be but it's not fair to the customers. Seems like this issue is happening to stock wrxs too. Subaru dealerships denying service on modified wrxs with this same issue is just bs if its happening to bone stock cars too. I was always under the impression that a dealership would have to prove the modifications caused the issue....
Old 01-18-2019, 11:07 AM   #79
noobultimatum
Member#: 431550
2016 WRX
ALL THE STAGES
Yes, you are correct.
But how frequent are these codes popping up? Keep in mind that here on the forums is where we are hearing about this CEL issue.
Is it more prevalent in modded cars or stock cars? or does it even matter?
If it IS a factory defect, then SoA would (in theory) issue a recall for the problem. Only reason they would issue a recall is if the cost of law suits/damage in the future -- due to the "defect" -- would be more expensive than dealing with it preemptively (recall).
To be clear, I 100% agree with you. If it is their fault, they should fix it on their dime since we paid for their product... unfortunately, this world is not a perfect one, so we are left to all kind of factors that play into a decision being made.
noobultimatum is offline   Reply With Quote
Old 01-18-2019, 11:52 AM   #80
Zrx_01
Member#: 481702
15 WRX
SMURF
5w30 MOTUL 8100. Before that I was on OEM.
Zrx_01 is offline   Reply With Quote
Old 01-18-2019, 11:55 AM   #81
Zrx_01
Member#: 481702
15 WRX
SMURF
^^^^TRUTH
Just be optimistic about your warranty claim.. No reason to stress over something that is out of your control. Hopefully your dealer is mod friendly
Old 01-18-2019, 06:26 PM   #82
E_WRX
Member#: 482486
Originally Posted by Zrx_01 View Post
^^^^TRUTH
So have they resolved the issue for you?
Old 01-19-2019, 06:26 PM   #83
Zrx_01
Member#: 481702
15 WRX
SMURF
Nah breh,
Still taking the car apart, And waiting for gaskets and boost lines with restrictor pill from Subaru....
Old 01-23-2019, 11:46 AM   #84
Zrx_01
Member#: 481702
15 WRX
SMURF
Update:
Techs ran diag on car... Stated that ECM needs to be replaced, everything else looks fine on car. Don't know if they checked cams or sprockets but sounds like it's pointing to ECM.
SOA refused to cover the vehicle due to ECM modification etc.. Looking for ECM or just paying quote 900+ for parts and labor..
Old 01-24-2019, 01:26 PM   #85
slimFA20
Member#: 433589
2016 WRX Premium
WR Blue
Was told by my tuner (BrenTuning) to only run Motul x-clean EFE 5W-30 on these FA20 DIT motors.
slimFA20 is offline   Reply With Quote
Old 01-25-2019, 12:12 PM   #86
Zrx_01
Member#: 481702
15 WRX
SMURF
Sounds about right...or just stick to OEM. Hopefully this code stays away with new ECM..
Old 01-25-2019, 09:34 PM   #87
E_WRX
Member#: 482486
So can the techs tell if the ecm has been ever manipulated or tuned?
Old 01-25-2019, 11:01 PM   #88
Zrx_01
Member#: 481702
15 WRX
SMURF
Not sure bud, but the dealer already knew I had modifications on the vehicle.
Techs notated that information.. Someone correct me if I'm wrong... The dealer can see your key cycles. As far as tune not sure.
I'm just hoping the code doesn't come back with the new ECM.
Old 02-12-2019, 08:23 PM   #89
bcterp
Member#: 409569
2018 WRX
Just got my 2018 WRX back from the dealer for P0018. Replaced oil control valve and had to ultimately replace ECU to keep the code from reappearing. The service advisor referred to it as “code burn in”. Weird that a 2018 ECU can’t properly clear a code after the issue is resolved.
bcterp is offline   Reply With Quote
Old 02-13-2019, 01:53 AM   #90
shmYng
Member#: 470818
Default Totally stock, same issue
3900 miles ago I had the clutch master and slave cylinders replaced under warranty, now I wait for weeks while they diagnose this code. Turned my car off for work, realized I left something at home so I turned it back on, and the check engine light was there. They haven't mentioned ECU yet, but I've been grilling my service rep to try and get a better answer for why this thing has been having so many problems completely stock. I don't drive hard. I've used Subaru official or better oil every 3500-4000 miles. I check out every sound and clean the car/undercarriage regularly. I am currently talking with a Lemon Law attorney to see if I have a claim, will get back to you guys once I have more info.
shmYng is offline   Reply With Quote
