06-13-2008, 08:59 PM | #1 |
Member#: 156478
Vehicle:06 330i Blue |
couple Q's on a turbo set-up DOM 3
i've chosen the turbo i'm going to go with
i'm going with the dom 3 what i'm wondering is...what else is nessecary to compliment this turbo... i know injectors...but sizing...? i want to be safe but have room to work with on these injectors... do i need a new inlet or will the stocker hold? do i need a bigger maf or will i be fine with my SPT intake... do i need an aftermarket boost controller? if someone can ethier link to me a list or give me some guidance i'd be more then happy Thanks for your help guys...i wanna get this rolling...
06-13-2008, 10:02 PM | #2 |
Member#: 23553
Vehicle:2005 STI - Insanity! 2014 WRX - Daily |
At minimum, you will need the following:
3" Turbo back exhaust (catless or high flow catted) 740cc+ injectors (I used the DW 860cc injectors) A high flow fuel pump (Walbro 255lph here) A turbo inlet (I suggest the Perrin) A big MAF intake (Perrin, COBB 70MM, APS 70MM CAI, etc) A boost control solenoid like the Perrin or GM (I went with an AVC-R) A large top mount IC (I went with a large APS Front Mount) I would also HIGHLY suggest the following: A new clutch TGV Deletes Fuel Rails An EWG Setup |
06-13-2008, 10:08 PM | #3 |
Member#: 92894
BAIC
Vehicle:2015 Wrx - fury kit silver duh |
Gimmick turbo inlet ftw, also cheaper then the Perrin.
06-13-2008, 10:16 PM | #4 |
Member#: 161270
Vehicle:2007 STI BLACK |
im using a gimmick inlet on my dom3 with an spt intake but as far as the rest pm me and ill send u the list
06-13-2008, 10:27 PM | #5 |
Member#: 127232
W. Canada
Vehicle:2017 Mullet SS1LE |
Fuel rails and an EWG is not needed, unless you will be pushing past 23psi, which is bad for the stock motor anyways.
06-13-2008, 10:31 PM | #6 |
Member#: 171920
SCIC
Vehicle:06 sti aspen white |
it also depends on what you want out of the car.do you good pedal response?or are you just looking to get the most power out of the dom3?
06-13-2008, 10:34 PM | #7 |
Member#: 171920
SCIC
06-13-2008, 10:35 PM | #8 |
Member#: 161270
^^^^^whole heartedly agree as well
06-13-2008, 10:42 PM | #9 |
Member#: 171920
SCIC
phuh,let me see the list..your mods
06-13-2008, 10:51 PM | #10 |
Member#: 161270
hey
lol ya power or EVERYTHING
06-13-2008, 11:01 PM | #11 |
Member#: 171920
SCIC
power only please
06-13-2008, 11:05 PM | #12 |
Member#: 161270
ahh **** it ive spent enough money on parts and enough time and sweat to post it ALL lol!
06-13-2008, 11:05 PM | #13 |
Member#: 161270
Accessport V2 w/ Protune
Spt Short Ram Intake Spt Heat Shield- Insulated modified air duct Snorkel Delete Ram Air Dryer Tubing Gimmick Turbo Inlet Blouch Dominator 3.0R Invidia G200 TBE- down pipe heat wrapped Perrin Signature Series FMIC AEM Meth injection Perrin Radiator Shroud Redline Water Wetter Sti V-Front lip Spoiler Apexi Ground Stabilizer 2 Greddy Catch Cans Ebay Front and Rear strut bars- FTW!! Perrin 25mm Front sway w/ Endlinks Perrin 25mm Rear sway w/ Endlinks Tein H-Tech Springs Perrin Rear Stabilizer Kit Perrin Shifter Bushings Perrin lightened crank pulley Gt spec Front Ladder bar Apexi Turbo Timer Subaru Underseat subwoofer Sti Titanium Shift Knob Uncle Scotty's Transmission Fluid Cocktail 20% Tint all around Deautchwerks 860cc Injectors Walbro 255lph fuel pump Grimmspeed coated TGV delete Grimmspeed PnP Coated Exhaust manifold w/ high flow crossover Greddy Profec B Boost Controller Wiseco Forged Pistons Head Studs/ Gaskets 8mm Phenolic Spacers Turbo Heat Shield Grimmspeed PnP Coated Uppipe Defi boost guage KSTech scoop delete |
06-13-2008, 11:07 PM | #14 |
Member#: 161270
oh and ACT Hd street clutch
and ACT streetlite flywheel |
06-13-2008, 11:15 PM | #15 |
Member#: 171920
SCIC
just a couple of Qs.
any trouble with the perrin pulley? curious,because i was told that maybe with big power,it could sometimes cause car to stall after fast accelleration,and then decelleration. why the boost controller? other than that,nice list |
06-13-2008, 11:25 PM | #16 |
Member#: 161270
BC because stock boost controller really sucks (i think they changed it so your 06 i believe has the one from previous years which is ok) the problem is on other years you can spike your boost at low rpm and then ride it out on the 07 you have to wait for it to come- might want to ask someone who REALLY knows how to tune the 07's because every tuner will tell u they can but they can explain it better as i am just passing on what i remember from conversations
06-13-2008, 11:30 PM | #17 |
Member#: 161270
and the light weight crank- you can tune your map to work with the lighter pulley and also increase idle which will keep this from happening but yea before when i first put it on every so often for the 3 or so weeks i had it b4 tune it would stall if i floored it to redline and put it straight into neutral (same thing will happen with light weight flywheel as these are the only 2 external weights on the crank so whichever you lighten or both have the same effect) but i love the benefits it accelerates and decellerates throught the rpms much quick (less rotational mass/inertia) and because it drops the rpms quicker you can get quicker smoother shifts IMO
06-13-2008, 11:30 PM | #18 |
Member#: 171920
SCIC
oh your talking about the boost control solenoid
06-13-2008, 11:45 PM | #19 |
Member#: 161270
yes and no
06-14-2008, 02:02 PM | #20 |
Member#: 156478
Thanks for the responses guys
i have the pump already on my set-up new clutch is going in on the install day of everything... put it this way i'm already stage 2... |
06-14-2008, 02:44 PM | #21 |
Member#: 127232
W. Canada
If you are already on STG2, this is what you need, and what I'd get if I'd go Domtree.
DOM3 (2.4" inlet 8cm2) DW740cc injectors Walbro fuel pump APS top mount or FM (your choice, to hack the bumper or not) APS Inlet APS 65mm intake Grimmspeed TGV deletes Prodrive BCS |
06-14-2008, 06:07 PM | #22 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
Question for people running 740cc injectors with a Dom3 or other 3076-based turbo:
What are your peak IDCs? Thanks! |
06-14-2008, 08:20 PM | #23 |
Member#: 161270
good question i would think pretty high bigger inj might be better
06-14-2008, 08:41 PM | #24 |
Member#: 171920
SCIC
for 2.4 inlet,and tmic=740-750cc
3" ,andfmic=850-860cc |
06-14-2008, 08:48 PM | #25 |
Member#: 171920
SCIC
ive been talking to a tuner,and this wrx wagon is stock inlet,tmic with atp gt 30r and they told me 740-750 cc would be perfect.850 are a little too much.but this guy still had alot of stock parts though.
Dyno Tune: IAG makes 409whp on 2.5L + Prototype Blouch DOM 3.0 XT-R | IAG Performance | Proven Power Bragging | 155 | 07-13-2011 07:06 PM |
Selling Dom 4R Turbo set-up | STiSteve | Engine/Power/Exhaust | 2 | 08-03-2009 03:32 AM |
WRX turbo set up on 2002 impreza | fasta$$wagon | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 02-11-2009 01:41 AM |
2002wrx turbo set up on 2001 2.5 rs | witte1919 | Normally Aspirated with bolt-on Forced Induction Powertrain | 9 | 03-13-2008 06:06 AM |
need stock 04 and up wrx turbo set up | impr3vize | Private 'Wanted' Classifieds | 0 | 07-14-2005 02:58 PM |
