01-24-2008, 08:52 AM | #1 |
Member#: 84482
Vehicle:2005 STI.UR gt4088r E85 pro comp sti |
My ongoing problems with the idle/motor please help!!
Well I tell you a short story of the long story, this is the second motor in my car, the first one had low compression and rod bearing #3 failed, well i get the car back with a slight idle problem, it would idle around 1800-2000 rpms and on the highway it felt like the car would engine break real slow like the rpms were keeping it from enginge breaking when i left off the gas going about 70mph in 6th gear and the throttle was delaying the rpms it felt like
Then yesterday I got my pump gas map from Phil and during lunch i went and downloaded it to the ecu, then after work drove to pick up my g/f and after driving for 15 mins the car just started sputttering, i was giving it gas and it was not responding or it was delayed about 2 seconds, and trying to up to speed was so hard b/c the throttle was so jerky, the rpms were not building at a steady pace more or less...then the car was giving out a really strange noise, it would like a if i can spell it dushhh sound, like a sputtering dush sound every so often, it was really scaring me, so i baby it the rest of the way home....anyone have problems like this before the shop before i picked the car up went through everything they thought of checking the hydra's wireing harness check all the grounds check the throttle assembly, including wires and iv been in touch with Phil and I think im gonna send the hydra to him, to see if he can figure it out, but we both think its really not the hyrda, i just hope we can find the cause!!! has anyone ever heard of these symptoms?? i can't even sleep at night, the car has been down since May and i just want a working car back!!
01-24-2008, 12:42 PM | #2 |
Member#: 84482
well i talked with phil, and he thinks its the spark plugs....i had a boost leak and it ran rich causing the spark plugs to fail.....so im changing them out tonight
so if it fixed the problem ill let everyone know |
01-24-2008, 12:47 PM | #3 |
Member#: 9960
Vehicle:2002 Impreza WRX WRBlue Perl |
why not change to a working map that you had before the motor went before, and drive around on that to see how it works.. Obviously don't push the engine on that map, but just to see if it isn't something with the Hydra.
01-24-2008, 03:38 PM | #4 |
Member#: 84482
^^^yeah i have the map that i was tuned for on the dyno, but bc this is a new motor it can't be a great tune, so im taking it easy until i get tuned on this motor....and hopefully the spark plugs will fix the problem
ill update tonight after i put in the new ones |
01-24-2008, 03:47 PM | #5 |
Member#: 9960
Yes, i would give the map a try just to see if it clears things up. I would have thought that faulty plugs would be most obvious when the car goes into boost though. Were the problems you were having showing up while in vacuum puttering around or something?
01-25-2008, 01:42 AM | #6 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
are you running speed density?
Alot of times if you have a boost/vacuum leak, the speed density car's will idle very high. this may be your driveabilty problems. |
01-25-2008, 08:34 AM | #7 | ||
Member#: 84482
yeah im running SD, i believe all the vac lines are fixed i really when through and checked last night when i changed the plugs, and the car started great and idle pretty good for the first time ever this is one of the plugs, they all looked the same!! the ends were completely black and reaked of fuel....pig rich!! |
01-25-2008, 01:12 PM | #8 |
Member#: 59388
RMIC
Vehicle:2003 WRX - Hybrid I do my own stunts |
Not to rain on your domain, but it "might" help if you can post some pictures of your sparkplugs instead of the floor and shelves.
We can see the plugs are dark, but we need to see what type of residue you have, and blurry photo's don't illustrate them very well. Thanks! |
01-25-2008, 01:19 PM | #9 |
Member#: 95840
NWIC
You need to pressure test your system starting right out of the turbo outlet. pressurize it to 25psi and report back. You may need a bottle of soapy water to spray on intercooler connections and the intake manifold.
post back when you're done |
01-25-2008, 02:20 PM | #10 | |
Member#: 84482
01-25-2008, 02:22 PM | #11 | |
Member#: 84482
hmm, iv never done this but i have a compressor, any sugestions?? |
01-25-2008, 03:23 PM | #12 | |
Member#: 95840
NWIC
disconnect the outlet to the turbo and I have a homemade pcv ppe fitting/plug that I drilled and tapped to put a quick connect on it. I put this fitting in the silicone connection and tighten the t-bolt clamp around it. This allows me to plug in my air compressor hose and use the regulator to go up to whatever psi I want and then check the system for leaks with soapy water. |
01-25-2008, 03:26 PM | #13 |
Member#: 95840
NWIC
I take that back. i forgot I bought one with a pipe threaded center section. Now I just screw my quick connect into the center and put it in the silicone connection for my fmic. then I tighten the t-bolt clamp around the piece and pressurize they system.
01-25-2008, 03:35 PM | #14 |
Member#: 84482
thanks for the pic..im def. gonna try this
it idles around 1500 now...which is much better and more consistant than it was before |
01-25-2008, 06:49 PM | #15 |
Member#: 60142
Vehicle:2011 WRX Grey |
These damn MAFS ought to be built into the friggin intake manifold, immediately in front of the TB. What the engine actually gets is exactly what it sees - end of problem.
Or is this simply un-doable for some reason I'm just not seeing? |
01-25-2008, 06:56 PM | #16 | |
Member#: 95840
NWIC
Then, if you had a boost leak with your maf placement, you would just work the turbo harder to make the same boost. I know, I'm captain obvious, huh? edit: how about 1 maf per cylinder? get rid of the tgv's and have absolute blow thru. talk about a tuning nightmare! |
01-25-2008, 07:24 PM | #17 |
Member#: 60142
Yeah, well, I'm sure you've been called worse, too.
I guess the point I'm tring to make is if it were built into the intake, sure, you could still have both pre and post-turbo leaks, but neither would affect the health or status of the engine. As it currently stands, if the system integrity is not perfect, at best the engine runs like crap (blow-thru) and at worst, you grenade it (suck-thru). And if you popped off a hose completely, no problemo, it's just a N/A motor until you fix the leak. |
01-26-2008, 04:31 PM | #18 |
Member#: 84482
well i check for leaks, did find anyone, its running terrible again and its misfireing, i am not going to turn the motor on again....looks like its gonna get trailored
who the hell knows |
01-26-2008, 04:49 PM | #19 |
Member#: 9960
take it back to your tuner... Does anyone you know have a hydra you can swap into your car just to see if there is an issue there somewhere? I know it usually is a mechanical fault and not electrical with these things, but you never know
01-27-2008, 03:16 PM | #20 |
Member#: 84482
thanks, yeah ill let know what i end up doing with the car
01-31-2008, 09:30 PM | #21 |
Member#: 84482
Phil sent me a base map....its running perfect....thank god!!!!!!!!!!!!!!!!
01-31-2008, 09:54 PM | #22 |
Member#: 9960
*pop's the champagne*
It would be interesting to see what it was about the other map that was causing so many problems.... |
02-01-2008, 12:14 AM | #23 |
Member#: 84482
^^^^yeah i sent the map back to phil and he is going to look over it
basically it was a tune for a bad motor and the new motor didn't like it and was giving me all sorts of problems |
Problem with AEM meth kit... Please Help! | rpeirats | Water/Methanol Injection, Nitrous & Intercooler Cooling | 4 | 11-23-2008 03:43 AM |
problem with oil temp gauge! please help! | v8eaterWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 06-10-2006 03:22 AM |
Can a remote starter ruin the starter motor? Please Help! | big67 | Car Audio, Video & Security | 4 | 12-21-2005 09:15 AM |
fuel problem with ver 7 motor swap,help!! | momentum | Subaru Conversions | 34 | 01-01-2005 10:03 PM |
problem with link ecu. someone please help! | STi2002WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-16-2002 05:04 AM |
