Tire & Wheel Forum sponsored by The Tire Rack |
06-26-2003, 08:42 AM | #1 |
Member#: 15799
Tires Mounted Backwards Dangerous?
I just noticed that two of my new KDWSes are mounted backwards, the sidewall has text saying "this side in".
Is this a big deal? If so why? Tire Rack Vender Mr. Tire in Arlington, VA did this. Should I take it back?
06-26-2003, 08:49 AM | #2 |
Member#: 36372
Vehicle:'03 WRX Sedan Silver |
Definitely have them fix them.
Are they assymetrical tread patterns? That's why they would have an "inside" marking. |
06-26-2003, 09:00 AM | #3 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
If they were simply on the wrong side (running reverse from the arrow on directionals) then it would not be a problem *in the dry*. But you've got a different problem. I don't know specifically on your tires, but on some, the sidewall is actually stiffer on the outside than on the inside. Take them back!
jack |
06-26-2003, 10:33 AM | #4 | |
Member#: 15799
details here: http://www.bfgoodrichtires.com/asset...ce_ta_kdws.pdf |
06-26-2003, 10:35 AM | #5 | |
Member#: 15799
"Benefits: Outstanding all-season traction and handling in dry, wet and snow conditions Superb steering response and road feel; exceptional control even at high speeds Confident snow traction with reduced noise Excellent wet and dry grip (UTQG traction grade=AA) Enhanced wet grip in shallow water depths; excellent treadwear for an ultra-high performance tire Outstanding cornering feel and handling; excellent progressivity (allows driver to anticipate the turn and feel impending loss of adherence) and recovery Tremendous cornering force Excellent strength, smooth ride and consistent footprint; maximum tread contact area maintained under high-speed conditions Serious sports car appearance W-speed rated; capable of speeds up to 168 mph Features: Innovative asymmetric tread design Center rib with tapered lateral voids for excellent on-center feel Increased interior groove offset enhances snow traction; also equalizes wet/dry handling, M&S rated All-season tread compound Flat/oval footprint Shoulder drop to contact width g-Control TM Sidewall Inserts resist deflection Dimensionally stable polyester carcass plies, ETEC System TM (Equal TEnsion Containment System) Aggressive tread and shoulder design" |
06-26-2003, 10:40 AM | #6 |
Member#: 15799
thanks for the info guys.
i'll take them back ASAP! numbnutz dorks, makes me afraid to have them anywhere near my baby. |
Mounting Tires-Should I let Discount Tire mount my tires? | DomzWRX | Tire & Wheel | 6 | 06-04-2007 10:29 AM |
Dismounting tires without damaging them without a tire mount tool | chimchimm5 | Tire & Wheel | 11 | 02-01-2007 06:56 PM |
Getting tires mounted at Tire Kingdom/Merchant Tire on York Rd. | homer227 | Mid Atlantic Impreza Club -- MAIC | 11 | 12-30-2006 04:33 PM |
Changing tires can be dangerous... | jetfan8178 | Off-Topic | 6 | 10-08-2006 12:22 AM |
Blizzack mounted backwards | freshsti | Tire & Wheel | 2 | 12-06-2005 12:30 AM |
