03-25-2007, 06:07 PM | #251 |
Member#: 26361
TXIC
Vehicle:My shenanigans are cheeky and fun |
After using 9s I wouldnt go back. Obvoiusly you can still do well even on 7.5s but driving on 245s on 9s simply feel worlds better than on a smaller rim.
03-25-2007, 08:31 PM | #252 |
Member#: 25859
South East
Vehicle:1965 MGB yellow 2008 Black Miata |
If you are planning on running different tires for the street and for autocross, go with the 9". If you are not fully prepped otherwise, your money is better spent elsewhere in the beginning, like exhaust, suspenion, tune.
03-25-2007, 08:47 PM | #253 | |
Member#: 96194
Branden |
03-25-2007, 10:29 PM | #254 |
Member#: 49881
South East
Vehicle:2006 Subaru STi 1989 BMW 325is |
ill probably be on the stock wheels too! haha
03-26-2007, 07:21 AM | #255 |
Member#: 123364
NESIC
Vehicle:2004 WRX |
I notice nobody running ALKs, did I miss something the rule book? I intrepreted the whiteline ALK as a bushing change to gain some caster. Its not an adjustable lower control arm. I don't think.
03-26-2007, 07:47 AM | #256 |
Member#: 39070
TXIC
Vehicle:-- GTF off my lawn! |
It's changing a 'non-moving' suspension mount point, I believe. At least, I'll say that this is what I've been told. You can replace the actual bushing w/an offset one, but an ALK is more than just a bushing.
03-26-2007, 09:35 AM | #257 |
Member#: 26361
TXIC
The alk changes the bushing housing as well. Whiteline does sell a offset bushing you can put into the stock housing to gain the caster while remaining legal.
03-26-2007, 09:40 AM | #258 |
Member#: 11482
South East
Vehicle:02 WRX Acute Stickeritis |
03-26-2007, 09:53 AM | #259 |
Member#: 25859
South East
I will have to look at it, but my understanding is that the offset is prohibited also. If you are a cheating bastard you can always use a mount from a Forester. Looks stock and does the same thing as an ALK. I have heard a few people mention that is makes bump steer worse though.
03-26-2007, 05:50 PM | #260 |
Member#: 123364
NESIC
Vehicle:2004 WRX |
hmm, thats annoying I got a Race ALK kit thrown in with the Used Coilovers I picked up.
03-26-2007, 06:26 PM | #261 |
Member#: 11482
South East
Sell it for profit.
-Biggly |
03-26-2007, 07:29 PM | #262 |
Member#: 123364
NESIC
Vehicle:2004 WRX |
What ride height should I shoot for? I'm lucky, I live 10 minutes from a place that will corner weight the car. I haven't installed the coilovers on the STi yet because the weather keeps flipping from spring to winter. I know on my civic I only went about 1.5 inches below stock. I was figuring about the same on the STi would put me in the ball park. What I did when I installed my civic coilovers was take the stock strut measure it, then set the coilover roughly 1.5 inches shorter. Then since I have nearly perfect(with in a 1/4) flat garage floor I measured from the top of the fender to floor on all four wheels to make sure the car was even.
03-26-2007, 08:18 PM | #263 |
Member#: 66033
SCIC
Vehicle:05 STi |
DrewSTi,
What size tire did you plan on running? That will have a little bearing on how low you can go. But 13.75"-14" front and 13.5 rear should be a good ride height for ya. Aim for 14" front if you are running 245/45's. Those numbers are center of wheel hub to fender. |
03-26-2007, 09:45 PM | #264 |
Member#: 123364
NESIC
Vehicle:2004 WRX |
ok cool, because the coilovers are used and I had to break them down and clean them so I don't have the height settings they came with. BTW do you run with CART? I was gonna try to make it down there this summer.
03-27-2007, 04:16 PM | #265 |
Member#: 66033
SCIC
Vehicle:05 STi |
No not anymore. I did about 2 years ago but I have since moved from CT. Last I heard, they lost the lot they used to race at for this year and are currently looking for a new lot to race in. Keep an eye on their website for info. As far as making the trip from MA...thats your call...Im pretty sure they dont run an STU class and they dont really follow SCCA rules and their events arnt run very well.
05-10-2007, 09:50 PM | #266 |
Member#: 36792
Vehicle: 2018 BMW M2 2016 FRS RS 2.0 #661 |
Bumped, because this thread died!
05-27-2007, 07:57 PM | #267 |
Member#: 56718
Vehicle:2005 STi Black |
Ok I need a bit of help. I had a small incident at a race this weekend and my rear control arms, endlinks, sway bar mounts and possibly trailing arms on the right rear now look like bananas. I figured I might upgrade a few of these pieces over stock since they need to be replaced but I want to make sure I'm within the rules. Most of the aftermarket pieces I've seen are adjustable but I think the rules state that that you cant have the adjustable lateral links if you have camber plates. So what exactly are my options? Should I just buy stock pieces and be done with it or upgrade while I'm in there?
05-27-2007, 08:26 PM | #268 |
Member#: 36792
See if you can locate a used set of stock lateral links and have these pressed in, part# 19.7101: http://energysuspension.com/pages/subaru.html
05-27-2007, 08:27 PM | #269 |
Member#: 11482
South East
I'd do stock endlinks with better bushings. Then do camber plates up top in the rear. I have the super-adjustable rear endlinks and were I to do it all over again, my choice would be what I am recommending for you.
-Biggly |
05-28-2007, 09:26 AM | #270 |
Member#: 56718
Awesome thanks guys!
05-28-2007, 09:37 PM | #271 |
Member#: 49881
South East
Yeah I agree with Biggly!
on a side note, I had FTD and FTP at this weekends event! |
05-29-2007, 10:28 AM | #272 |
Member#: 45177
TXIC
Vehicle:2003 GDA White Volks |
05-31-2007, 11:04 AM | #273 |
Member#: 25859
South East
Sounds like you got a curb? Agree with above and am jealous of the FTD/FTP
05-31-2007, 02:03 PM | #274 |
Member#: 56718
06-01-2007, 09:07 PM | #275 |
Member#: 25859
South East
Happens sometimes. I was really pushing at one autocross and tried to save a spin and almost put it into a bunch of trees. They were coming really fast and once I figured it wasn't worth saving and that I wasn't going to save I put both feet in. Missed them by 10 feet. Make sure to look for additional damage while under there, you don't want a mechanical failure to cause additional damage. Good luck.
Air Force Guys Check-in (other branches welcome) | joosrsx | Off-Topic | 293 | 05-01-2010 10:36 PM |
northwest connecticut guys check in | 09wrxtorrington | New England Impreza Club Forum -- NESIC | 6 | 08-12-2009 02:46 PM |
New Guy Checking In | mmormino | Newbies & FAQs | 3 | 02-14-2009 12:07 PM |
New guy checking in | amfj231 | Newbies & FAQs | 7 | 12-22-2008 09:13 PM |
