Welcome to the North American Subaru Impreza Owners Club Tuesday February 18, 2020
Old 12-08-2017, 12:38 AM   #276
Marvin54
Member#: 317521
2015 WRX
hi
any idea where to install the nozle of an AEM kit meth stock intercooler and stock Throttle Body Hose
Thank you
Marvin54 is offline   Reply With Quote
Old 07-29-2018, 11:25 AM   #277
pcampbell
Member#: 437670
2005 2.5 SC OB
Personally I would buy a little nozzle insert that fits after the IC before the TB.
pcampbell is offline   Reply With Quote
Old 11-25-2019, 04:58 AM   #278
Maddy77
Member#: 508188
Hello everyone,,
Denatured alcohol is NOT methanol, it's ethanol that has been denatured with things such as Bitrex and Methanol.
Isopropyl IS NOT methanol.
snaptube.cam/ syncnet.onl/telegram-web/ https://9apps.cam/
I would be careful just dumping anything labeled "alcohol" into my injection system.
Maddy77 is offline   Reply With Quote
Old 11-28-2019, 09:05 AM   #279
pcampbell
Member#: 437670
2005 2.5 SC OB
Default Water/Methanol Injection FAQ
Hey guys. I noticed that washer fluid msds is measured methanol by weight not by volume. -25F is usually around 34%. So my question is what VOLUME of pure methanol does it take to get it to 50% by weight? Assuming boost juice is 50% by weight not volume. Meth is about 6 lb per gallon and water is more like 8. I was thinking adding 24 oz of pure methanol per gallon(removing 24 oz of wiper fluid from the bottle first) would be roughly the right spot but that is going by volume. Doesn’t need to be perfect but I need significantly more knock resistance than wiper fluid is giving me.
Old 12-02-2019, 10:52 AM   #280
pcampbell
Member#: 437670
2005 2.5 SC OB
So I weighed a gallon of -25F wiper fluid and it is 8# per gallon (actual weight of fluid excluding the container).
If we believe the MSDS is around 33% then it is ~50 oz of meth per 128oz of wiper fluid which is 33.65% by WEIGHT and is 39% by VOLUME. My plan is to displace 24 oz of wiper fluid with 24 oz of HEET which will get me 57.8% by VOLUME or 52% by WEIGHT. These are rough calcs but I believe they should be about right. Cost about $7/gal which is $3 less than buying boost juice.
Old 12-06-2019, 07:33 AM   #281
pcampbell
Member#: 437670
2005 2.5 SC OB
2.28 gallons of straight meth(6x 4 packs of 12oz yellow Heet). was $35 shipped from Walmart. Yes significantly more expensive than M1 but individual measured containers and sealed containers is key for me.
Old 12-08-2019, 02:34 PM   #282
pcampbell
Member#: 437670
2005 2.5 SC OB
To get roughly 50-50 water meth. Remove wiper fluid to slightly above the lip in the bottle (105 oz mark). Add 24 oz of heet (2 bottles).
Old 12-13-2019, 01:54 PM   #283
bergs
Member#: 124376
Is there any sort of demand for lab grade methanol in the tuner world?
I am working with considerable amount of methanol to perform a specific cleaning process and the "waste" methanol has been exposed to nothing more than the atmosphere for 20 minutes during the cleaning. It is then disposed of.
As a result of the minimal exposure the methanol is getting, I started to become curious if this "waste" could be repurposed into something besides an incinerator.
bergs is offline   Reply With Quote
Old 12-14-2019, 12:17 PM   #284
pcampbell
Member#: 437670
2005 2.5 SC OB
Interesting, what did it absorb? It’d probably be fine for methanol injection mixed with water.
Old 12-15-2019, 10:19 AM   #285
bergs
Member#: 124376
There is a coated optic lens that is immersed in the methanol in an ultrasonic cleaner. No absorption to speak of other than exposure to the atmosphere.
Old 12-18-2019, 07:10 AM   #286
pcampbell
Member#: 437670
2005 2.5 SC OB
Nice. I am sure it’d be fine to run in a car!
Old 12-29-2019, 01:05 PM   #287
pcampbell
Member#: 437670
2005 2.5 SC OB
Hey guys can anyone tell me how much of a significance does the injector placement have? I currently have mine inside of my IC before TB but it is also offset (not directly inline with the TB). I am thinking about moving to 2 smaller nozzles post TB on the intake manifold as it splits into 2 cylinders per head. I assume this will be better, but... how much better?
Old 12-29-2019, 01:28 PM   #288
blurred
Member#: 47143
Try to find this stuff, it's 50% (not sure by volume or weight, it's fine for my power level as a safeguard, not sure if I was trying to use it as a fuel though)
blurred is offline   Reply With Quote
Old 12-29-2019, 05:25 PM   #289
pcampbell
Member#: 437670
2005 2.5 SC OB
How much does that -40C stuff cost you? We don't have it in the USA, even in Vermont , but might be able to go get it in Canada lol. Maybe a truck stop near the border.
Old 12-29-2019, 09:20 PM   #290
blurred
Member#: 47143
$3cdn or less
https://www.homedepot.ca/product/tur...8-l/1000146609
Old 12-30-2019, 08:07 AM   #291
pcampbell
Member#: 437670
2005 2.5 SC OB
Nice. I wonder what they would say to a trunk full of water meth at the border crossing hehe. This stuff is probably very similar to boost juice for $8 a gallon shipped. Not quite worth a 4 hour round trip drive to Canada but maybe if I was there for something else. Like going to see a rally race in trois rivieres.
Old 01-24-2020, 02:30 PM   #292
notown775
Member#: 505863
its easier and cheaper to make your own. or at least in my case.
notown775 is offline   Reply With Quote
water / methanol injection kit -new or used blazin sti Private 'Wanted' Classifieds 3 05-27-2006 09:01 PM
Water/Methanol Injection or Race Fuel or Both ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2005 07:35 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-01-2004 06:52 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 05:51 PM
