Welcome to the North American Subaru Impreza Owners Club Tuesday February 18, 2020
Old 02-14-2020, 01:39 PM   #1
Krowten
Member#: 511680
Default P0328 Knock Sensor Circuit High Input
Hello everyone, Tried everything I could to fix my issue but i need some more help....
Recently changed my timing belt (belt only), I have a 2012 Wrx hatch. Car has 225km and belt was never done, when I took the old belt out, the belt had skipped two teeth's which is probably why I had random misfires. everything went well, maybe 2 hours after driving, my car is showing the code p0328. Car idles and runs awesome. feedback knocks is at 5.00 when pressing on gas in gears, not idle or on revs.
  • -Changed the Sensor. Torqued and position was the same.
  • -fixed a bad ground I had on the block.
  • -checked the voltage and amperage of the connector.
  • -Checked my timing.
Every seems find and cant find the issue of this CEL.
Appreciate all the help and replies.
Krowten is offline   Reply With Quote
Old 02-14-2020, 08:44 PM   #2
Boxcar80
Member#: 491471
2009 Impreza
When you replaced the sensor did you torque it to spec? If I'm right it should be 17 ft. lbs. Any more and you can damage the sensor.
Boxcar80 is offline   Reply With Quote
Old 02-14-2020, 11:15 PM   #3
Krowten
Member#: 511680
Default Sensor
Yes torqued at 17 and the position was the same!
