Welcome to the North American Subaru Impreza Owners Club Friday December 14, 2018
Old 05-27-2003, 05:46 PM   #76
SDaWG
Member#: 9622
2002 Subaru WRX
Platinum Silver
Make: 2002 WRX Sedan
Mileage: 10,000 when happend, 13,000 now (taken this long for dealer to diagnose problem.
Time Out Of Use: Diagnose time, car still runs but with a lack of boost from turbo.
Problem And Likely Cause: No boost from turbo, rattle coming from below turbo when accel. pedal is tapped. Likely a failed
sensor and adamaged turbo.
Modifications: Silencer removal, K&N filter, axle back scoobysport muffler, turbo Timer...
Submitted For Warranty Work (Yes/No): yes
Reason Given For Denial: Turbo timer caused sensor to burn up leading to a failed turbo over time. Turbo likely ingested sensor that failed because of Timer.
Your Story: I'm sure there claim about the sensor messing up my turbo is valid, although there claim on my turbo timer causing it all to happen seems a bit far fetched. Waiting to speak to SOA rep regarding explanation for such claim. Dealer states 1500 for new turbo and sensor... I'm pissed.
SDaWG is offline   Reply With Quote
Old 06-06-2003, 01:06 AM   #77
PatTheRat
Member#: 12975
2002 Impreza 2.5RS
Silver Metallic
Make: 2002 Impreza 2.5RS
Mileage: 16,000 KMs
Time Out Of Use: None
Problem And Likely Cause: Clutch shutter, crappy clutch...
Modifications: No driveline mods
Submitted For Warranty Work (Yes/No): Sort of, spoke to service at my dealership about replacement. Guy there said SOC was aware of the crappy clutches and were working on some manner to rectify the situation instead of just continuing to replace crappy clutches with more crappy clutches. I am yet to speak to them again to get an update as to where this stands...
Reason Given For Denial: See above
Your Story: See above
PatTheRat is offline   Reply With Quote
Old 06-07-2003, 11:49 AM   #78
poison
Member#: 37678
Make: 2.5 TS Wagon
Mileage: 14020
Time out of use: none
Problem and likely cause: clutch shudder, problems shifting into 1st and reverse
Modifications: totally stock
Submitted for warranty work: yes
Reason given for denial: dealer could not replicate
My story: I bought the car 3 months ago with 11300k, had clutch shudder from the beginning, plus problems shifting into 1st and reverse. I waited about 1.5 months to take it in because I thought that either I need time to get used to the clutch, or I am an idiot. I have not gotten used to it, I am an easy driver, never ride, drop, grind the clutch, or force gear changes, or lug the engine; I have only owned manual transmissions, with no problems similar to this. I took it to the dealer, left it overnight, and they said they could not replicate the problem, sorry dude. I will be taking it back in. My email: [email protected]
poison is offline   Reply With Quote
Old 06-20-2003, 03:32 PM   #79
WRXWagon2112
Member#: 23524
2010 FXT
Angry Clutch Shudder
Make: 2002 Impreza WRX Wagon
Mileage: ~15,000 ***EDIT: ~30,000
Time out of use: none ***EDIT: 1 day (while at work)
Problem and likely cause: Clutch shudder, difficult to shift into 1st from a stop.
Modifications: TurboXS turbo-back exhaust, LHD STi-style headlights, no drive-train mods
Submitted for warranty work: No ***EDIT: Yes
Reason given for denial: N/A ***EDIT: Not denied
My story: This has been a problem ever since I bought the car about a year ago. At first, I thought I just needed to get used to the clutch. But it has persisted and gotten worse over the last three or four months. Iím hesitant to contact a local Subaru dealer because of the horror stories Iíve seen on this site. Iíll have to do something because this is getting supremely annoying and is likely causing additional damage to the transmission.
***EDIT***
So I finally took my car to a fairly reputable dealer for the 30K service stop as well as asking them to perform the clutch judder TSB. Apart from some standard BS about having to verify/recreate the problem, they did the clutch replacement under warranty and did not mention mods or "abuse" (of course, there never was any abuse but it seems that most dealers are trying to claim that). Now the car has NO judder what-so-ever. The biggest difference is the feel of the clutch. It is exceedingly light now. I don't feel this is a bad thing, just thought I'd mention it. I now have to re-acquaint myself with the feel of the clutch. But I don't mind as long as it doesn't shudder like crazy in the morning.
There are some excellent dealers out there. When you find one, make sure the management and SOA knows that you appreciate what they do.
WRXWagon2112 is offline   Reply With Quote
Old 07-02-2003, 03:32 PM   #80
ascott
Member#: 6545
Rally Blue Pearl
MAKE: 2002 5MT WRX Sedan
MILEAGE: 31,000
TIME OUT OF USE: 1 day (diagnostic)
PROBLEM: Grinding going into 1st gear while moving, difficulting shifting into 1st when stopped
MODIFICATIONS: Coilovers, Unichip, Samco Hoses
SUBMITTED FOR WARRANTY WORK: Yes
REASON GIVEN FOR DENIAL: not denied...completely
YOUR STORY: Tech was able to reproduce issue. Dealer immediately contacted SOA. Dealer told me that SOA told him that the transmission would have to be disassembled for diagnosis. If evidence of "abuse" or damage caused by modifications were evident, warranty claim would be denied and I would have to reimburse the dealer for disassembly time. I did not pursue the issue any further.
ascott is offline   Reply With Quote
Old 07-02-2003, 05:23 PM   #81
TSINightFall
Member#: 17980
2018 STI Limited
CWP
Mileage: 14, 000
Time Out Of Use: 1.5 days.
Modifications: Not much at the time. LHD STI lights, Prodrive muffler, and Eibach springs.
Submitted For Warranty Work (Yes/No): Yes.
Reason Given For Denial: na
Your Story: Dealer fixed the clutch shudder according to the TSB without much hassle. I did have to leave the car overnight so they could replicate the problem. I wasn't worried as it is easily repeatable. It shuddered severely almost every morning year round.
The TSB was done almost two months ago and I haven't had a problem since.
TSINightFall is offline   Reply With Quote
Old 07-02-2003, 06:54 PM   #82
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
n
Drews_WRX is offline   Reply With Quote
Old 07-03-2003, 10:10 AM   #83
eWRXshun
Member#: 39162
2003 WRX Wagon
Default Shifter binding in 1,2 gears
Make: 2003 WRX Wagon
Mileage: 5800
Time Out Of Use: 7 days and counting
Problem And Likely Cause: Difficult to shift into 1st and 2 nd gear. suspect SOP: bent 1-2 shift fork
Modifications: None
Reason Given For Denial: : D Covered by SOA
Your Story: During routine traffic merge, shifter popped out of 2nd gear and trans made grinding sound. Afterwards, 1-2 gear binds while shifting. Took into dealer on Monday with suspect bent shift fork.
Dealer stated Wednesday that the 1-2 gear selector was damaged and would replace it under warranty.
Expect the car back today.
Update: Car is shifting better into second, but randomly refuses 1st gear requests. Expect another post.
eWRXshun is offline   Reply With Quote
Old 07-10-2003, 10:16 AM   #84
WRXDD03
Member#: 24867
2004 STi
Default SOA Sucks
Mileage: 42, 000
Time Out Of Use: Don't know yet
Problem And Likely Cause: Clutch shutter, problems shifting into 3rd and reverse
Modifications: MRT Springs, Kartboy SS & Bushing, TXS Stage 1 unichip and MBC.
Reason Given For Denial: Clutch Shudder is normal with Subaru's on a cold start, reason for problems in reverse and third is caused by my Short Throw shifter...
Your Story: Complete BS IMO. I think we need to have a Class Action Lawsuit against SOA for all the BS they put their customers through...they advertise the car like it is a racecar, and then won't cover warranty because they say it was abused...***.
WRXDD03 is offline   Reply With Quote
Old 07-10-2003, 10:16 AM   #85
WRXDD03
Member#: 24867
2004 STi
Default SOA Sucks
Mileage: 42, 000
Old 07-10-2003, 09:34 PM   #86
WRXerRacer
Member#: 39181
2002 Impreza WRX
WR BLUE
Default Denied warranty work
Make: Impreza WRX 2002
Mileage: (approx.) 15,000
Time Out Of Use: 3 days intermittently.
Problem And Likely Cause: Turbo shakes at more than 4500 rpm, boost fluctuations, car not pulling strong at all(compared to stock)
Modifications: Injen CAI, Turbo-XS rfl blow-off valve.
Reason Given For Denial: Modifications on engine.
Your Story: Ever since about 2 months ago my car has benn getting slower and slower. Now i can't rev to anything over 4500 rpm or the trubo shakes and feels as though the engine is being choked off or closed off by something. Maybe a possible leak but i checked all vacuum lines and high pressure hoses. Subaru denied to even work on the car because of the mods.
WRXerRacer is offline   Reply With Quote
Old 07-21-2003, 06:37 PM   #87
jbtsurf
Member#: 14189
0219 GGWRX SW;STi
Aspen White;coolgraykhaki
Make: 2002 Subaru WRX wagon
Milage: 31,000
Time out of use: almost 3 weeks
Problem and likely cause: lost the abiliy to shift into 2nd gear at
any moment whether the car is on or off or at a complete stop with the cluch fully depressed. Broked shift fork inside transmission.
Mods: 18" P1's, spt suspension, pwr radiator, CAI, TBE, UTEC
Submitted for warrantee work: YES
when i submitted my car i was told that it would be covered under warrantee. then i was told it would be a 10% chance it may not get covered. then a 20% chance. Then a call telling me that the problem was a broken shift fork inside the transmission and that it would not be covered at all. and the reason for 'no coverage' was because of my modifications. even though higher horsepower levels are in no way related to that component i am still denied my 3-year 36K mi. warrantee. so subaru has my car and i have their rental car. it will be a stand off until my car is fixed under warrantee. and the longer they take the more money they will owe Enterprise. in the mean time im contacting my lawyer to send letters to the service department, the district service rep, and SOA. as for my intension of buying an sti or and a subaru for my wife, they are never going to happen now...ever, despite of what may come of this situation.
jbtsurf is offline   Reply With Quote
Old 07-24-2003, 06:26 PM   #88
wrxmom
Member#: 32512
2002 wrx wagon
wrb
Thumbs down
Make: 2002 impreza wrx wagon
Mileage: 43,000
Time Out Of Use: 2 weeks so far
Problem And Likely Cause: blown 2nd gear
Modifications: up-pipe, down-pipe, uni-chip, bov, exhaust,
Reason Given For Denial: second gear was ground smooth - driver abuse
Your Story: I was pulling out of the daycare driveway going down a back road went to shift into second the car made loud banging, shut the car down pushed it into the driveway and had it towed the 1st dealership wouldn't work on it because of aftermarket parts 2nd dealer where it was purchased also denied the work after I have spent days on the phone with SOA and the rep
The clutchand brakes were given to me under warrentee with all my mods, but when the tranny went they said no. The car is still at the dealership three states away because I thought they would take care of me. I did not abuse my car I have a 2 young kids and I was not racing it. I had also reported the grinding in 1st and reverse but they don't remember that now! I have had the car for less than 2 years.
Repor
confused:
wrxmom is offline   Reply With Quote
Old 07-24-2003, 07:25 PM   #89
Turbo4me
Member#: 2200
2015 Mazda 3
97 Miata, 96 Landcruiser
NAME: Curt McConnell
MAKE: 2002 5MT WRX Wagon
MILEAGE: 52,000
TIME OUT OF USE: 2 weeks (parts issues)
PROBLEM: Grinding going into 1st gear while moving, difficulting shifting into 1st when stopped, slight knock in engine
MODIFICATIONS: Prodrive springs, STi short throw shifter, BPM TBE,
REASON GIVEN FOR DENIAL: Covered
YOUR STORY: Took the car in for them to look at the tranny. They also heard the knock. Replaced 1st and 2nd gear syncros and replaced the short block under warranty.
Turbo4me is offline   Reply With Quote
Old 07-30-2003, 05:47 PM   #90
Technic
Member#: 581
2002 WRX Wagon
Very Blue
NAME: Andrew Hitchcock
MILEAGE: 32,000 (just under 2 years old)
TIME OUT OF USE: 2 days (so far)
PROBLEM: Grinding when going into first while stopped.
MODIFICATIONS: K&N air filter
REASON GIVEN FOR DENIAL: Abuse / operator error
YOUR STORY: Having trouble shifting into first. Took car to dealer for regular service and asked them to look at transmission. They tell me there is a problem with the transmission but they don't know what. They have to open it to determine if it is covered by warranty and that is $425, which I will pay if it is not under warranty. I say, "ok, open it up", because there is no way I abused it. In the meantime I have to ask my kind co-workers to drive me to and from work. So after a day I get a call back and am told that the first and second gear synchros are bad and are not covered due to abuse. So the car that I drive to work on the highway each day and sit in for 2 minutes before I turn off has been abused, well I want to know who did it so I can beat the hell out of them. It was probably that aftermarket air filter, they are evil and cause premature headlight failure. Anyway I am now calling this person at SOA, who tells me to call this person at the dealership, etc. I will update when I my problem is resolved...
Technic is offline   Reply With Quote
Old 08-01-2003, 01:47 AM   #91
Jademonkey
Member#: 9213
2000 RS
Red
Default My engine Blew
Make: 2001 RS (4eat)
Mileage: 59,000
Time Out Of Use: 2 weeks thus far
Problem And Likely Cause: Floated Valve, cracked piston, metal shavings ate bearings. Dealer says I race my car and drive it at high RPM's. Caused valve to float
Modifications: Ganzflo, MSD Wires, Borla Header & Catback
Reason Given For Denial: No evidence of manufacturer defect
Your Story: I've taken care of my car from day 1. Mobil 1 syn, and NGK copper plugs. Bought service manuals. Took car in for o2 sensor recall, and ECU reflash. I never raced my car. NO signs whatsoever of any trouble. I was returning from a backpacking trip in the Sierras. I was 20 miles from home, and my CEL starts flashing. I can't pull over immediately because of traffic. When I do, I hear this loud slapping noise. Dealer keeps overnite and diagnoses it in the morning. First story is they will replace it under powertrain warranty, but because of my mods, they say I have to pay to have the engine tore down and inspected. Fine with me. I did nothing wrong, and took care of the car. After engine tear down, they find a floated valve, cracked piston, and worn bearings. They accuse me of never changing my oil, and ask for service records. I always change my own oil... They ask for recepits i spent on the oil. Long story short. dealer says i over drive my car, race it, and don't take care of it, so they recommend to SOA to deny my warranty. Next day (today) , I call SOA, and they "stand behind" the findings decision of their dealership.
Jademonkey is offline   Reply With Quote
Old 08-05-2003, 10:28 PM   #92
Gramata
Member#: 41201
2002 Impreza RS
Make: 2002 Impreza RS
Mileage: 34,000
Problem And Likely Cause: Clutch shudder
Modifications: None yet
Submitted For Warranty Work (Yes/No): Not yet
Reason Given For Denial: N/A
Your Story: I bought my car used from a dealer who of course never mentioned the shudder problem.. I thought I was crazy since it really only happens bad in the AM... The Subaru dealer in Fullerton said they need my car overnight so they can have a manager drive it to make sure I am not "just a guy on one of the message boards abusing the warranty work" - I am having trouble finding the time to be without a car that long!!! Will update later.
Gramata is offline   Reply With Quote
Old 08-18-2003, 10:51 PM   #93
bhall687
Member#: 37376
Default Bad Rear Differential
Make:2004 WRX Wagon
Mileage:1900
Time Out Of Use:9 days
Problem And Likely Cause: Faulty Rear Differential
Modifications: Tinted Windows ha
Reason Given For Denial: They covered it.
Your Story: I was driving down a gravel road and ripped a turn, car did not hop just drifted around the corner and powered out of it. I got to the highway and once I got up to 50MPH it would start to whirrrr very loud. Then when I got to town I started downshifting and it was grinding and klunking quite loud, the next day, I took it to the dealer and they informed me that it was a faulty rear differential, then called me back a few days later and said it was ready. I called to say I was coming to pick it up and he then told me that they new differential that they put in sounded worse than the one that they took out. So At 2000 miles I am already on my third rear differential. That sucks. No problems since, only put 800 miles on so far though.
bhall687 is offline   Reply With Quote
Old 08-27-2003, 04:32 PM   #94
Blknblu
Member#: 29188
Chapter/Region: PRSIC
2000 Ducati M900
Make: 02 WRX
Mileage: 30,000
Time Out Of Use: 3 days so far
Problem And Likely Cause: Lock out of second gear
Modifications: Up pipe, turbo back, filter, ebc @16psi, turbo back
Reason Given For Denial: modifications
Your Story: Pure crap. I have two Subarus. My rex and my wifes Outback. I will never buy another one again period. Had plans to trade in the WRX for an sti in the next year. Not now. Dealer told me they "thought" it was a chipped tooth on the gear. SOA won't cover it because of mods. They can't tell me for sure what it is so I have to pay them about $400 just to take it apart and tell me what it is. Then they want another $1100 just in labor to fix it plus parts. SOA sucks
Blknblu is offline   Reply With Quote
Old 08-28-2003, 08:16 PM   #95
SoLiDbReAkZ
Member#: 13736
Make: 2002 Subaru WRX Sedan
Mileage: 29729
Time Out Of Use: 3 weeks
grinding into 3rd and 4th gears. Local dealer at last service did not put in transmission fluid.
Modifications:
STi uppipe, turbo-back exhaust
Yes (Third time for transmission)
Driver abuse (Shift forks bent, parts worn), and modifications
Your Story:
I had brought my WRX Sedan to my local dealership in Freehold, New Jersey to get my transmission and rear differential fluid changed. I was moving to Rhode Island, and wanted to have the fluid replaced before the car hit it's 30k mile mark. I brought the car into the dealership, they 'serviced' it. Then four days later I noticed considerable grinding when shifting into 3rd and 4th gears. I checked the fluid level, and it didn't even make it to the 'LOW' marker on the dipstick. I brought it in to the dealership again, they added fluid, and the problem persisted while on a test drive w/ the service manager. He confirmed the problem, but DID NOT admit that they goofed.
Unfortunately, I had to move to Rhode Island in the next two days. I made an arrangement with my local dealer to have the service manager call the service manager at a Rhode Island dealer near where I was going to be living--in order to have my car warranty serviced there. I dropped my car off at the dealership in Warwick, RI, and received a loaner car.
The next day I received a call from the service manager, scared and annoyed, indicating to me that from looking at the xerox'd copies of the service orders from the NJ dealer, it appeared that they "messed up the car." He expressed his concern with getting "stuck with the bill from SOA. After two days of 'phone tag' between the dealers and myself, the RI dealer agreed to work on the car. The dealer called me three days later telling me to bring my car in for service. It had already been there for days! I call three days after that to ask about the progress being made on the car. The service advisor responded that they STILL hadn't looked at it b/c their transmission technician was 'out for a few days.'
I receive a call today from the service manager, 2 weeks later, indicating that due to:
1. my turboback exhaust, and..
2. bent shift forks and worn transmission parts.
..that my car would NOT be covered under warranty. I explained that I had not abused the car. I explained that worn parts most likely would be due to four days of heat and friction from not having any fluid in the transmission. He indicated that it was not his problem, and again stated "see, this is why I didn't want to be '3rd party' to all of this." He made it clear when I first brought my car in, that he was wary about doing the work---now they are trying to find every excuse...NOT TO DO IT.
This is my third transmission problem with this car.
(1) 3 months after purchase: clutch replaced under warranty due to 'shudder.'
(2) 6 months after purchase: synchro gears, and main shaft replaced , under warranty, due to dealer confirmed 'defect.'
nearly one full year passes with NO problems from the car...none
(3) 20 months after purchase transmission service denied due to 'abuse,' and 'modification,' despite records showing blatant NEGLIGENCE from Subaru.
I will NEVER buy a Subaru again...
SoLiDbReAkZ is offline   Reply With Quote
Old 09-03-2003, 11:08 PM   #96
t_wrexxx
Member#: 42790
2002 Bugeye
Make: 2002 Impreza WRX Sedan
Mileage: 29000
Time out of use: Approx 30 days
Problem and likely cause: Broken 2nd gear; Dealer installed faulty clutch into car.
Power modifications: Cold air intake, Catback exhaust, Boost controller @ 14.5psi, Blow off valve.
Submitted for warranty work: Yes, originally for clutch shudder, and then for trans.
Reason given for denial: Abuse, and mods to car.
Your story:
I took my car to Colonial Volkswagen/Subaru in Feasterville, PA to have the new clutch/flywheel assembly installed due to shudder. I dropped the car off at the dealer, and returned 2 days later to pick it up but could not take it because the clutch was not bled properly. I returned the next day, and the clutch was still not bled properly. The tech took the car and re-bled the clutch for the third time. I left the dealership and noticed as I was pulling away that the clutch was chattering from a standstill, and when shifting into any gear. I returned to the dealer 5 minutes later to explain the problem. The tech took the car for a drive, and agreed that the clutch was indeed chattering when trying to engage any gear. I was told that there could be a "defect in the material" and that it could wear itself out in a few days. They even went so far as to say that "it may have been dropped at the warehouse." I was told that it was "probably" a bump in the friction material and to take the car for a week to see if it went away. I took the car (Stupid.) As the week progressed, the problem got worse. The chattering changed to shuddering. The car would pop out of gear while cruising along. I would go to pull away from a stop and the clutch pedal would stay on the floor, but would then pop out by itself. This happened many times at a traffic light, and the clutch would pop out while I was in gear causing my tires to audibly 'chirp' from the sudden engagement before the engine stalled out. So a week later, I call the dealer and tell them that the problem is getting worse, and that they would have to order new parts. I am blown off by the service writer, and was told he would call me after he checked availability. Over the weekend, I was driving my car, and while shifting from 1st to 2nd I go to let out the clutch but once again it stays on the floor. It then popped out by itself again causing the car to jerk violently as it tried to engage gear. Second gear was toast. I could not engage the gear and the trans now grinded going into first and third, and would not engage second at all. I had the car towed to the dealer, and after 10 days of waiting was finally informed that the transmission was "not a warranty issue" and that they would not repair my car. I was told that the transmission failure was a result of abuse and the mods to my vehicle when in fact I was being very careful with my car because of the problematic clutch when the trans failed.
t_wrexxx is offline   Reply With Quote
Old 09-08-2003, 11:51 PM   #97
neversatisfied
Member#: 42631
03 Subaru WRX
Silver T67 equipped
Default Re: Trouble/Warranty Denial Report Thread: Drivetrain (Engine, Tranny, Diff, Etc.)
Name:Allan Bargenquast
Make:03 WRX
Mileage: 4,200
Time Out Of Use: 1.5 months
Problem And Likely Cause: 2nd gear discinegrated, 1st gear discinegrated, 1st gear syncros, problems getting into reverse, total of about 55 pieces in the tranny were broken.
Modifications: 0 when taken into dealership
Your Story: Getting on the interstate in 1st gear. Shifted into 2nd gear at about 5,000 rpms, when I let off the clutch I heard a loud boom sound. I pulled the car off to the side of interstate because tranny was messed up and it sounded like I was dragging something. Whenever the car was running it made a horrible spinning sound. Dropped the car off in the key drop on a Thursday night. Dealership left me a message, but I didnt get it until the weekend. Called them on Monday and talked with service manager which had just cracked the tranny open and made a list of all the parts that needed replaced. All parts were ordered before I had even talked to the dealership. Subaru has definitely treated me well (except for the dealership I bought it from) and I cant wait to get my car back and running again.
neversatisfied is offline   Reply With Quote
Old 09-09-2003, 12:42 PM   #98
Irish
Member#: 23421
2005 WRX Wagon
Dead Hooker Black
Make: 2002 WRX
Mileage 19,000
Mods: TBE
Time out of use:7 days and counting
Submitted for Warranty work: yes
Denied/Approved: 70/30...currently
Reason for Denial: Clutch is discolored and abused...
At 17,900 miles on June 26th, I brought my car in for a clutch replacement for the "Clutch Shudder" issue. Replaced under warranty.
Upon leaving the dealership I proceed to stall the car at 3 consecutive stoplights. The clutch engages HARD. Almost like an unsprung clutch. I assume it is a new clutch and needs to be broken in.
Two months go by and the problem progressively worsens, my wife will not drive the car. The clutch engages instantly, I have to leave stoplights at 3000 rpm to keep the car from stalling and I begin to hear something rattling upon startup. I begin to commute in my 1951 chevy until I have a free day to bring the car in (I work about 75-85 hrs per week).
Tues sept 2nd, Alternator goes out on my Chevy and I have to drive the WRX. At this point the car has 18,900 miles and the car has been driven about only 1000 miles in the past 70 days. Due to how terribly the car has been running. Most of the miles have been put on going to get parts for my Chevy to keep it running.
Pull out of my neighborhood, Gingerly pull second gear at about 20mph, roll on to about 50% throttle and the transmission makes a frightening sound and the gearshift rifles out of my hand and the clutch jams to the floor. I can not shift into any gears, especially 1st and 2nd, 3rd-5th and reverse can be had, as long as the car is not running.
I have the car Flatbedded to Flarirons Subaru, where the transmission is pulled from the car. The clutch fell out before the transmission was removed due to the fact that it was in pieces. The transmission fluid contains some metal, (bad first gear synchro anyone?) but there are no gear teeth to be found....
The faceplate of the clutch looks virtually brand new and the flywheel looks it just was pulled out of the box. The metal portion of the clutch is rainbowed from heat, however I dont feel that is out of the ordinary for clutches, however, this is currently the reason for denial.
They call me ad tell me that SOA is willing to do a 70/30 split for the cost of the repairs...Which will probably include a new transmission, with the 70% being my burden, due to abuse!? They are going to open up the transmission today and tell me the situation. If the gears are sheared I am screwed, they will not cover anything except the clutch. Which they admit was probably faulty...I will be going up there to fight with the service rep today about the transmission.. I don't understand how a faulty clutch causing my transmission to break is my fault.
I think this thread is long enoug at this point....Class Action anyone? There HAS to be a lawyer out there that will take this one on.
This car is worse than my DSM was.
I thought it was a POS.....
Irish is offline   Reply With Quote
Old 09-09-2003, 04:17 PM   #99
Blknblu
Member#: 29188
2000 Ducati M900
I hear you Tim. I think this thing has gotten big enough to proceed w/ legal action. We aren't asking for the world just for SOA to admit that put a pos tranny in a car that needed one that was twice as strong. The fact that unmodified cars are having issues with them should be a freakin red flag that something is wrong!! I think they will lose market share to other manufacturers untill they fess up and fix them and design stronger transmissions. I praised subaru and was an advocate of them to friends and others looking for a new car. Not now. Hell the tranny on my wifes 01 Outback is starting to act up!!! Pure, unadulterated... bull crap
Old 09-09-2003, 05:11 PM   #100
Irish
Member#: 23421
2005 WRX Wagon
Dead Hooker Black
UPDATE:
Just got off of the phone with Dustin at Flatirons Subaru in Boulder CO. Apparently the transmission has a broken second gear. However, They are going to HONOR the warranty and replace everything.
It almost felt like I won the lottery for just having a car company doing what they are supposed to do. I know for a fact that both Dustin and Bret at Flatirons must have pulled really hard for me to get SOA to do this. Thanks Guys.
I guess that there are 100 voided warranties for every 1 repair. It just proves not all dealerships are crappy.
Trouble/Warranty Denial Report Thread: Interior North Ursalia Warranty Issues & SOA Problems 71 11-14-2018 09:18 AM
Trouble/Warranty Denial Report Thread: Body/Exterior of Vehicle North Ursalia Warranty Issues & SOA Problems 145 11-06-2018 05:49 AM
Trouble/Warranty Denial Report Thread: Electrical (Lighting, ECU, Sensors, Etc.) North Ursalia Warranty Issues & SOA Problems 133 09-20-2018 06:23 PM
Trouble/Warranty Denial Report Thread: Suspension North Ursalia Warranty Issues & SOA Problems 56 03-22-2018 12:09 AM
Trouble/Warranty Denial Report Thread: Braking System North Ursalia Warranty Issues & SOA Problems 94 11-23-2016 06:27 PM
