Welcome to the North American Subaru Impreza Owners Club Monday June 18, 2018
Go Back   NASIOC > NASIOC Technical > Normally Aspirated with bolt-on Forced Induction Powertrain
Old 10-08-2001, 04:00 PM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Thumbs down This just keep getting worse!
Finally had a chance to look at the piston a little closer because I raised the engine and this is what I saw that I had previously missed
That also means that the turbo is also gone. what do you think?
Eric
Eric SS is offline   Reply With Quote
Old 10-08-2001, 04:07 PM   #2
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Which piston is this one? Still #4, B? Or is this a different one? If you're lucky, the turbo should still be fine. Hopefully the whole chunk didn't break off all at once.
I presume this is an EJ25 piston, despite what your tag says about a 2.2L?
-WaC
Wayne
wac is offline   Reply With Quote
Old 10-08-2001, 04:09 PM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Yeah sorry. it is still the #4B piston from my EJ25
Eric
Old 10-08-2001, 04:25 PM   #4
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Hmm.. upper right hand corner of the number 4 piston.. and it's a "B". Interesting... I have five others that look just like it. From what I've seen, these pistons are brekaing apart in small pieces. There was no damage to my turbine blades on the turbo. Maybe you got lucky and will see the same thing.
Fitz
Fitz is offline   Reply With Quote
Old 10-08-2001, 06:29 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Have you checked the turbo? Very possibly, the material that broke off has melted away to nothing before it had a chance to screw up the turbo. I believe mine finally got screwed up only after an inch or so of the top ring broke off and got caught in between the turbine and the housing while it was trying to spool up (SKREEEEEEEEE!!!!). What a painful noise.
8Complex is offline   Reply With Quote
Old 10-08-2001, 07:27 PM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Ihaven't checked the Turbo yet. I was trying to but that passenger rear up-pipe to turbo flange bolt is arguale the hardest bolt to get to on the whole setup. I finally stopped so I wouldn;t start throwing tools around. I'll try again later
Eric
my luck just keeps getting worse. DraconisWRX Rocky Mountains Impreza Club Forum -- RMIC 13 01-21-2009 07:13 PM
Monday Nite Football keeps getting Worse because of Cornhole!!!!! AliBenn Off-Topic 33 10-03-2007 08:31 AM
My luck just keeps getting worse. WRmotoX Tri-State Area Forum 3 07-27-2003 03:05 AM
They just keep getting funnier looking. Red-Impreza South West Impreza Club Forum -- SWIC 5 04-13-2001 10:42 PM
OT: It just keeps getting worse for Ford, and then some... BigElm General Forum Archive 11 09-01-2000 12:17 AM
