Welcome to the North American Subaru Impreza Owners Club Friday September 21, 2018
Old 10-07-2002, 04:35 PM   #1
jfalcon001
Member#: 23062
2002 Impreza WRX
Default Replace stock EGT probe with a aftermarket probe?
Is it possible to replace the stock egt probe, in the up-pipe, with a new thermocouple from an aftermarket EGT gauge? If so how difficult would this be to do? I know normal instructions say to tap the manifold... just looking for other options.
Thanks
Justin
jfalcon001 is offline   Reply With Quote
Old 10-09-2002, 04:20 PM   #2
jfalcon001
Member#: 23062
2002 Impreza WRX
Come on... no one has even thought about this? Or are you guys just being shy?
Old 10-09-2002, 06:48 PM   #3
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
I imagine it would be possible, but you would lose your Subaru thermocouple in the process probably causing a CEL. More importantly though, is that you want to measure EGTs as close to the exhaust as possible, so you would be much better to tap the manifold off of the last cylinder on the fuel rail (someone else can confirm where this is, but I think it's passenger side front cylinder.) The last cylinder on the fuel rail is the most likely to go lean therefore the most likely to see the highest EGTs.
If you have your EGT gauge reading from the up-pipe you'll have no way of actually knowing what the exhaust gas temperature is and you'll have no way of comapring your numbers to other members of i-club.
Most mechanics can tap the manifold for you for a few bucks, just make sure that you tap somewhere so that the EGT probe will be in an acceptable location when you reattach the manifold. For example, don't tap the "top" of the exhaust manifold otherwise the EGT probe won't fit in the space betwwen the exhaust manifold and the engine, you need a few inches of clearance.
Corn-Picker is offline   Reply With Quote
Old 10-09-2002, 08:02 PM   #4
fastburro
Member#: 10503
02 WRX wagon
black
Not really practical. The Subaru sensor is NOT a thermocouple. It is a very nonlinear thermistor type sensor, and putting a standard thermocouple into the ECU would make it think the EGT's were more than 1700F!
Hope this helps
Mark
fastburro is offline   Reply With Quote
Bolt to replace stock EGT probe? DinoGuan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-05-2006 01:12 AM
Stock EGT sensor...same as aftermarket??? subieworx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-27-2006 02:42 PM
stock EGT work with Autometer Pyro? maxitout77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-26-2006 09:32 PM
Anyone replace stock WRX speakers with 6.5" components? Heather Car Audio, Video & Security 26 07-03-2003 07:13 PM
Replacing stock EGT sensor. gusman21 Tri-State Area Forum 6 03-31-2002 02:24 PM
