10-12-2007, 03:14 AM | #26 |
Member#: 102749
SCIC
Vehicle:2005 impreza STi OBP' |
10-16-2007, 05:33 PM | #27 |
Member#: 62555
SCIC
Vehicle:1993 FD3S E92 / CBR600RR |
Yay for ppl who don't know anything.
10-16-2007, 06:16 PM | #28 |
Member#: 13680
Vehicle:2002 WRX WRB |
I'll start by saying that I have an obvious bias in this area because I make these aftermarket controllers...with that said....
It's not a good idea to run with direct power to your dccd coil for any length of time. 12v or 6v won't make any difference except in terms of amperage, it will heat up and burn out the solenoid in a short period of time. Describing it as a 6-7 volts signal is a "dumbed down" way to explain it to the techs/mechanics so they can check it with a multimeter instead of a scope. The signal is PWM so 6-7 volts is probably close enough to the signal RMS. I have suggested it in the past to people to run a switch with tons of caveats. It is ok for limited dyno or occasional use for a few minutes if you are stuck or something like that. |
10-16-2007, 06:31 PM | #29 | |
Member#: 10268
SCIC
Vehicle:gc8 I ride ride 24s with the top down low. |
10-16-2007, 11:11 PM | #30 |
Member#: 102749
SCIC
10-17-2007, 01:33 AM | #31 |
Member#: 8785
SWIC
Vehicle:02 c_turner@ix. netcom.com |
COrrect. The input voltage to the clutch coil is RMS voltage. Its pulsed. Hooking direct current to it will fry it. I have seen this first hand by a guy hooking 12 to the coil. It fried the DCCD diff in a short time and had to be replaced.
Clark |
10-17-2007, 01:17 PM | #32 |
Member#: 10268
SCIC
thanks clark, its good to hear that you've had first hand experience with this. hopefully when someone searches this idea later on they will run across this thread with the definate "do not do it" answer, and not 'pull up your ebrake to make your dccd work' lol
10-05-2019, 02:22 PM | #33 | |
Member#: 42215
Vehicle:2002 WRX being built and going for 10s :evil: |
However, I was tempted to just run full ebrake... |
Anyone else sick right now? | rogue | Off-Topic | 55 | 12-13-2011 07:07 PM |
Anyone running this on their RS? | 93subi | Engine Management & Tuning | 4 | 08-05-2008 01:29 PM |
Anyone watching D1 right now on Speed? | MattDell | Off-Topic | 14 | 03-19-2006 02:35 AM |
Anyone at CDIS right now?(Thu. 12:17pm) | popnGEAR | Vancouver Impreza Club Forum -- VIC | 0 | 10-17-2002 03:20 PM |
I'm Eating This Right Now | Ferg | Off-Topic | 19 | 10-03-2002 07:12 PM |
