11-25-2017, 01:09 PM | #1 |
Member#: 429701
Vehicle:2002 Impreza WRX Grey |
Center diff gone bad? (video)
Hi there, the symptons make me believe this is a faulty center diff, i just need your oppinion to be sure.
The car is a 2002 wrx 5mt: When cold, no noise or car stutter. 15 minutes or normal driving, the geartrain gets warm, and then on tight turns the car makes this noise, and you can actually feel the car "braking" upon each "click", like going through small lumps. Thanks in advance.
11-27-2017, 10:09 PM | #2 |
Member#: 478371
Sure doesn't sound good. I'd say if you've already checked your CV joints for clicking, that theres a good chance its your center diff...
11-27-2017, 10:13 PM | #3 |
Member#: 429701
Yup...CV joints have a different sound when they go bad, and happens on cold too. This really seems a center diff.
Meanwhile i found out my gearbox is from a GT Classic... Subarus and their "fit-to-all" parts are suprise boxes, live and learn... |
11-27-2017, 11:01 PM | #4 |
Member#: 333468
RMIC
Vehicle:93 SS - 06 OB XT 03 WRB GD 205/22T 20G-XT |
Sounds like my center diff when it went out. Mine popped and clicked in turns. The snap ring came loose and destroyed some gears. Sounded like this when I went straight:
I bought a JDM 5MT w/4.444 FD from JDM racing motors for $1100 shipped and swapped it in. I love the gearing much better than the USDM 5MT. Replacing the center diff would have been more than buying the JDM 5MT. |
11-28-2017, 10:01 AM | #5 |
Member#: 429701
You replaced the gearbox only? Your rear diff was 4.44?
11-28-2017, 12:02 PM | #6 |
Member#: 375462
NWIC
Vehicle:2006 Impreza WRX STI WR Blue |
You likely have a broken gear pair - that's exactly what mine sounded like.
So... full stop - no more driving this car unless you want it to get a LOT more expensive really quickly. Place the car on 4 jack stands, run it in as listed below and record the RPM (post the video). I should be able to run the audio through GoldWave and tell you which pair is bad... but you'll be opening the case regardless. Do the following until you hear the noise, then log and record it: 1. Rev in neutral, clutch DISENGAGED. 2. Run in neutral, clutch engaged. 3. Run through gears, clutch engaged - stop at the lowest gear that makes the tick. Make absolutely sure your jack stands are up to snuff... for obvious reasons - 3rd-4th-5th will be bogging the engine as you get it into gear and even at idling, the wheel speeds will be high. If you've got the balls to do it, once it starts ticking you can get under the car and pinpoint the EXACT location (fore to aft) on the transmission casing the noise is coming from. This will help separate the transfer gear from gear cluster in terms of diagnosis. |
11-28-2017, 02:45 PM | #7 |
Member#: 429701
mrsaturn7085, why wouldnīt it make on cold then? Yourīs only did it after warming up too?
11-28-2017, 05:54 PM | #8 |
Member#: 175624
Vehicle:0304 WRX WRX SY WRB |
It sounds like diff to me. Especially since there is no noise when cold.
11-28-2017, 10:19 PM | #9 |
Member#: 333468
RMIC
No, I replaced the rear diff as well. It was included with the transmission.
When I was diagnosing the broken trans I drained it and the gear oil was black, even though I had put new gear oil in it a few months earlier. A gear in the center diff was broken. For fun I split the case and everything else looked to be in good shape. Since I was getting a new trans I just threw it all away. If I were you I would just order a JDM trans from ebay and call it a day. |
11-29-2017, 10:06 PM | #10 |
Member#: 403329
Vehicle:2003 wrx stage 3 |
Sounds exactly like mine, I've got it apart, picking up bearings tomorrow and will assemble and have it back in with a replacement differential this weekend. I agree that it's your diff as busted gear pairs should be noisy when cold I would think.
Pretty easy transmissions to work on, took me 2 hours to get the tranny out, another few casual hours to open and assess how much money I want to spend.. And then double time to put it all back! All in it cost me 250 for the diff and 300$ to do transfer bearings, seals, input bearing and 5th gear bearing which I suspect is the source of an annoying bearing noise at idle which goes away when I disengage the clutch. I'll report back when I confirm it was that diff! |
11-29-2017, 10:53 PM | #11 |
Member#: 467167
NWIC
Vehicle:2002 Impreza WRX |
Hey Ruedorb .....
The input bearing you mention is for the input shaft ? Is it a sealed-bearing ? Ring and Pinion bearings looked good ? I'm asking because I need to pull my transmission and split it to see what is the cause of my Grumbling. Good luck on your re-furb ! Len |
11-30-2017, 12:37 PM | #12 |
Member#: 375462
NWIC
Mine did it cold, but the noise was identical - in either case, it is the sound of a tooth being off. Whether it's the transfer gearing or the actual gear cluster, the pinging noise is the sound of the ratio changing as a tooth being off will alter the ratio at this point. You would be shocked at how small of a bend is needed on a tooth to cause this much noise; these two photos show the damage to my gears that caused this noise - most people can't even see the damage in the pictures:
And this is the audio analysis that told me which gears to inspect: |
12-02-2017, 06:27 PM | #13 |
Member#: 403329
Thanks Greaser,
Looks like im delayed another few days. I think I can confirm my whirling noise at idle was my 5th gear needle bearing. I replaced the race and bearing, but found the gears pressed in inner race to be toast. Looks like this race cannot be replaced, so i need to find another gear. Have a look at the pic below, you can feel the grooves seen. https://drive.google.com/file/d/1p9J...ew?usp=sharing As for the ring and pinion bearings, i just left them. But Maybe i should change them, but they look and feel fine. I'll let you know about the diff when it gets back in, i still have high hopes that it was my problem. Last edited by ruedorb; 12-02-2017 at 06:39 PM. |
12-04-2017, 08:39 PM | #14 |
Member#: 429701
mrsaturn7085 i can see those bends for sure, but i guess that would make the noise even on a straight line, wouldnīt it? Not my case, mine does that in every gear including reverse. Speed just makes it less perceptive.
ruedorb letīs see that diff Iīm waiting for a phonecall from the shop to make 500 miles and go change it...poor country this one... |
12-14-2017, 08:52 PM | #15 |
Member#: 429701
Well, center diff was replaced and problem is gone
12-18-2017, 01:55 PM | #16 |
Member#: 403329
Sorry for the delay, just got my car back on the road Saturday, I was delayed waiting for other unrelated parts. My clunking was also fixed by replacing the c diff. With regards to seeing the old one, it looked perfect, but I assume the viscous fluid was lost, which turned my oil dark brown. Anyway, this ones done!
12-18-2017, 06:43 PM | #17 |
Member#: 177235
NWIC
Vehicle:2016 Focus RS 2002 WRX Wagon |
Where'd you get your parts?
12-18-2017, 07:12 PM | #18 |
Member#: 403329
12-19-2017, 06:40 AM | #19 |
Member#: 403329
[quote=samb;45466671]Where'd you get your parts?[/qu
12-25-2017, 06:20 PM | #20 |
Member#: 479658
Center diff also bad
Hello new to the site and just had a question about the center diff. Mine is a 04 wrx m/t. I bought a used tranny for parts and when i removed the cover from the center diff there were small peices of what looked like a washer. Just wondering if the used center diff is bad. Thanks in advance did not want to start a new thread when this one was on the same subject.
12-25-2017, 06:29 PM | #21 |
Member#: 220971
South East
Vehicle:2004 Impreza |
Usually the snap ring that usually breaks.
12-25-2017, 07:19 PM | #22 |
Member#: 479658
Thanks for the reply. The snap ring looks like its still in its spot dosent look broken. Some of the pieces look thicker some almost the thicknes of a quarter.
12-25-2017, 07:28 PM | #23 |
Member#: 479658
12-25-2017, 07:58 PM | #24 |
Member#: 220971
South East
Ooooo not good
12-25-2017, 08:42 PM | #25 |
Member#: 479658
Thanks for the reply. So differential is toast?
