12-25-2009, 10:38 PM | #26 | ||||
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
Rallispec told him that his reving ability is limited to 7200rpm by using the stock heads. and that is not true
12-25-2009, 10:51 PM | #27 |
Member#: 99397
RMIC
Vehicle:15 WRX, 83 DR30, 93 R32 GTS-T, 93 R32 GTR |
That is just what was recommended.
12-25-2009, 11:56 PM | #28 |
Member#: 75234
Vehicle:2004 WRX Wagon with 07 STI 6-Speed Goodness! |
That's a great looking block for the money! When mine finally bites the dust, I'll be giving that one a hard look!
12-26-2009, 04:07 AM | #29 |
Member#: 93033
International
Vehicle:- SG5 & GVF |
Can anyone chime in regarding their specs:
1. They use 4130 steel H-beam conrods, while most of the aftermarket conrods use 4340 steel. Any differences? 2. Regarding their 'uprated main and rod bearings', is it Cosworth or ACL? Thanks. Last edited by Pecosdude; 12-26-2009 at 09:51 AM. |
12-26-2009, 09:45 AM | #30 |
Member#: 99397
RMIC
I am pretty sure the Eagle rods are 4130.
12-26-2009, 05:08 PM | #31 |
Member#: 113924
NESIC
Vehicle:2005 STI....SOLD! 93 RX7...Not Broken |
i think my engine will be meeting an early grave at some point in the not too distant future, this is looking like a great replacement. anyone have anymore info on it?
12-27-2009, 03:28 PM | #32 |
Member#: 45702
I am glad to hear all the positive comments. We've been in the business of Subaru performance modification for over 10 years now and bring a lot of experience and knowledge to the table.
I would like to comment on a few things to perhaps clarify or enlighten: The rods used in this motor are 4340. The website info is a typo. The rods are produced for us by Manley. It is an economical performance rod good to about 600bhp. Similar to Eagle, K1, and many others. Chinese forging that is machined in-house at Manley. We've used about 50 sets of these rods and never seen an issue. The quality control is very good. The crankshaft is not dynamically balanced. This is the only way to keep the cost what it is. The parts are closely weight matched. The horizontally opposed motors are such that this is 90% of what you need to achieve a good balance. We are marketing this shortblock as a street specification shortblock...basically a way for people to gain the reliability they need on their modified street cars without breaking the bank. It is felt that we cannot justify the cost of the crankshaft balancing for this type of application. However, we can balance the crank as an option but it raises the cost by $450. All of our race spec blocks are dynamically balanced as standard because we feel those motors will be spending a lot of time at high rpm and achieving a perfect balance is more critical. They are balanced to 1/4 gram which is about the limit of the resolution on most of the current balancing equipment that shops are using. With regards to high compression....yes 9.2:1 is an option and we can build the street spec shortblock with this CR by special order. However, i would advise against running this CR on pump fuel. I would suggest running a thicker head gasket to bring the CR down to something in the 8.7 range or below. I've tuned cars running this 8.7:1 on 93 octane and compromises had to be made to keep it out of det but I still felt it was acceptable. I think beyond that then the compromises you have to make are going to cause reliability issues long term. With regards to max revs.... there are many factors involved. These include, but are not limited to: valvetrain inertia (valve float), valvetrain harmonics (valvespring failure), bearing loads (crankshaft imbalance), connecting rod inertial loads (either rod failure or more commonly big end bearing failure), oil supply issues. Addionally there is the issue of volumetric efficiency dropping off. If your engine is not built to make decent power above 7000rpm there is no reason to spin the engine to 8000rpm or even 7500rpm (unless you are in a situation where you a few extra rpms helps avoid an unecessary gear shift). The stock ports, valve sizing, and cam profile will not flow sufficently well with a 2.5L displacement to make reving the engine beyond 7000rpm even worthwhile in most cases. And sure you may be able to spin the stock valvetrain to 8000rpm on occasion but how accurately are the valves following the cam profile and just how close are you to the resonant frequency of the valve spring. If you don't know these things you probably shouldn't be advocating it. The issues with max revs as it relates to the street spec shortblock we sell have to do mainly with the oil supply to the rod bearings. Please keep in mind that the crankshaft is stock. Additionally, the lower cost rod does not have sufficient rod cap rigidity to maintain its shape under the loads experienced at very high rpm. If you are looking to run the engine at 8000rpm or more for any regular period of time I strongly suggest you look at one of our other shortblock options (or ask us to build something custom tailored to your requirements). And lastly...yes, Jodie does a great job for the company. He builds many of the transmissions and some of the engines. I work very closely with everyone I hire to make sure they have the knowledge and skills necessary to produce the best quality finished product before they touch anything that comes out of my shop. Whether it is built by myself, Jodie, or anyone else that works at RalliSpec you can be sure it was built to the highest possible standards. |
12-27-2009, 03:48 PM | #33 | |
Member#: 18602
Vehicle:2005 Moller Skycar glow in dark purple |
i have a 2003 WRX. what i want to end up with is basically a hybrid. i dont care about spinning above 7000 rpm. and i would like to keep the compression ratio around stock or at the very most, no more than 8.5:1. i plan to run it with the OEM ECU + APv2. i want to keep my OEM sensors etc etc.. lets say crank hp 400 to 450 (unless you would recommend something else). probably a stock location turbo, probably EWG. car is street driven. no tracking, no autocross. it might see an eventual 1/4 mile just to see what it can don et wize.. my biggest confusion more or less up to now is what are the options/prices etc for using my heads (or something offered by an engine builder). the block thing is easy more or less. but finding a properly matched head setup that works with my ECU and sensors is less so. i do not want to slap my WRX heads on a 2.5 and then rely on a tuner's ability to tune around the short comings of such a set up. what i would really like would be a full 'street longblock' that i could just replace my engine with.. so what do you offer in this category? |
12-28-2009, 12:18 PM | #34 |
Member#: 45702
If you are wishing to build a hybrid (2.0L heads with 2.5L block) then you will want to run a head gasket thickness of 1.1mm to bring the compression ratio back down close to the standard ratio of 8.2:1. This assumes the heads have not been resurfaced.
In terms of building a long block....yes, this is no problem. However, people have many different opinions on exactly what a long block is. So you would need to clarify exactly what parts you wanted supplied. For example, Cosworth and some other companies define their long blocks as basically a shortblock with heads, cams, valve covers, and oil pump. Subaru defines a long block as essentially a complete engine. Most long blocks that we build here are somewhere in between and usually consist of shortblock with complete heads, water pump, timing gears & belt, covers, oil pickup and oil pan. No intake or exhaust manifolds and no coolant piping. My best suggestion is to build the long block using JDM Ver.5/6 heads with aftermarket valvetrain parts. These are non-AVCS heads with big ports that flow well without any modification. We built this type of motor for X Games rally competition in Matthew Johnson's car. We ran a high compression ratio because we were running race fuel. Combined with a Garrett GT3071 the thing was blisteringly quick (quicker than most of the competition on the straights) until he put the car into the wall during practice and destroyed the motor. For the type of application/power levels you are talking about this would be the ideal solution. Sometimes we have used low mileage heads of this type available. Send me an email ([email protected]) and we can discuss pricing. |
12-28-2009, 12:26 PM | #35 |
Member#: 99397
RMIC
Thanks for all the info Dave. Ill be ordering my short block today!
12-28-2009, 01:02 PM | #36 |
Member#: 165611
Dave,
I have an '07 Sti and want to put in a built longblock, I have another longblock just sitting there as a replacement but it is from an '06 sti, is it just basically the same? (heads etc) if I were to send the 06 motor to have it bulit and then swap it and use the '07 's manifold injectors etc. |
12-28-2009, 05:03 PM | #37 |
Member#: 99397
RMIC
The 06 heads are different form 07. Your 07 heads have the ports for the air pump, which you dont need if you want to get rid of the air pump.
12-28-2009, 08:05 PM | #38 | |
Member#: 18602
12-28-2009, 08:41 PM | #39 |
Member#: 165611
is that air pump really needed?
12-28-2009, 08:50 PM | #40 |
Member#: 114631
Vehicle:2009 GTR, 735whp 13' Benz, 15' WRX |
12-28-2009, 09:17 PM | #41 |
Member#: 71460
Vehicle:2007 STi Limited |
Cosworth makes a nice delete plate for about $70.
12-28-2009, 09:47 PM | #42 |
Member#: 117384
Vehicle:2003 WRX sonic |
some good info in this thread.... gotta look into rallispec's blocks!
12-28-2009, 09:49 PM | #43 | |
Member#: 99397
RMIC
Ive had no issues with mine being deleted so far. Plus, it cleans up the engine bay. PS: Rallispec block is ordered |
12-29-2009, 07:04 AM | #44 |
Member#: 75234
12-29-2009, 08:56 AM | #45 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
I added this thread to my "links" thread stickied at the top of this forum.
I always appreciate it when someone gives good information on their product to communicate to the masses. Thanks Dave/Jodie. Ryan |
01-29-2010, 03:52 PM | #46 |
Member#: 99397
RMIC
Well I got the block and had it installed by Solid Autoworks. So far ive only got roughly 100 miles on it. But I can say that the motor sounds like stock. No slapping pistons etc. Very quiet. So far I am very happy with it.
The Rallispec block includes: Brand new 704 engine casing Cosworth 8.2:1 CR pistons (they have a 9.2:1 option as well) ACL/ Cosworth bearings Manley H beam conrods ARP rod bolts Last edited by bhhamblin; 08-12-2010 at 02:30 AM. |
01-30-2010, 10:25 AM | #47 |
Member#: 95840
NWIC
Interesting that they didn't use the new Nitrided crank.
01-30-2010, 12:02 PM | #48 |
Member#: 103399
E. Canada
Vehicle:2009 Stripped STI Dirty White |
Pretty sure they do in their street SB for $3000...
02-01-2010, 03:30 PM | #49 | |
Member#: 205427
Vehicle:2000 RSTI w/ hta68 Army Green |
I have V5 heads that i am holding on to for a build down the road and was curious how you tackled the wiring and what manifold did you use Dave? |
02-01-2010, 03:57 PM | #50 |
Member#: 150986
Vehicle:06 #001 LSB STi |
Jodie and Dave really know what they are doing, and there really is no one other then them who I would trust working on my baby. For the price you cant beat the Rallispec "street spec" block, let along the knowledge they have. I couldnt be any happier with the job they did with my car last spring, if it wasnt for my huge cams you wouldnt have a clue it was a built motor its so quite. Now since were all posting pics Ive got a few that I might as well share when Jodie built my longblock.
-Gary Last edited by 06njsti; 02-01-2010 at 04:07 PM. |
Rallispec Street Spec EJ257 | obrut | Car Part Reviews | 9 | 11-21-2012 12:16 PM |
swaping a u.s spec to jdm | unclewolf82 | Subaru Conversions | 7 | 06-06-2010 10:52 AM |
JDM STI V7 shortblock VS JDM STI V7 Spec C shortblock | Lam | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 02-16-2008 04:26 AM |
attn:paulg...rallispec alignment specs? | shuman | New England Impreza Club Forum -- NESIC | 1 | 02-28-2001 09:49 AM |
Question for the Subaru engine builders: Cobb Tuning, B Spec USA, Rallispec, et al. | Digital_Boy | Normally Aspirated Powertrain | 0 | 01-31-2001 03:13 AM |
