04-29-2009, 12:22 AM | #1 |
Member#: 65711
Vehicle:2004 WRB WRX Wagon 2.5 Hybrid STI Conversion |
5mt to 6mt USDM WRX Wagon Swap Help!
I also posted this in the transmission forum, I don't know which is more correct. I'm doing the 6mt swap into my 04 WRX wagon. I had gotten a rear diff off a turbo legacy (told it was 3.9) and then bought a supposed 4EAT driveshaft off ebay out of a totaled 04 wrx wagon. Axels didn't hook up to the rear diff so I had the guts swapped to the R160. Got this note tonight from my buddy at the shop:
"After setting up the WRX differential in the case with the 3.9 gear pinion, spending two hours getting the correct gear lash and bearing clearance.....then installing it. The driveshaft you provided does not fit, its most likely something wrong with the rear. The problem is the rear flange has holes in a rectangle with the dimensions of: 44mm x 53mm The driveshaft has square dimensions of: 53mm x 53mm The dimensions are approximate (+_ 0.3mm), center to center. Unfortunately, it's not as easy as just changing the flange. With most cars there is a crush collar on the pinion side of the rear end that needs to be changed and setup when changing the flange or any bearing on the pinion side of the rear. This puts the proper amount of preload on the pinion bearing, too much and it vibrates apart, too little and it over heats and locks up. So; 1) the driveshaft is wrong and we need a new one. 2) the rear is wrong and we need a new one. " This of course is the last major obstacle in the build and makes me a super Anyone know the quickest, most effective way (both in cost and quality) to remedy this problem? Answers would be great, part numbers too. Parts List: '04 USDM 6mt '04 stock WRX wagon axles '9x Turbo Legacy 3.9 Rear '04 4EAT Driveshaft (what I was told is an auto driveshaft, has a square flange) '04 Stock 5mt Driveshaft (don't know which flange) 1/2 of a random manual Driveshaft that came with the 6mt (square flange) Aftermarket DCCD Controller Thanks a lot everyone! |
04-29-2009, 01:47 AM | #2 |
Member#: 119591
If the flange from your old diff is the same bolt pattern use it. As far as pre-load on pinion bearings just replacing the flange will not affect this, unless you go crazy with the impact gun.
04-29-2009, 02:20 AM | #3 |
Member#: 65711
I'll make sure to ask.
04-29-2009, 08:43 AM | #4 |
Member#: 65711
bump for 2nd opinions?
04-29-2009, 12:05 PM | #5 |
Member#: 65711
Bump for justice
04-30-2009, 12:49 AM | #6 |
Member#: 65711
issue resolved. thanks to those who replied.
Similar Threads | ||||
06 STI to 03 wrx wagon swap | kite_tmr | Subaru Conversions | 59 | 01-15-2019 11:51 AM |
Swap help! 5mt to 6mt | whatishe | Transmission (AT/MT) & Driveline | 10 | 04-30-2009 12:36 AM |
6MT into WRX wagon swap questions | bluescoobywagon | Transmission (AT/MT) & Driveline | 4 | 02-19-2006 08:53 PM |
5mt to 6mt help? | vvRX7 | Transmission (AT/MT) & Driveline | 33 | 11-30-2004 09:41 AM |
anyone done a USDM WRX motor swap into a RS? | ^jynx^ | Tri-State Area Forum | 15 | 01-02-2003 07:27 PM |
