12-09-2015, 11:26 PM | #8551 |
Member#: 104098
NWIC
Vehicle:97' LGT 2.3 Dstroke Rotated BW S256 6speed |
I have an 05' WRX swap, so it's the 2.0L manifold/rails. Is the factory regulator the limiting factor? Could I run a little more power if I go stock rails/lines with an aftermarket regulator?
Is the DW300 not a reliable pump, or does it just not flow enough?
12-09-2015, 11:35 PM | #8552 |
Member#: 73932
RMIC
Vehicle:2005 STi EFR 6758 04 S2000 EFR 7064 |
The regulator can handle that pump just fine.
12-10-2015, 07:59 AM | #8553 | |
Member#: 166005
Vehicle:2005 Saab 92x Beaten Silver |
I trust walboro makes a superior product compared to DW. |
12-10-2015, 01:40 PM | #8554 |
Member#: 104098
NWIC
Thanks! Exactly the info I was looking for.
So if I just want a solid 400hp/400tq, I don't have to hardwire the pump, and just let the fuel pump controller do its thing? So it looks like the plan is to leave stock rails, lines, regulator, and just add the ID1300's and drop in a big Walbro. And with that I might have a little headroom for a hair more? Sorry for all the questions. I'm getting ready to drop in my 2.3 Destroker with custom Piper cams, and might stick with the BW S256, or go with a smaller EFR Thanks for all the help! |
12-10-2015, 01:53 PM | #8555 |
Member#: 166005
I am running a 2.0 with 1k's and a 255. With a 20g and e85, my duty cycles at 12.0afr are around 90% at 7k in 4th gear on a 2004 6 speed. Most people would agree that is around 400whp on a dynojet.
1300's afford 30% more than 1000's. I know you have a better breathing motor and larger turbo, so I know you are capable of a lot more power. Basic math says 400x1.3 = 520. It is not perfect, but it is a decent place to start. |
12-11-2015, 11:44 AM | #8556 | |
Member#: 94097
Vehicle:2004 WRX Hybrid GT35 [email protected] |
12-11-2015, 02:34 PM | #8557 |
Member#: 104098
NWIC
Thanks for the info!
I think I'm going to run an aftermarket regulator so I can adjust base pressure if needed. It looks like the Walbro 450 is not a direct fit, and now I'm reading about all these heat issues from current draw, heating up the fuel etc., and some people hard wire, and others don't. |
12-11-2015, 02:36 PM | #8558 |
Member#: 73932
RMIC
You can only take adjusting the base fuel pressure so far if you don't back it up with a good fuel system.
I've been running a hardwired 450 for a couple years and though I haven't checked for "heat issues", I also haven't had a reason to. |
12-11-2015, 03:05 PM | #8559 | |
Member#: 220816
Vehicle:2018 Exotruck |
12-11-2015, 05:36 PM | #8560 |
Member#: 94097
Hardwire any aftermarket pump to use full benefits of it and save the hassle of a burn electric cycle regulator.
12-11-2015, 07:27 PM | #8561 | ||
Member#: 104098
NWIC
I assume you mean the Fuel Pump Controller? I'm definitely just going to hard wire it. |
12-11-2015, 07:45 PM | #8562 |
Member#: 166005
1300's and a hardwired pump will be maxed at 600# on a dynojet at #45 base pressure.
Get ready for 30#. Last edited by Zee Biker; 12-14-2015 at 05:22 PM. |
12-11-2015, 08:11 PM | #8563 |
Member#: 350332
South East
Vehicle:2004 Bone Stock* STi *with supporting mods |
You guys probably already know this, but some of us successfully do a hybrid hardwire of sorts. We hardwire the hot side the fuelpump (with a relay energized by the origional hot lead) and run an extra chassis ground to the ground wire on the fuel pump controller. This way you still get pwm (pulse width modulation) in the ground side, which effectively controls the pump, and doesn't run it wide open all of the time.
12-12-2015, 07:17 AM | #8564 |
Member#: 220816
so ethanol production is my only concern in the upcoming election
12-12-2015, 12:22 PM | #8565 | |
Member#: 94097
12-12-2015, 12:25 PM | #8566 | |
Member#: 94097
12-12-2015, 01:21 PM | #8567 | |
Member#: 350332
South East
I got it from a NASIOC thread: Thread: http://forums.nasioc.com/forums/show...382384&page=13 Last edited by dlapham; 12-12-2015 at 10:54 PM. |
12-13-2015, 12:07 AM | #8568 |
Member#: 94097
Oh nice. I did not have the extra ground.
12-14-2015, 01:24 PM | #8569 |
Member#: 97043
TXIC
Vehicle:08 STI 02 Z28 - project |
#6 says pump power but line shows pump ground?
And diagram shows #5 going to two chassis grounds? The rest of it makes sense. |
12-14-2015, 03:12 PM | #8570 |
Member#: 220816
lovely schematic. I'm gonna be 16bit swapping my SF here shortly. maybe i should hardwire my 255 like above. goals around 400wtq
12-14-2015, 03:52 PM | #8571 |
Member#: 220816
12-14-2015, 09:11 PM | #8572 |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! 2020 G70 3.3T RWD |
That's it?
12-15-2015, 07:24 AM | #8573 |
Member#: 220816
I got 18mpg stock on 87 octane with a n/a 2.5 making 165 at the crank. So i call it a win.
12-15-2015, 09:21 AM | #8574 |
Member#: 425346
South East
Vehicle:2003 WRX Caucasian |
EDIT: Found the answer to my question 3 pages back. Should have searched lol
12-15-2015, 09:57 PM | #8575 |
Member#: 436213
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
