01-18-2008, 11:42 PM | #1 |
Member#: 41853
Vehicle:2002 Impreza WRX RED |
Questions regarding Video Cards and TV Tuner Cards for Laptops
I am looking into buying a laptop and have narrowed it down to either a Dell XPS or a HP dv9700t. They both are very similar, but have a few differences.
I have done the searching and could not find anything to answer my questions on the internet and when I went to places like Best Buy and Comp USA, all the sales reps were puzzled by my questions, which surprised me because they seemed simple enough for a sales rep to answer. Maybe I don't understand enough to ask the question properly which would explain their confusion, so bear with me if I don't use the correct jargon. Video Card: HP is offering a 512 MB GeForce 8600M GS, and Dell is offering a 256 MB Geforce 8600GT. I understand the difference in the memory, but not the difference between the GT and GS. I think it has something to do with the "clocking" which I sort of understand. GS is the lowest setting and GT is the middle setting. Will the "GT" be a better choice do to the "GT" classification because if we were simply comparing numbers the HP has got it hands down. All I am asking is which one is better? TV Tuner Card: HP is offering a TV tuner card with their Laptop for a cheaper price than what it would cost seperatly. I have been investigating the card and I am not sure if it is what I want. Here is a link of the card being sold seperatly: http://www.circuitcity.com/ccd/produ...T&cm_keycode=4 I have a TV tuner card in my desktop right now but I think that it is totally different. It has a coaxial input for it so I can plug right into normal cable. This card appears to not have that coaxial input. From what I can understand, there is nothing that plugs into this card. It takes the transmitted TV signals from the air. Is that correct? If it does in fact do this, would these be analog or digital signals? I am curious as to whether or not this will work in a year. Also what sort of channels would I get if the card were receiving wireless TV signals? So ultimately this thing seems to boil down to an antenna to pick up TV and would not give me the full function of another TV tuner card with a coaxial input. Also I would assume this card would stick out of the expresscard slot and not full fit into the actual laptop right? Aside from another card to pick up my cell phone companies internet signal (which I don't need) is there anything else that I would potentially put into the express card slot that would turn into a hassle to change in and out with the tv tuner card? Thank you for your patience and dealing with my stupidity.
01-19-2008, 12:50 AM | #2 | |
Member#: 20998
http://www.notebookcheck.net/Compari...rds.130.0.htmlI'll give you my thoughts on the subject.
First, Quote:
Edit: And i'm right. It comes with an RF Cable Dongle with adapter. As for the cards, check out the comparison here. http://anandtech.com/video/showdoc.aspx?i=2984&p=2 I'm looking up the video cards now, but I'd willing to guess that the GT would probably be the better of the two. This website has specs on both. It appears the GS has a faster clock speed, while the GT has more stream processors. I would go with the GT, but read the specs. |
01-19-2008, 02:25 PM | #3 | |
Member#: 41853
Thank you so much for you help. Anyone else with input feel free to share. |
01-19-2008, 02:30 PM | #4 |
Member#: 20998
To be honest with you, I remember reading up on cards about this time last year, and the one thing that I remember sticking out the most was that the amount of RAM did not have as much of an impact as you would think. What mattered was clock speed and other factors. Let others chime in and see what they say. It's not as if you can go terribly wrong here. They both seem like fine cards.
01-19-2008, 02:50 PM | #5 |
Member#: 41853
Ok great thanks for the input. Do you have any thoughts on the express card slot question I posed?
So I have found a picture of the TV Tuner antenna and I see the cable hanging off of it but I cant see anywhere if it says its a coaxial cable inlet or something like an S-Video plug. Where did you find that? So the antenna is purely to transmit the TV signal wirelessly to the computer and not to pick up TV signals? Is is possible for the antenna to pick up signals? I thought I read in some review of the product that some guy stuck the antenna on the roof of his car and watched tv in the car and while camping? Now this is not my intent, but I am curious if it is possible or this guy was just dumb and had not actually done what he said he did. http://www.walmart.com/catalog/produ...00000003142050 |
01-19-2008, 02:56 PM | #6 |
Member#: 20998
01-19-2008, 03:28 PM | #7 |
Member#: 41853
Is composite Audio Video Dongle the same thing as saying coaxial? Also all I kept seeing was analog this and analog that, no digital, is this going to pose a problem in a year when the switch from analog to digital occurs?
01-19-2008, 03:51 PM | #8 |
Member#: 20998
Ok, the way it works is like this. It has a built in antenna to pick up over-the-air digitial signals. What does this mean? It means that if you are close enough to a tower to pick up the signal then you will get it. I've tried using this on my ATi tuner and I can't get even one channel. So, what does that mean for the switch from analogue to digital? I don't know. The HP doesn't look like it accepts off-the-air digital signals.
As far as the dongle is concerned, yes this appears to be the way that you attach your coaxial cable to it. Reviews for it seem to be spotty, but that's like most tv tuners. Some say it's fantastic; others say it's horrible. It's going to depend on a lot things. You could wait a little bit longer and see if more reviews pop up on Amazon or other places. Or, you can get a usb tuner that is both analogue and digital. I have the ATi HD 600 usb and it is both. As far as quality, it's pretty good. The video looks like a good (not great) Divx rip. Sound is ok as well. I got it for like $60 on sale. I think this sounds like it would suit your needs a little more, but it's up to you. |
01-19-2008, 03:55 PM | #9 |
Member#: 38224
NWIC
Vehicle:I miss my Subie. |
There are several USB tuners, is this an option for you?
01-19-2008, 04:31 PM | #10 |
Member#: 14680
NESIC
01-19-2008, 05:09 PM | #11 |
Member#: 9731
Vehicle:2k2 wrx '13 Audi S4 Midnight Gray |
alot of the new usb tuners coming out from pinnacle and hapaugge support not only ATSC and NTSC, but Clear QAM also (which means unencrypted HDTV from your cable provider as well has digital cable)
personally id go with the Dell, but I can't stand HP with a passion |
01-19-2008, 05:37 PM | #12 |
Member#: 41853
Alright well thanks everyone you have been very helpful. I think I will pass on the HP card and go with a USB then. I was really liking the idea the wireless TV and being able to watch tv anywhere in the house without hooking up my laptop but oh well. Thanks again.
01-19-2008, 05:42 PM | #13 |
Member#: 17187
BAIC
Vehicle:2009 Braun Entervan Gimpy White |
I just got the hp 9700t w/ the tv tuner and love it. I also got the xb3000 docking station so I can get up and go as needed. I have my 26" Olevia hooked up to the base and set it up as extended desktop. Tv on the big screen and internet on the lappy. The tuner has an rf adapter for analog cable and a antenna for ota digital and analog tv. The antenna worked surprisingly well here in Fresno. My specs:
Intel c2d t7500 3gb of ram 512mb 8600m gs 320gb hd(2 x 160) 5400rpm dvd/rw w/ lightscribe webcam/mic/fingerprint reader hp express card tv tuner I can game with it no problems either. |
01-19-2008, 09:57 PM | #14 | |
Member#: 41853
WOW, that was the EXACT setup I was looking at getting. Hence the TV tuner and GeForce 8600GS questions. So you know from first hand experience, that the TV tuner has no coaxial plug into it then? What is an rf adapter? |
01-19-2008, 10:20 PM | #15 |
Member#: 9731
01-20-2008, 01:12 AM | #16 |
Member#: 41853
I dont really understand what a dongle is. Ive tried looking it up but I don't get it.
01-20-2008, 01:13 AM | #17 |
Member#: 9731
basically a cable that has an adapter on the end
01-20-2008, 01:23 AM | #18 |
Member#: 38224
NWIC
FYI, if you plan on using Windows Media Center to watch/record TV, you will not be able to do so with Clear QAM channels. If you use other software (MythTV, etc) it is not a problem.
FS IL:Video cards and TV Tuner | Gr3en | MWSOC Private Classifieds | 0 | 09-18-2009 01:42 PM |
TV Tuner Cards for PC | hoku123 | Off-Topic | 4 | 11-10-2005 02:08 AM |
MSI tv tuner card | Star555 | Private 'For Sale' Classifieds | 4 | 07-12-2005 03:27 PM |
PC - TV Tuner cards - software recommendations? | -=C=- | Off-Topic | 3 | 06-13-2005 11:22 AM |
A few questions about installing an LCD, DVD, and TV tuner | Poe | Car Audio, Video & Security | 16 | 03-16-2002 03:02 PM |
