05-06-2015, 03:34 PM | #8426 |
Member#: 305107
Vehicle:2016 GT 5.OHH DIB |
stock motor? im going back this week to have my tuner tweak my tune, my #s were at 20 psi, id like to see what 22 gets me now that i have a clutch to hold the power
05-07-2015, 08:14 AM | #8427 |
Member#: 183480
South East
Yup...50,000 miles on this tune, and about 80,000 total.
05-20-2015, 02:54 AM | #8428 |
Member#: 237190
South East
Vehicle:2003 Matte White Wrx 2006 WRB STi 2007 SWP STi |
id1300
idc was a lot lower than its at now 2 weeks ago 114% fp red 28psi walbro 400lph pump i made 520whp 490trq dyno jet on e90 tested so idc was running at around 80% about two weeks ago. i let the car sit outside in the florida humidty for exactly a week after an autocross. i didnt move it or turn it on for that time with e85 in it around half a tank. once i started driving it again a week later the car drove like complete crap. full throttle it started running lean. i had my tuner raise the idc but that didnt help much. i checked the injectors to see if they clogged, nothing...i havent checked the pump but has anyone else run into this problem? |
05-20-2015, 07:44 AM | #8429 |
Member#: 220816
Vehicle:2018 Exotruck |
sounds like fuel pressure issue, hows the 400 wired, and still on stock regulator?
05-20-2015, 09:08 AM | #8430 |
Member#: 390933
I wonder how much water the fuel might have absorbed? Try some fresh e85 in the tank?
05-20-2015, 10:42 AM | #8431 |
Member#: 183480
South East
In one week, it shouldn't have absorbed much unless the gas tank was left open which is highly doubtful.
When is the last time a tank of 93 oct has been run through it? Might be a long shot, but why not try the easy stuff first. Try running some ethanol fuel system cleaner or a couple tanks of 93 oct through it and see what happens. Sometimes the ethanol can gunk up when it has sat for a while, and this could be causing a blockage on your injectors or fuel system somewhere. This happened on my wrx one time after a few weeks of sitting, and it caused an injector to get stuck open. Ran a couple tanks of 93 oct and started using ethanol fuel treatments every so often, and never had a problem with it again. |
05-20-2015, 02:09 PM | #8432 | |||
Member#: 237190
South East
I put the lucas e85 conditioner in it last fill up as well. As for the gunk/gooey stuff check this out, has anyone else run into this? Ever since florida went on their "summer blend" I've been noticing this goo in the filter of my vp jug funnel. I always wash it out after everytime I fill it but it makes me wonder if the gas station pumps get all gooey |
05-20-2015, 02:13 PM | #8433 |
Member#: 237190
South East
I've looked it up and know what it is but it seems like it's a huge debate between people..some have seen it and some have never seen it.
05-20-2015, 03:11 PM | #8434 |
Member#: 220816
when i pulled my old injectors after a month of e85, they had very small amounts of deposits. My tank and lines had 267k miles on them when i switched, and no issus so far so i dont buy into the hole gunk in the lines theory
That goo is probably that hose melting or from the inside of your storage tank, e85 will destroy plastics in short order. It even destroyed my e85 water tester in a couple days when i forgot to empty it. The hose on the pump at my local speedway specificly says e85 right on it so its not regular octane fill hose |
05-20-2015, 04:10 PM | #8435 | |
Member#: 237190
South East
How about hard wired pumps. I know it's supposed to decrease the life on the pump but I wouldn't expect it to last only a a couple months if hardwired. Sent from my SAMSUNG-SM-G900A using NASIOC mobile app |
05-28-2015, 10:10 AM | #8436 |
Member#: 220816
I dont know why it would shorten pump life, if anything it should help it get the current it needs
05-28-2015, 01:16 PM | #8437 |
Member#: 220816
well here we go, car can now run on any blend of octane/ethanol.
I ended up adjusting the maps on the way back to work. -30% for 93 octane was removing too much because of my injector size. They are 3x stock so 1% equals 3%. The slope now starts at -12%. My fuel trims are still low and on e30 i hit 11:1 afrs at wot and 12:1 at what on e80 Also, greddy lied to me. The emanage will adjust more than 20° of timing. good for me. I set it up to pull about 5° out of my maps for e30, so i hit about 15° of timing at peak torque on e30, and 20° pk tq on e80. Theres a noticable power loss on e30, but atleaste now i can make road trips, and get a few gallons of 93 if need be to get me back to and e85 pump |
06-13-2015, 04:45 PM | #8438 |
Member#: 387223
NESIC
Vehicle:2016 WRX Lapis Blue |
I am planning to go E85 soon with the following supporting mods. I have a question: Living in Minnesota with cold winters, should I run on 93 in the winter? Will I need a block heater? And should I be worried about knock?
Also, any recommendations on the setup? COBB Tuning AccessPORT V3 Subaru 2.5L Turbo Killer B Motorsport 4-1 Holy Header 2-Bolt Subaru Turbo Models Tial MV-S Wastegate 38mm Blue w/ All Springs* Invidia Downpipe Divorced Wastegate w/ 2 Bungs Subaru Models Injector Dynamics Fuel Injectors Top Feed 1000cc Subaru Models COBB Tuning SF Intake and Airbox Subaru WRX GrimmSpeed Turbo Heat Shield Subaru Turbo Models* GrimmSpeed Boost Solenoid Subaru * DeatschWerks DW65c Series Fuel Pump DEI Titanium Exhaust / Header Wrap GrimmSpeed Ceramic Coated 38/40mm V-Band External Wastegate Uppipe AEM UEGO Wideband Controller 4.9LSU AFR Gauge* Turbosmart Recirculating Blow Off Valve Kompact Plumb GrimmSpeed Top Mount Intercooler |
06-13-2015, 05:44 PM | #8439 | |
Member#: 220816
06-13-2015, 06:16 PM | #8440 |
Member#: 387223
NESIC
I see, thanks. So I guess it's pretty safe with a good tune.
06-14-2015, 11:12 PM | #8441 |
Member#: 374650
South East
Vehicle:2012 Sti Limited WRB |
Alright guys, looking for some help. I tried researching the thread but couldnt get very far. Ive ordered a few parts in the last few days and Im planning on getting tuned for E85, most parts wont be installed until tune day since the tuner wont be in town until then. My question is whats the procedure a few of you take as far as fueling goes to/until the actual tune? Do you guys fill up on e85 before the tune and just not go into boost?
Another question that just came to mind now if you guys dont mind helping out while we're at it. Ive been reading and you guys apparently test the ethanol content of the E85. I know what you guys use to test the ethanol content. Ive seen the links here to the test sticks, but my question is how do you guys go about testing the fuel? do you fill a small tank before filling up the car and test it? Ill try to keep searching throughout the thread if I think of anything else. The help is always appreciated guys. |
06-15-2015, 03:42 AM | #8442 |
Member#: 350332
South East
Vehicle:2004 Bone Stock* STi *with supporting mods |
Javi -- I would not put e85 in your tank until after the tune. Most tuners will drain your tank somehow, and full with E85. You could and should also contact the tuner or local shop that he / she is using for specific instructions...
I personally highly recommend an ethanol content analyzer be added in line to your fuel system. They aren't very expensive any longer, and are much better than a test kit. |
06-15-2015, 07:39 AM | #8443 |
Member#: 220816
Ya you dont want to change fuel types on your own until you have maps ready or you'll likely stall out at the gas station and never get it restarted. Like dlapham said, just give the tuner a quick call, even if he isnt there someone else will likely know how they operate.
i use a flexconverter.com universal kit. Comes with sensor (needs tee'd into return line) and hooks up with 2 wires. 3 if you want to use the analog output for logging or flex fule in my case. It's bluetooth and use a android/phone or tablet as the gauge with the blueflex app. |
06-16-2015, 08:00 PM | #8444 |
Member#: 271479
Vehicle:2010 LGT 2009 FXT |
Joined the e85 army today. 385whp/385wtq @ 24.5 PSI in 90+ degree ambient heat. Soooooo much torque down low. Death to pump, LONG LIVE E85!
06-16-2015, 09:04 PM | #8445 |
Member#: 220816
nice, im making 322/338 at 17psi on a NA 2.2. E85 is a god.
06-17-2015, 10:38 AM | #8446 | ||
Member#: 374650
South East
I took a look at some ethanol content analyzers, along with the one you mentioned Terry. Theyre not expensive imo, and its a useful tool. I am still however somewhat confused with testing and how it effects my driving/tune. So Im in FL, Miami specifically, and to my understanding we are on summer blend throughout the year. What is a right percentage I should be looking at? What is considered low content? What do I do if Im tuned for e85 and I have a low ethanol content fillup or two? I have/will have pretty much the same upgrades with the average users here on stage 2 asking the same noob questions lol. Grimmspeed Catless DP Invidia Q300 Cobb SF 1000cc injectors DW300c Grimmspeed EBCS Perrin Turbo inlet I thank you for all the help/info! |
06-17-2015, 10:51 AM | #8447 |
Member#: 350332
South East
In Tennessee, summer blend is 80 percent. I imagine you should see something in that range. Our low is 70 percent, which I have seen even now at some stations. I have three tunes now. One for E80, one for E70 and another for 93. So far so good, but I can't wait until cobb releases flex fuel.
06-17-2015, 10:55 AM | #8448 |
Member#: 350332
South East
Low ethanol content runs rich. I would think your tuner would give you several maps for different E content. My personal rule, is to stay out of boost if I have questions about something, and use my AAA membership if the car doesn't run right, or the wideband is off.
06-17-2015, 11:23 AM | #8449 |
Member#: 348177
TXIC
Vehicle:2002 Bugeye Haltech GTX3584RS |
Stations around here run anywere from e70 to e95. I use a zeitronix eca2. Most stations are pretty consistent, the one near my house always has e70....they suck.
06-17-2015, 03:45 PM | #8450 | |
Member#: 395731
SCIC
Vehicle:2015 WRX Premium DGM |
You could always get a pro tune ya know, and have flex fuel - be it Cobb or ecutek. |
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
