Welcome to the North American Subaru Impreza Owners Club Sunday November 17, 2019
Old 12-28-2013, 11:13 PM   #226
NJReppin
Member#: 371530
2004 PBP 2.5RS
PSM 04 STi
what kind of fluids should 4EAT users use?
thanks!
NJReppin is offline   Reply With Quote
Old 01-09-2014, 03:31 PM   #227
subawoo77
Member#: 370658
07 Hawkeye STI
How often are you guys servicing you differentials?? I dont trust the "stealer" ugh I mean dealer. They just want my money..I trust Nasioc for subie questions
subawoo77 is offline   Reply With Quote
Old 01-09-2014, 04:04 PM   #228
falconWRX
Member#: 349089
2014 WRX Limited
WR Blue
I serviced my wrx at 32k with oem fluids using a coupon at the dealership. Has been running fine. I'm at 38k miles now.
falconWRX is offline   Reply With Quote
Old 01-09-2014, 07:32 PM   #229
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
Its a 30k service for trans and diff fluid. Its really easy to do, just like an oil change really but you need a torx bit ... t27 I think but might be wrong. I have seen subaru extra s oil for sale on amazon for 15 $ a quart.
T_woot is offline   Reply With Quote
Old 02-17-2014, 05:35 PM   #230
trife86
Member#: 301368
2012 WRX
PBP
Which rotella do I want for my 12 wrx. I see just plain ole rotella (cheapest) than I see t5 and t6
trife86 is offline   Reply With Quote
Old 02-17-2014, 06:03 PM   #231
T_woot
Member#: 321665
2006 WRX VF39 Swap
WRX Blue
T6 Rotella
Old 02-17-2014, 08:26 PM   #232
falconWRX
Member#: 349089
2014 WRX Limited
WR Blue
T6, the blue container
Old 02-17-2014, 10:42 PM   #233
Rigged
Member#: 259196
2015 WRX STI
WRBP
Originally Posted by T_woot View Post
I'd still run a k/n filter. Its a few bucks more but works better and is reusable for life.
Just to share information. If you want the "cleanest" air you should rethink the K&N. If you want the least restrictive then the K&N will work. I remember doing research way back when so I had to search for this article.
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
Rigged is offline   Reply With Quote
Old 03-03-2014, 06:42 PM   #234
trife86
Member#: 301368
2012 WRX
PBP
I need to top off my coolant s little in my 2012 wrx. Its maybe a inch below the low line so not much needed only a couple of ounces. Can I use just distilled water? Being its not a significant amount
Old 03-18-2014, 03:38 PM   #235
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
For that much just use tap water, unless you have well water that really sucks.
prochucker is offline   Reply With Quote
Old 03-18-2014, 04:06 PM   #236
subawoo77
Member#: 370658
07 Hawkeye STI
hmmm I wonder the stealer charges for this.
Old 04-06-2014, 02:33 PM   #237
Twofiveeye
Member#: 386874
08 2.5i 55k miles
I just changed plugs for the first time. Passenger side front hole had a lot of oil in it. Passenger side rear hole had a little. Drivers side were bone dry.
Where did the oil come from? What would cause this? Anything to worry about?
Twofiveeye is offline   Reply With Quote
Old 04-19-2014, 12:03 AM   #238
fullarmor00
Member#: 388222
2003 Forester 2.5 XS
Gold
I need tutorials for the following:
1) How to replace the valve cover gaskets on my 2003 Forester 2.5 XS
2) How to replace the A/C belt
3) How to replace the power steering belt
Thank you.
fullarmor00 is offline   Reply With Quote
Old 04-19-2014, 12:05 AM   #239
fullarmor00
Member#: 388222
Gold
Default Tutorials for 2003 Forester 2.5 XS
Thank you.
Old 04-21-2014, 11:53 AM   #240
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Thank you.
to replace the valve cover gaskets really requires an engine removal so the last 2 would be included. I have heard of people doing them in the car, but was told they would pull the motor if they had to do it again. You may want to invest in a Service Manual, they can be found on CD on Ebay cheap.
Old 07-22-2014, 04:22 PM   #241
npicar
Member#: 358828
2013 WRX
PLASMA BLUE PEARL
I recently changeD my transmission oil. But for some reason, I get a jerking motion between 2nd to 3rd gear during hard acceleration. Did anyone experienced the same thing? What do I do? Its my 1st turbo charged car.
npicar is offline   Reply With Quote
Old 08-08-2014, 04:25 PM   #242
buggeyesubie02
Member#: 397880
2002 wrx
Subaru Blue
Does anyone live in the daytona beach area i would like someone that knows these wrx motors to take a quick look at my car i need a second opinion i swear my turbo is ticking at idle
buggeyesubie02 is offline   Reply With Quote
Old 11-18-2014, 02:59 AM   #243
Tommyp
Member#: 277475
I changed out my front brake pads and rotors. Now I get a squeak at the metal clip(?) that holds the brake pads on the passenger side. I've greased that metal clip and the sound goes away for about two weeks then comes back again? I've greased it twice and it came back each time. What gives..? Is the grease rubbing off somehow?
Tommyp is offline   Reply With Quote
Old 12-25-2014, 06:33 PM   #244
jbrew
Member#: 409351
Default Oil Level
I recently took my 2012 impreza to the dealership to complain about it losing oil and to get an oil change. They told me to come back in 1200 miles. After I got home, I checked the oil and they overfilled it by about 30%, see photo. Is this bad for the car? What should I do? The red arrow is the full mark.
https://drive.google.com/file/d/0B7U...ew?usp=sharing
jbrew is offline   Reply With Quote
Old 12-25-2014, 07:49 PM   #245
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Drain it down a bit.
Next time, perform your own oil service and while doing so, install a Fumoto oil drain valve.
Old 12-27-2014, 12:05 PM   #246
TommY_-_-
Member#: 409477
So...I'm having a similar problem with my 2014 impreza. The vehicle just broke 9000 miles, the oil has been changed like clock work as per the manufacturer specifications and recently the oil light came on. On the way into work about 100 yards away from the parking lot the oil light came on, when I checked it the oil level it was at the bottom of the dipstick it was still there but really low. I automatically assumed the oil change place did a jenky job with the oil filter etc. But when I took a closer look there was absolutely no oil anywhere. I called the place where I had my oil changed and they had me bring the car to them to do a leak check but they couldn't find anything. I then called Subaru to see if they could help and of course I was told just to keep an eye on it and call them back if it gets low again. What would cause the oil level to drop like that.? I don't run the car too hard at all in my opinion and for a new car it shouldn't burn a drip of oil. I know Subarus have been know to need a quart of oil every two thousand miles or so but common sense tells me that something is screwed up. I thought Maybe a defective piston ring so I had a buddy follow behind me to check for the dark oily smoke from the exhaust and he said there was nothing. So where is this oil going.?? I'd appreciate if Anyone has any ideas on what to do.
Sent from my iPhone using NASIOC
TommY_-_- is offline   Reply With Quote
Old 12-27-2014, 12:32 PM   #247
tjmmason93
Member#: 300250
2004 Impreza WRX
JBP
Originally Posted by tjmmason93 View Post
Recently did the 2004 sti 6speed swap and picked up alot more than I found out I needed, so I have alot from my wrx and some random things from the sti that are 100% identical.
Location Spotsylvania 23024 VA
Most prices are OBO
if im shipping you pay shipping,
The 04 sti components have 90k
The 04 wrx components have 108k
Unless listed otherwise
Aftermarket parts
250$Helix High-flow catted downpipe
50$Kartboy front endlinks
75$ Cobb Tuning SF Air Intake Box Subaru WRX / STI 2002-2007 / Forester XT 2004-2008
40$ 5speed excedy OE replacement clutch with 30k miles on it -
SOLD5speed flywheel OE from subaru with 30k on it -
^both are in excellent shape, broke in accordingly (900miles) way more than necessary
SOLD grimmspeed top mount silicone charge piping. Literally bought them, installed them (had to cut to fit) and then decided to go front mount
450$2004 wrx transmission (3rd gear had some sync row issues may have just been crappy fluid, but everything else is pretty solid) may end up keeping and rebuilding not sure yet
SOLDA stock td05 04 wrx turbo w/90k- No shaft play at all.
35$ for both2004 wrx front half shafts - one CV boot will need to be replaced, will replace but price will increase
50$ for both2004 wrx rear half shafts -
60$ both 2004 wrx rear hubs -
50$2004 wrx driveshaft -
250$2004 wrx r-160 rear diff (still in good shape, used high quality magnets and diff fluid) -may still keep
30$2004 sti front hubs (the bearings looked like they had begun to rust so I used my wrx front hubs (identical)
200$2004 sti/wrx rear subframe that holds the diff in (has all centric bolts and everything else)
50$ for both2004 sti/wrx rear trailing arms
make offer2004wrx rear calipers and front calipers-
100$ for all 42004 wrx OE roters- all the way around along with hawk hp+ pads in the front. And 0em in the rear All in good shape. U may want to resurface the roters if u plan on picking them up as I made the mistake of using a hammer to get them off.
All brake pads and roters have about 30k on them
100$ 2004 STi front autozone roters less than 5k and autozone pads less than 5k
30$bosch OE narrowband post-turbo 02 sensor- with about 20k miles on it
SOLD2004 wrx tumbler generator valves- non deleted, will delete and polish for you but will charge for the delete before I do it.
40$ ball ping hammer mod2004 wrx stock BPV
40$2004 wrx stock fuel pump
150$2004 wrx stock 550cc injectors
150$2004 wrx TMIC
Just went FMIC
SOLD 2004 sti TMIC
and im pretty sure thats everything. If you have got a price in mind im willing to take offers.
Thanks for your intetest
Thomas M.
Best advice I can give you boss, is do your own oil changes or pay someone you personally know and trust.... and do a compression test for results if you have a defectove piston ring this is your best bet.
Sent from my SM-N900V using NASIOC mobile app
tjmmason93 is offline   Reply With Quote
Old 01-28-2015, 07:15 PM   #248
steveo3141
Member#: 411103
1997 Impreza Outback
Default Nice Sticky
Thank you for letting us know. Lots of good info.
steveo3141 is offline   Reply With Quote
Old 03-10-2015, 04:48 PM   #249
subien3ss
Member#: 414301
Hey guys. Got an 02wrx. What is the name of the rail that connects the coolant expansion tank to the resivoir? It is mounted to the fan bolts and the coolant hoses from the resivoir and expansion tank are clamped to it. Thank you
subien3ss is offline   Reply With Quote
Old 03-16-2015, 03:30 PM   #250
Woadie12
Member#: 414555
2012 WRX
2012 WRX - Trying to figure out how to replace the rear turn signal bulbs. Anyone replace the bulbs yet and know the easiest way?
Woadie12 is offline   Reply With Quote
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 338 10-25-2019 01:04 AM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 391 08-16-2019 11:49 PM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 307 07-07-2019 04:40 PM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 118 12-08-2016 01:24 PM
