Welcome to the North American Subaru Impreza Owners Club Saturday September 26, 2020
Old 03-02-2020, 12:46 PM   #1
Lancaster
Member#: 476041
2014 WRX
Default Project Rosco GV WRX
Growing up in the golden age of automotive forums in the late 90s and early 2000s I have grown tired of Facebook groups and IG picture accounts. NASIOC is still here and itís time I got back to it!
One of my many Subaru projects is my 2014 WRX premium sedan. Purchased used with 15k miles it was all stock. As the thread progresses Iíll explain why the WRX has STI side badges and interior as it will be asked lol.
All work on this project has been competed by myself and I take great pride in my quality of my workmanship. Iíll add more details and mod list when I have more time to add to this initial post!
Engine
-IAG stage 3 plus
-D25 heads with Kelford 272 cams, GSC valves and GSC beehive springs
-Cobb FMIC
-Garrett GTX3076R gen II
-ETS V2 header with rotated up-pipe
-Tomei catback exhaust
-IAG tgv deleted under STI ported intake manifold
-ID1300 injectors
-Cobb flex fuel and fuel pressure sensor with Cobb fuel rails
-Walbro 525 in Visconti hanger managed by I-wire hardwire kit with GTR pump controller
-Tial BOV and EWG
Suspension
-Feal 441+ coilovers
-2017 STI front lower control arms
-2019 STI brembos
-2017 STI knuckle assembly
-RCE sway bars
-SPC lower rear control arms
-Super Pro roll center adjustment
-Cusco chassis bracing
Drivetrain
-2017 STI 6 speed trans / r180 diff
-2017 STI axles
-Iwire DCCD controller w/ oem switch
-ACT XDSS
-Kartboy short shifter
-Group N engine, trans mount and pitch stop
Exterior
-OEM chrome xenons (originally halogen)
-JDM STI extended front lip
-JDM STI Ts spoiler
-STI turn signal mirrors
-Impreza trunk
Interior
-JDM radio bezel
-DAMD steering wheel
Wheels
-Volk Rays TE37sl Diamond Black 18x10 w/ Firestone Indy 500 in 275/35/18
Lancaster is offline   Reply With Quote
Old 03-02-2020, 02:52 PM   #2
96accord
Member#: 145105
2015 Honda Accord
Nice build! Subscribed
96accord is offline   Reply With Quote
Old 03-02-2020, 03:16 PM   #3
Lancaster
Member#: 476041
2014 WRX
First couple months of owning it was basic stage 2 engine mods and suspension. Several wheel changes in that time frame.
17x9 Rays 57DR lowered on RCE regular guy springs
Old 03-02-2020, 04:05 PM   #4
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
Subscribed. About time you make a build thread. Can’t wait to see all the details of this thing.
QwaktastiK is offline   Reply With Quote
Old 03-02-2020, 06:18 PM   #5
Lancaster
Member#: 476041
2014 WRX
Originally Posted by QwaktastiK View Post
Subscribed. About time you make a build thread. Canít wait to see all the details of this thing.
Thanks brother Iíll try and find pics of everything!
Old 03-02-2020, 07:48 PM   #6
Lancaster
Member#: 476041
2014 WRX
Certain taste come and go. Cheap FMIC w/ stock turbo and an interesting color choice on Rays 57Extreme 🤣
Was running Koni yellows in narrow body 08 wrx strut housings, 08 housing were 1/2 lower than later years and added some camber.
Quickly grew out of the mustard color 🤣🤦
Old 03-02-2020, 07:51 PM   #7
Lancaster
Member#: 476041
2014 WRX
After running the usual stage 2 issue free it was time for a slight engine upgrade with a fresh STI block, crank and rods paired with CP pistons. Converted to an STI intake manifold and aftermarket STI top mount with Blouch 1.5xtr and E85. Made 430whp and 380wtrq to save the original 5 speed.
Old 03-02-2020, 07:55 PM   #8
Lancaster
Member#: 476041
2014 WRX
Much needed 6 speed swap came in from a low mile 2017 STI... 1400 miles!!! Along with the Brembo and knuckle assembly. Paired with an Iwire DCCD controller using oem DCCD switches. Deleted the Sdrive knob as itís not usable with the WRX ecu. Top mount pulled some heat soak so went to Cobb for an excellent performing and amazing fitting FMIC
Old 03-02-2020, 08:08 PM   #9
Lancaster
Member#: 476041
2014 WRX
After a wastegate spring increase and the 6 speed we pushed 460whp and 445wtrq out of it but were at the limits of the STI rods and Blouch 1.5xtr.
Time to get real!
Always a sucker for a rotated turbo! We have a rotated 07 STI limited and I just had to have one in the 14.
Set out with a goal of 600whp. After many conversations with my Tuner Corbin at Johnson Tuning it was decided to use the Garrett GTX3076R gen 2. Picked the supporting fuel mods and began to build the engine.
Right away went with an IAG stage 3 plus closed deck block. Paired it with fresh D25 casting heads with a pocket port performed by my ( was a little nervous 🤣 ). Sent heads to IAG to install GSC stock size stainless valves and beehive springs. Also had them clearance for Kelford 272 cams and lash set with new lifter buckets.
Assembled the engine at my home garage and dropped her in!
Money shot!!!
Old 03-02-2020, 08:17 PM   #10
Lancaster
Member#: 476041
2014 WRX
After break in Corbin at Johnson Tuning pushed 607whp on the Dynojet meeting my goal of 600!
Side note that was overshadowed by my wifeís 07 STI pushing out 777whp the very next day!
My wifeís 07 we built at the same time lol
Old 03-02-2020, 08:52 PM   #11
Lancaster
Member#: 476041
2014 WRX
Always liked Cobb
Old 03-03-2020, 12:01 AM   #12
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
@thejeffruhl 387hp/350tq
Damn... nice car! Well done
JeffrWRX is online now   Reply With Quote
Old 03-03-2020, 12:21 AM   #13
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
damn y'all both fancy! Love it; I have this affinity for black cars man, too damn sexy and sinister at the same time.
JDMJNKY is offline   Reply With Quote
Old 03-03-2020, 07:14 AM   #14
Lancaster
Member#: 476041
2014 WRX
Some smaller details about the car. I canít use an STI cluster without a lot of work! So as I donít have Sdrive anyway I moved the STI bezel with Cherry Blossom accents over to the WRX gauge face.
Old 03-04-2020, 08:22 AM   #15
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
Thatís dope. I thought you just swapped the STI cluster. So cool itís a hybrid of the two
Old 03-04-2020, 09:36 AM   #16
96accord
Member#: 145105
2015 Honda Accord
Oh Snap! You are that Lancaster. The Aaron Lancaster. Nice
I follow you on Instagram.
Old 03-04-2020, 12:22 PM   #17
Lancaster
Member#: 476041
2014 WRX
Nice appreciate that very much! Wish I could change my screen name here to something catchy 🤣
Old 03-04-2020, 12:23 PM   #18
Lancaster
Member#: 476041
2014 WRX
Anyone think of a creative way to get this temp sensor to work on the AP?
Old 03-04-2020, 03:42 PM   #19
lub
Member#: 343218
2004 WRX wagon
So much win in one thread.
lub is offline   Reply With Quote
Old 03-05-2020, 07:16 AM   #20
Lancaster
Member#: 476041
2014 WRX
much appreciated!
Old 03-05-2020, 07:19 AM   #21
Lancaster
Member#: 476041
2014 WRX
Some engine bay details
Old 03-05-2020, 11:51 AM   #22
werk
Member#: 382167
2014 wrx hatch
ISM
Sweet I drool over your car on a bigger screen now! I've been lurking your build over instagram haha
werk is offline   Reply With Quote
Old 03-06-2020, 09:26 AM   #23
milab21
Member#: 157833
2017 WRB STI
2007 WRB STI-sold
Subscribed, always enjoyed your build
milab21 is offline   Reply With Quote
Old 03-06-2020, 09:05 PM   #24
Lancaster
Member#: 476041
2014 WRX
Waiting on Volk to send me a single wheel. Hell my spoke decals have been on backorder for 2 months 🤦
Old 03-07-2020, 02:36 PM   #25
mryakker
Member#: 512350
beauty!
mryakker is offline   Reply With Quote
