Welcome to the North American Subaru Impreza Owners Club Tuesday November 24, 2020
Old 10-03-2001, 12:15 AM   #1
Rob W.
Member#: 8992
'02 WRB WRX
'91 300ZX Twin Turbo
Default How much oil is too much in a WRX? Ticking noise.
Today, I decided to check all my fluids in my WRX. The car has a whole 380 miles on it now. Everything looked pretty good except the engine oil - it was way full. It's hard to describe the dipstick, but here's two attempts:
1.) If you measure the distance from the end of the dipstick to the "F" mark, my oil is about DOUBLE that amount!
2.) If you look at the end of the dipstick, starting on the bottom end, there are three 90 degree twists to the stick. My oil is at the second twist.
What should I do? Is this normal for factory break-in periods? Is it way too much? I've had some engines in the past that have dipsticks which are very sensitive to oil amounts. By that, I mean that just slightly overfilling it will make the dipstick look like it's way overfilled (but it's no big deal really). Is the WRX like that, or should I go to the dealer and tell them to drain some oil out??
I noticed that my engine has a slight ticking noise that changes with revs. This made me think that the engine might be low on oil, which is what prompted me to check it in the first place. It's a fairly quiet sound.. maybe it's even the injectors clicking away.. I can't tell for sure. It's mostly just noticeable if I'm driving next to a tall curb or wall. Does anyone else have this sound? Could the ticking be related to the overfilled oil? I'm a real amateur when it comes to these boxer motors, so any advice would be appreciated.
-Rob W.
Rob W. is offline   Reply With Quote
Old 10-03-2001, 01:34 AM   #2
bmwk12rs
Member#: 10632
Read the front side of the dipstick when you pull it out. The back side smears the oil on the dipstick and the oil appears high. Also, read the manual. It describes how to insert the dipstick, how to read it and the difference between hot and cold oil.
bmwk12rs is offline   Reply With Quote
Old 10-03-2001, 02:57 AM   #3
aov
Member#: 7193
MY02 WRX
If you think something is wrong take it to your dealer and have them look at it. They should be able to give you a proper answer.
I have heard others mention a ticking noise but I don't know what caused it for in their cars. I would be more worried about the oil levels. It can't hurt to have it looked at.
-anders
aov is offline   Reply With Quote
Old 10-03-2001, 08:45 PM   #4
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
Mine was overfilled from the factory too. On my first oil change they put in the correct amount( below Full). I guess factory overfills these engines for break-in.
Alex...
amelnikov is offline   Reply With Quote
Old 10-03-2001, 09:04 PM   #5
Rob W.
Member#: 8992
'02 WRB WRX
Thanks amelnikov, that was the kind of confirmation I was hoping for.
-Rob W.
How much play is too much in an axle? WRXislander Service & Maintenance 4 09-30-2007 01:49 PM
How much HP is too much for the WRX? snvin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 12-02-2004 10:55 PM
How much PSI is too much PSI? virus67 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-15-2001 07:48 PM
how much bar is too much? Darryl Brakes, Steering & Suspension 17 06-08-2001 01:23 AM
How much Nitrous is too much? KillerTHC Normally Aspirated Powertrain 3 05-23-2001 08:14 AM
