#26 |
Member#: 437670
Vehicle:2005 2.5 SC OB |
![]() I think they switched to returnless in 2006 for many cars, A return style has 3 lines. 1 is supply, 1 is return and 1 is Evap. You can tell by going to RockAuto and looking at the fuel pump module, or.... in engine bay 3 hoses would be return style. I have no idea how to tune a returnless system but I am sure many people have done it successfully.
#27 |
Member#: 505361
Vehicle:2008 Legacy 2.5i White |
![]() I disconnected the hose I thought was return and it’s definitely evap, no fuel. I’ve had this car tuned multiple times, no one has ever mentioned returnless being an issue?
#28 |
Member#: 437670
![]() Yeah I don't think it will be much of an issue.
#29 |
Member#: 505361
![]() Video 1.5 is up!
Lots of work done today.. and more tomorrow. I'll have a video up next week of us actually working! Some progress pics: Installing the AWIC radiator and pump https://i.imgur.com/K2iSZ7S.jpg https://i.imgur.com/NSqzBOX.jpg Pump and relay/fuse box 100% complete https://i.imgur.com/SjFeaWK.jpg Inside the pump relay/fuse box https://i.imgur.com/TEgOqEL.jpg Radiator complete https://i.imgur.com/2H0bV5I.jpg Hella horn mounting https://i.imgur.com/lh5wnLl.jpg Subimods Hella horn harness https://i.imgur.com/IuJj89R.jpg Rear galley plug used for turbo oil feed and AVLS oil temp sensor relocation https://i.imgur.com/qhW1eyD.jpg OEM turbo manifold sandblasted, painted, and ready for wrap https://i.imgur.com/ne9fVTa.jpg https://i.imgur.com/1L4ceMo.jpg Last edited by tipsymechanic; 09-08-2019 at 12:31 AM. Reason: added more stuff |
#30 |
Member#: 505486
Vehicle:2008 Subaru Legacy |
![]() Hi tipsymechanic, awesome build.
I'm assuming you did engine management yourself. How did you adjust your ROM for the larger fuel injectors? Any guides anuwhere about this? I'm going to slap on a used raptor SC kit soon with wrx injectors onto an ej253 and need help since I don't have a base map. |
#31 | |
Member#: 505361
![]() Quote:
There’s a lot of good newbie tuning info here: https://forums.nasioc.com/forums/showthread.php?t=1626520 Have you had your ECU defined yet, so it can be tuned? PM me if you need more detailed help. |
#32 | |
Member#: 505486
![]() Quote:
#33 |
Member#: 505361
![]() Cool. You’ll also need to re-scale the tip-in fueling, cranking tables, and a few other things fuel related
#34 |
Member#: 505361
![]() Part 2 is up! In this episode, we tackle installing the air-to-water intercooler.
#35 |
Member#: 505361
#36 |
Member#: 437670
#37 |
Member#: 491471
Vehicle:2009 Impreza Black |
![]() Do you have to modify the stock BPV for the lower boost?
#38 |
Member#: 491471
![]() Its been awhile. Anything new with your build?
#39 |
Member#: 243490
![]() What happened to this thing??
#40 |
Member#: 437670
![]() Probably life! I’m sure he will be back
#41 |
Member#: 505361
#42 |
Member#: 505361
![]() Nope, it works just fine!
Its running and driving, I'm trying to find time to edit videos. still here! sorry, been super busy! |
#43 |
Member#: 505361
![]() PART 3!!
I apologize for the delay.. I got lazy/unmotivated/busy/etc.. This one isn't too exciting, just making some changes to allow the turbo inlet fitment, and turbo oil feed plumbing. |
#44 |
Member#: 409332
Vehicle:2013 WRX PBP |
![]() What are those topfeed rails with integral pulse dampers off of?
#45 |
Member#: 505361
