Welcome to the North American Subaru Impreza Owners Club Tuesday November 20, 2018
Old 03-08-2010, 09:23 PM   #1
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Default 07 wrx ecu, key, immobilizer, compatible with 06 sti?
Like the title states, I have a 2007 wrx ECu, Key and immobilizer and im trying to get a car going that has had a wiring harness merged from an 06 sti. I didnt do the merging and I dont know who did. Does anyone have any insight? Ive been searching for the past hour or so, found some helpful threads and notes; I know that an 06 wrx is pretty much identicle between an 07 sti, and that an 07 wrx and 07 sti differ by only a pinout or so. I also will be using either the 06 sti engine harness, or 07 wrx harness which ever is called for.
Dubstar112 is offline   Reply With Quote
Old 04-02-2010, 01:37 AM   #2
Team Scream
Member#: 121532
06 FXSTi, 06 FXTAT
06 STi Wagon, 99 GF Wagon
I am pretty sure those ECU's will swap right over.
The immobilizer will bolt right up in the same place and the ignition switch is a no brainer.
You should have no problems whatsoever as long as the wiring harness merge did not mess with any of the original immobilizer's integration.
Team Scream is offline   Reply With Quote
ECU compatability 05/06 STI scotty144 Engine Management & Tuning 1 05-30-2010 02:05 PM
Immobilizer compatibility with Turbo Timers tones111 Car Audio, Video & Security 9 03-03-2010 04:24 AM
05-07 Legacy key works with 06 STI MorphiasX Interior & Exterior Modification 10 01-18-2010 01:17 PM
Attn 06/07 WRX owners with 06 STi swap...NEED HELP!!! jester696 Transmission (AT/MT) & Driveline 3 08-03-2008 06:53 AM
OEM 06 STI springs compatible with 06 WRX strut SCRAPPYDO Brakes, Steering & Suspension 4 04-22-2007 09:53 PM
