Welcome to the North American Subaru Impreza Owners Club Wednesday November 14, 2018
Old 04-10-2010, 07:45 PM   #1
07xtreme
Member#: 218663
96 legacy wagon
ej20 swapped, white
Default got codes, need some brain power...
ok so as some of you know im buttoning up my 02 wrx/96 legacy swap. we tried to run all wrx wiring and then just splice my connectors on when needed. wrx motor, wrx ecu, wrx fuel pump controller, wrx fuel pump. everything else is 96 legacy(tranny, interior, etc). so my o bd2 connector came in today so i scanned for codes...
P0500 - speed sensor
im using a legacy speed sensor, think we have a missing conection from the speedometer to ecu...could that be part of whats causing it to run in limp mode?
P0183 - fuel temp sensor
i dont have one, only way to fix is add one?
P0447 - Evaporative emission control system vent control low input
what can i do for this, i cant find crap on this code that, that would specifically help me
P1230 - manu. fuel air metering
?...just read something it could be due to something with the fuel pump controller...any other ideas?
P0245 - wastegate solenoid
just searched and found something that said you can toss in a 10k [email protected] 0.5w across the wires? anybody hear this one?
P1400 - Fuel tank pressure control silenoid valve circuit low input
dont have one, do i need to get one?
07xtreme is offline   Reply With Quote
Old 04-11-2010, 10:46 AM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
get access to a tactrix and disable any codes in romraider that are hard to fix, and don't affect anything.
P0245... are you talking about the boost control solenoid?! cause you definitly need that.
ProdriveDreams is offline   Reply With Quote
Old 04-11-2010, 11:17 AM   #3
07xtreme
Member#: 218663
96 legacy wagon
ej20 swapped, white
P0245 - if that does mean the boost control silenoid, I'm running a manual boost controller so Id just need to trick it I guess
Old 04-11-2010, 11:31 AM   #4
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
Oh good, once again tactrix cable and rom raider should do the trick, or get a stock one plug it in and just zip tie it to something.
Old 04-12-2010, 08:18 AM   #5
07xtreme
Member#: 218663
96 legacy wagon
ej20 swapped, white
bump, any other thoughts?
Old 04-12-2010, 10:30 AM   #6
RSmatt
Member#: 8039
94 v2 STi RA - RHD
Sounds like you know the problem here.
The legacy ecu got it's VSS signal from the cluster. You need to splice the VSS wire from the wrx ecu to the VSS wire that comes from the legacy cluster.
RSmatt is offline   Reply With Quote
Old 04-12-2010, 11:01 AM   #7
07xtreme
Member#: 218663
96 legacy wagon
ej20 swapped, white
haha 1 down, 5 to go...thank you
im pretty lost on the P0447 and P1230
seems like P0447 only occurs on wrx's when the wire sheers off the evap canister. so im assuming my issue it the lack of connection to an evap canister. im not sure where to even start with this one
and P1230 im just lost haha
Old 04-12-2010, 11:04 AM   #8
07xtreme
Member#: 218663
96 legacy wagon
ej20 swapped, white
ok so i just found this thread for P1230, figure its a place to start...
http://forums.nasioc.com/forums/show....php?t=1625690
Old 04-12-2010, 11:27 AM   #9
07xtreme
Member#: 218663
96 legacy wagon
ej20 swapped, white
ok so where im at right now
P0500 - just need to splice a wire
P0183 - install a fuel temp sensor or tune it out
P0447 - i guess just tune it out
P1230 - i need to look over my fpc wiring(see the link i posted above)
P0245 - im going to try that resistor trick other wise ill figure something else out haha
P1400 - get the pressure sensor or tune it out
everyone agree? haha
Old 04-13-2010, 08:22 AM   #10
07xtreme
Member#: 218663
96 legacy wagon
ej20 swapped, white
P0500 - FIXED, spliced a wire, no more fuel cut
P0183 - going to tune it out
P0447 - going to tune it out
P1230 - still need to look over my FPC
P0245 - FIXED, used the 10k ohm @ 0.5w resistor, and it worked
P1400 - going to tune it out
BUT...got scanned again and now i have a misfire on 3 outta 4 cylinders
also i could hear a small vacuum leak last night, gotta pop off my IC(it seems to be under it somewhere)
need some help power steering spinx2005 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 08-28-2008 04:50 PM
P0546 code, need some advice rexhio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-08-2007 04:15 PM
I Am Looking To Buy This Legacy. Got Questions. Need Some Help. eterglo Newbies & FAQs 12 01-31-2007 09:56 PM
HI. I think I need some stopping power Amazake New England Impreza Club Forum -- NESIC 30 06-01-2004 04:15 PM
pulled 2 CEL's codes... need some help. rhdude Normally Aspirated with bolt-on Forced Induction Powertrain 8 07-05-2003 12:28 PM
