12-18-2016, 07:13 PM | #1 |
Member#: 459950
07 Impreza head gasket parts list?
I recently bought an 07 Impreza 2.5 Auto with 120k miles on it with a head gasket going bad.. I'm to the point where I want to try and fix it myself.. I've done some middle of the road projects but nothing this big and I just wanted some input on what I should expect or any tips etc.
I found a tutorial video of someone replacing the same year and I'm going to follow that along with a haynes manual Am I missing anything on what I should replace while I have it all torn apart? Water pump, timing belt + pulleys, thermostat? Really any info will be appreciated
12-18-2016, 07:20 PM | #2 |
Member#: 398028
Vehicle:2007 2.5i CGM |
if you are able to pull the engine it can be less painful. Still quite a bit of work for a shade tree mechanic.
I work on anything and I WONT do another and I had access to a lift and a Subaru tech. Good Luck!!! |
12-19-2016, 07:34 AM | #3 |
Member#: 283429
South East
Vehicle:2016 Fuji Sunfire 03 Silver |
Here's my "full boat" list when quoting HGs for that model.
2 head gaskets 2 rocker cover gaskets 4 spark plug tube seals 2 intake manifold gaskets 2 exhaust manifold gaskets 1 exhast manifold to midpipe gasket 2 camshaft seals 1 front crankshaft seal timing belt timing belt tensioner upper right idler lower right idler cogged idler water pump water pump gasket thermostat w/gasket 1 gallon Subaru long life coolant or 2 gallons Subaru super coolant. Subaru coolant conditioner (optional) oil filter oil drain plug gasket 5 quarts oil 2 piece timing cover rubber gaskets A/C compressor suction and discharge O-rings (if you discharge system) R-134 refrigerant per label on hood. (if you discharge system) 4 spark plugs NGK, or ND (due @ 120,000) Subaru spark plug wire set (optional but recommended) 14 hours labor + 2 hours prep if heads need resurface. |
12-19-2016, 05:22 PM | #4 |
Member#: 201277
Vehicle:2008 08 QSM 5MT LGT QSM |
Great parts list and really buttons up a EJ25 for a solid 100K more miles.
02-26-2017, 04:17 PM | #5 |
Member#: 407188
BAIC
Vehicle:2007 Subaru metallic sky BLue |
Ok, but my question is, what type of head gasket are you using for this? I'm in the same situation, researching options. Felpro?
10-02-2021, 05:04 PM | #6 |
Member#: 31573
NWIC
Vehicle:I found the meaning of life! |
Good list. I forgot about thermostat
Now if I could figure out how to paste a table in, I'd update the thread with part numbers... |
10-02-2021, 09:18 PM | #7 |
Member#: 515308
Get a complete oem gasket set for 240$ish and I like six star for timing componants
10-03-2021, 02:37 AM | #8 |
Member#: 31573
NWIC
10-03-2021, 08:48 AM | #9 |
Member#: 515308
I get em from dealers on eBay, just picked up another a month ago for 06 forester 2.5 10105ab140
Dig around and find the part number and search that Last edited by benflynn; 10-03-2021 at 08:48 PM. |
10-05-2021, 11:43 PM | #10 | |
Member#: 31573
NWIC
The things you got though, got a link? Online vendors tend to have a pile of the same thing. |
10-11-2021, 10:15 PM | #11 |
Member#: 151818
Vehicle:2007 Impreza 2.5i SE Newport Blue |
I'm doing headgaskets right now and I decided to buy the 1a auto headgasket kit but since it's only $80 and comes with many seals and gaskets, I don't trust the head gaskets for that price so I bought the awdauto six star head gaskets.
https://www.1aauto.com/subaru-saab-h...0/1496879/2007 https://awdautoparts.com/product/sub...l-head-gasket/ |
