Welcome to the North American Subaru Impreza Owners Club Sunday December 16, 2018
Old 08-23-2013, 05:23 PM   #326
omiotek
Member#: 272090
2006 Subaru Forester
SGM
harbor freight or the dremel tool company has a bunch of tiny wire brushes. go kind of slow take your time and buy like atleast 5 of them as they go kind of quick. the dremel ones work far better but are double the price so its up to you what you choose. then use a multi speed dremel. this took me hours to get the block and heads done just so you know. it was not easy.
hope that helps
omiotek is offline   Reply With Quote
Old 08-23-2013, 06:55 PM   #327
omiotek
Member#: 272090
SGM
Patrick here ya go... this is the main one I used but theres a few other shapes I used as well. any menards home depot lowes or harbor freight should have them
on a side note drive shafts painted and
heres whats to come
Old 08-24-2013, 12:26 AM   #328
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
hope that helps
Thanks. I was hoping you had found some clever trick to make it quicker and less time-intensive. There is a HF within 15 or 20min, I'll head over there tomorrow to see about finding some cheap tools.
Old 08-24-2013, 02:39 AM   #329
omiotek
Member#: 272090
SGM
theres a really easy way but it should be done when the case halves are totally apart and thats tape up the case halves so they are sealed up with duct tape and media blast them.
i did mine after my motor was back together. it was an after thought to paint it. it took hours to do because i made sure it was damn near perfect. i got it done in one night after work for the most part. stuck the ipod in the ears and went to town.
Old 08-26-2013, 02:54 AM   #330
GC8Russell
Member#: 366528
loven that hood
GC8Russell is offline   Reply With Quote
Old 08-26-2013, 02:55 PM   #331
omiotek
Member#: 272090
SGM
Thanks man..... I'll start the repairs this week
Old 08-29-2013, 11:07 AM   #332
VIsubi
Member#: 187834
06 2.5i impreza
Red
Originally Posted by Patrick Olsen View Post
A simple question compared to all the fabrication work in this thread - what did you use for the wire brushing of the block? I'm assembling an EZ30D that I think must have sat outside for a bit. The heads got cleaned up pretty well by the machine shop, but the block is pretty crusty. Here's a sample of how it looked when I first got it - it's somewhat better now, but you can see the block has lots of nooks and crannies and I haven't had much luck getting in there.
Thanks,
Pat
trust me motor looks awesome. I did mean to ask you is that a 2.5i motor or an RS motor. 2.5i came with better cams and the piston profile actually changed even though both are EJ253 blocks. Was just wondering. as for calipers. For those who don't have money to buy calipers the stock calipers are not bad at all. what is a poor design are the rotors. they sell big rotor brackets for the RS which can be bumped up to 314mm !!! that will stop your ride just as good as WRX 4 pot and 2 pot. Sold mined and took the money and bought the brackets. with still money over for new pads. Sorry didn't mean to flame. Was just wondering if this block is stock or if you went ahead and did pistons since rods and crank are forged already.
VIsubi is offline   Reply With Quote
Old 08-29-2013, 07:12 PM   #333
omiotek
Member#: 272090
SGM
its a rs block sti rods, pistons and crank.
i swapped out to all stock wrx stuff for brakes.got a good deal with the hubs and supension for them as i wanted the bumped track width.
Old 10-19-2013, 05:30 PM   #334
nate79dawg
Member#: 340555
2011 Impreza OBS
Excellent build so far. I have been watching this for a while and thought I would chime in with Kudos. You have been doing some excellent work.
nate79dawg is offline   Reply With Quote
Old 10-22-2013, 01:55 AM   #335
omiotek
Member#: 272090
SGM
Thanks sir. I appreciate it. I'm continuing the build still as it nears close to putting the power plant back in..... its a lot of little crap not wroth pictures but iI will have some this week. Wanted to do a decent size update.
Old 11-27-2013, 01:11 AM   #336
omiotek
Member#: 272090
SGM
Did a little more on the car.
Shot some high temp silver on the tsudo junk
Refurbished my STI Fuel Pump Assembly
Heres the STI and WRX Fuel pump assemblies next to eachother
Heres the STI WRX and RS Fuel Pump assemblies(listed in order)
The gas tank is all done and ready to go back in the car.
Started getting the interior back in(atleast whats needed for the engine start)
Engine Bay ACTUALLY has stuff in it...Its been awhile since its been like this and honestly im surprised I remember where some of this stuff goes
Gas tank/EVAP in!
Old 11-27-2013, 01:11 AM   #337
omiotek
Member#: 272090
SGM
Rear subframe complete with new SuperPro differential bushings and new GroupN subframe bushings courtesy of Rallispec IN IN IN
Old 11-27-2013, 09:41 PM   #338
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
Huge progress! Looking good!
Jackie leggs is offline   Reply With Quote
Old 11-28-2013, 02:19 AM   #339
omiotek
Member#: 272090
SGM
more to come after this weekend.
thanks!!!
Old 12-01-2013, 03:43 PM   #340
omiotek
Member#: 272090
SGM
anyways heres todays tiny update
clutch is on
outrigger prepped with group n bushings and spacer bushings
new clutch fork, spring, retainers, and act throwout bearing installed
new shifter bushings in back
none of the rest are subaru related...
i love when stuff like this happens.......in our shop.
now after about 5 months from being a beginning welder heres where i am.
Old 12-01-2013, 03:44 PM   #341
omiotek
Member#: 272090
SGM
Old 12-01-2013, 04:13 PM   #342
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
Wow, your welding skills have come a long way!
spyrule is offline   Reply With Quote
Old 12-01-2013, 05:10 PM   #343
omiotek
Member#: 272090
SGM
thanks man. ive been getting more practice and luckily its all on joints. they are far from perfect still bu i hope they get good soon.
Old 12-02-2013, 03:05 PM   #344
Dayglow
Member#: 211395
0000 4wfp Flintstone
Mobile made of stone+wood
Yea man, those welds look pretty clean especially taking into consideration the amount of time you've been at it. I love checking this build, such a thing of beauty.
Dayglow is offline   Reply With Quote
Old 12-02-2013, 03:14 PM   #345
omiotek
Member#: 272090
SGM
thanks man ill have more updates this week.
Old 12-13-2013, 05:30 PM   #346
Rob-nonymous84
Member#: 370607
2009 WRX
This is awesome, its a real inspiration, i want to build an older impreza so bad, but i dont have a garage and i live in pa sooooooooo i loose.
Rob-nonymous84 is offline   Reply With Quote
Old 12-15-2013, 06:26 PM   #347
omiotek
Member#: 272090
SGM
thanks man. yeah im fortunate to have a work space and other much needed tools to my advantage. i really want a 72 skyline gtx gtr to do next
Old 12-17-2013, 11:05 PM   #348
omiotek
Member#: 272090
SGM
more welding progress
had these made too
Old 12-20-2013, 03:32 PM   #349
omiotek
Member#: 272090
SGM
Well the engine has made it an hour away to my dads shop.I mated the transmission up, I got a bunch of other stuff installed aswell....clutch fork boot, dust cover, starter, shifter linkage, driveshaft etc etc.
bought this rack from a member here....2 lines got crushed during shipping. Luckily I was able to reuse my lines. Installed the white line bushings too.
and here is where I left it so you know what's next
Old 12-20-2013, 10:28 PM   #350
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Are you going to install it onto the crossmember then lift it up? I assumed as much, but no crossmember in those pics.
geronimo81 is offline   Reply With Quote
My Supercharger Build Skidd Normally Aspirated with bolt-on Forced Induction Powertrain 150 09-08-2011 12:40 AM
WTB : Omiotek WTB Thread(motor parts) omiotek Private 'Wanted' Classifieds 3 09-06-2011 01:46 PM
VIsubi's Raptor Supercharger build LetItSnow Normally Aspirated with bolt-on Forced Induction Powertrain 57 02-12-2011 08:11 PM
A supercharger build with actual power(Not Mine) ToneWrx02 Normally Aspirated with bolt-on Forced Induction Powertrain 15 01-31-2011 04:09 PM
What's needed to tune supercharge build on a 2.2L? NC_OBS Normally Aspirated with bolt-on Forced Induction Powertrain 1 05-06-2009 03:00 PM
