Welcome to the North American Subaru Impreza Owners Club Tuesday October 27, 2020
Old 10-14-2020, 04:57 AM   #1
Baru-barage469
Member#: 518883
Default My poor Hawkeye (2006 wrx) just wants to break free
So Iíll Iím try to keep this short and sweet, I punch it in 2nd to let the ponies loose and once it gets to around 4000rpms it starts to sputter and wonít let me accelerate any faster, but if I gradually speed up (either shift early or even just donít wind it out ) it doesnít do it. And I am NOT getting a CEL. Any thoughts and advice of course would be greatly appreciated
She has 75000 miles on it oil change and air filter have just been done
Baru-barage469 is offline   Reply With Quote
Old 10-14-2020, 07:23 AM   #2
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
What does it have for mods?
Sounds like it's either misfiring, getting unmetered air, or has a vacuum leak. Giving the age of the car possibly all of them. Do the following:
Replace your plugs and make sure they are gapped properly
Check your turbo inlet for tears. If still OEM, replace as these are known to become brittle with age
Replace MAF sensor
Clean throttle body
Check coil packs for proper function
Replace vacuum lines as they are going to be brittle at this age
If it has a rough or inconsistent idle, clean IACV
snow_bound26 is online now   Reply With Quote
Old 10-14-2020, 07:45 AM   #3
horsePOOGAS
Member#: 450712
04 STi
Replace MAF sensor
Clean throttle body
Solid advice ^^^ But also give us more info on the car and any kind of maintenance history.
horsePOOGAS is offline   Reply With Quote
Old 10-14-2020, 06:37 PM   #4
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
03 WRB GD 205/22T 20G-XT
Also clean your battery terminal connections and check all of your grounds.
monkeyposeur is offline   Reply With Quote
Old 10-14-2020, 08:06 PM   #5
Baru-barage469
Member#: 518883
Thanks for the input guys Iím changing the other three Spark plugs now,
Just bought it about a month ago , i drove it home from Vancouver BC to Prince Rupert BC just below Alaska (about a 16 hour trek) and all seemed to be fine, opened it up a Couple times In 5th gear but wasnít honkin on the motor by any means as Iím new to Subbys. The CEL came on about half way home (where the symptoms started) so I took it easy on her the rest of the way. When I got home I plugged in my code reader and I got a misfire on cylinder 2 so I changed the spark plug on it aswell as an oil change (a litre and a half if that of the blackest oil Iíve ever seen came out of the poor thing) fired it up and seemed too be all Gravey. Had no CEL and sounded A lot better then it did so I took it to the highway tryed again and still a studder/power loss with it in 2nd and going about 85% on it. No CEL this time.Thought maybe fuel filter at first but again Iím new to these machines.
Old 10-14-2020, 08:19 PM   #6
Baru-barage469
Member#: 518883
Default Mods
As far as mods go All the guy Said it had was aftermarket struts , Cobb turbo and Cobb exhaust. He didnít seem to know much about it just wanted it sold so his son wouldnít kill himself in it. No rust and good shape underneath low Kimís so I bought it. I can see a Cobb heat shield and boot off to the left Below the inter cooler
Old 10-14-2020, 09:03 PM   #7
subaru_gc8
Member#: 29292
2004 WRX wagon
check your sparkplugs and coils
Old 10-14-2020, 10:30 PM   #8
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
Does it have a proper tune? Does it have supporting mods for this turbo? A Cobb turbo is a 20g size turbo I believe and that requires quite a lot of supporting mods and a pro tune to run properly. You need to find someone who specializes in Subaru cars and get this car fully looked over. If you don't know what you have you're playing with fire.
