Welcome to the North American Subaru Impreza Owners Club Wednesday October 28, 2020
Old 09-28-2020, 06:33 AM   #1951
ALA81
Member#: 518507
2017 WRX
WR Blue Pearl
Just a good wash n seal. Is it just me, or does the clear coat on a newer WRX seem really soft?
ALA81 is offline   Reply With Quote
Old 09-29-2020, 07:08 AM   #1952
Norm Peterson
Member#: 498642
'19 WRX Ltd 6M dgm
'08 Mustang GT (the toy)
Checked the oil level (good), added a few fluid ounces of coolant, and adjusted the tire inflation pressures (adding an extra psi or so in anticipation of temperatures continuing to drop).
Norm
Old 10-05-2020, 07:48 PM   #1953
YungBoba
Member#: 450808
2017 WRX Premium
WR Blue Pearl
Took her to the shop to get an oil change and have some new suspension bits installed: lower control arms, end links, and sway bar, plus an alignment of course.
YungBoba is offline   Reply With Quote
Old 10-06-2020, 11:33 AM   #1954
oichan
Member#: 492327
19 WRX 16 STI
17Golf-R 16FiST 20Supra
I have a 16 STI and 19 WRX. Paint harness/durability is about the same if not identical.
I did have my dealer temporarily ruin the lower sections of my rear bumper and fender where their tire dressing slinged onto the paint and stained it (my WRX is a pearl white). I tried clay and polish but it was literally 'stained' into the clearcoat so I used my friend the Sun to UV it out. Stains were completely gone after a few weeks.
oichan is offline   Reply With Quote
Old 10-06-2020, 03:32 PM   #1955
ItzBlue
Member#: 519173
Been tackling the suspension components myself. Just finished up the rear with all new lateral links, trailing arms, whiteline sway bar /mounts and coilovers. The front is next for me.
ItzBlue is offline   Reply With Quote
Old 10-06-2020, 11:56 PM   #1956
lbrown39615
Member#: 515256
2006 WRX
Installed an air oil separator. Looks like I could use an engine bay cleaning.
lbrown39615 is offline   Reply With Quote
Old 10-07-2020, 12:19 AM   #1957
WallopingTuba
Member#: 488146
2015 WRX
Red
Changed the oil and filter, cleaned MAP and MAF, changed spark plugs fork me that was a pain in the.
WallopingTuba is offline   Reply With Quote
Old 10-08-2020, 10:43 AM   #1958
oichan
Member#: 492327
19 WRX 16 STI
I need to do my Forester's first oil change this weekend. Going to see if I can drain the oil without lifting the car, but probability very low due to my pumpkin head. I'll just use my ramps.
Going to install a Fumoto valve as well.
Old 10-09-2020, 08:19 AM   #1959
oichan
Member#: 492327
19 WRX 16 STI
Yesterday washed the car cover on my WRX using a MF wash mop (while still on the car to make it easier), allowed it to dry 3-4 hours before stowing it away possibly for good.
Hardwired a battery manager umbilical to the battery, made a cord tunnel under my garage door to prevent pinching the cord (and any snow/ice bug entry), wrapped the entire cord with plastic coil wrap as it will be exposed to many cycles of melted snow and ice, then cleaned up the wheels, interior and took her out for a spin. Car felt good. Going to look for a radar detector.. probably will go with the MAX360c again.
Old 10-09-2020, 11:10 AM   #1960
oichan
Member#: 492327
19 WRX 16 STI
Did my 2020 Forester Limited's oil change this morning at shy of 4000miles. Fumoto F108S fit just fine. My pumpkin head would not fit under the car without lifting to get sufficient clearance to get a good visual, but next time I won't have to raise it because I have the Fumoto valve installed.
Old 10-09-2020, 08:39 PM   #1961
Drcookes
Member#: 519263
I got in and drove to work. Got out at work and realized I need to wash it this weekend. SMH
Drcookes is offline   Reply With Quote
Old 10-10-2020, 12:58 PM   #1962
SwappedOBS
Member#: 234916
SwappedOBS is offline   Reply With Quote
Old 10-10-2020, 04:00 PM   #1963
oichan
Member#: 492327
19 WRX 16 STI
Took my WRX for a drive this morning.. I quickly remembered this car has weak brakes and inconsistent throttle response at lower RPM even with AP Stage1+.
Overall a good daily driver, but not much of a weekend toy.
Old 10-10-2020, 05:23 PM   #1964
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Never changed the brake fluid on my 2016 STI. The inside bleeders valves on both front calipers were nicely seized. Don't be like me.
Scorpius is offline   Reply With Quote
Old 10-10-2020, 06:00 PM   #1965
oichan
Member#: 492327
19 WRX 16 STI
Yeah, mine was seized on the driver side when I did my 16' STI's brakes a few months ago as well.
I ended up using a deep socket to break the nozzle loose before hooking up a bleeder tube so I do not shear the hex on the bleeder with an open wrench.
Old 10-11-2020, 07:36 PM   #1966
Kochi_STi
Member#: 369411
2002 WRX STi Limited
Replaced my Kartboy front endlinks with Cusco spherical ones yesterday.
Dropping the car off tomorrow to get the Do-Luck trunk's clear coat sprayed on.
Kochi_STi is offline   Reply With Quote
Old 10-13-2020, 01:14 PM   #1967
oichan
Member#: 492327
19 WRX 16 STI
Kochi- GL with your clear coating the CF trunk lid. Hope it turned out for ya.
Old 10-15-2020, 12:47 AM   #1968
sr20122s
Member#: 395051
Gave her a bath and got her cleaned up to sell!
sr20122s is offline   Reply With Quote
Old 10-15-2020, 02:42 AM   #1969
Kochi_STi
Member#: 369411
Thanks. I hope so too. I'll find out next week. Driving around in the shop's beater for now.
Old 10-15-2020, 11:19 AM   #1970
Xake
Member#: 515707
Washed it, lmao.
Xake is offline   Reply With Quote
Old 10-15-2020, 12:13 PM   #1971
purist_
Member#: 498218
2018 WRX Premium
Pure Red
New battery, covered under warranty. Car will be two years old on Nov. 13th, 3400 miles. Ill need to use a battery tender from here on out. Weekly trips to and from band practice won't cut it for these batteries.
purist_ is offline   Reply With Quote
Old 10-15-2020, 01:04 PM   #1972
oichan
Member#: 492327
19 WRX 16 STI
I got a new Escort MAX360c. I still need to buy another one when my STI comes out of hibernation next Spring.
Old 10-16-2020, 04:27 PM   #1973
Griffin27WV
Member#: 519440
Finally completed my first engine removal on my 08, overall everything went smooth. Only took around 4 hours. Would have went a lot quicker if my lower engine mounts would have cooperated more. Spent a solid hour cutting one out laying in a puddle of coolant as pb blaster kept dropping on my face..... next up is replacing HG along with anything else I find leaking.
Griffin27WV is offline   Reply With Quote
Old 10-16-2020, 07:54 PM   #1974
jdm05
Member#: 180155
05 Jdm Sti 2.0
Nice little touch added
jdm05 is offline   Reply With Quote
Old 10-16-2020, 08:21 PM   #1975
Db1991
Member#: 512297
Default Help
Help... 15 STi won't make more than 5lbs of boost. Ran a smoke test no visible leaks. Car was fine one day sat over night got in the next day and it is noticably quieter. No exhaust pops nothing almost like a non turbo car. No weird noises, no cel, dam is at 1.0. could the BCS taken a ****? I'm lost my mechanic and I can't figure it out. Stock car with muffler deletes. 60k miles. Anyone had this issue any help would be appreciated. Thanks.
Db1991 is offline   Reply With Quote
