Welcome to the North American Subaru Impreza Owners Club Wednesday October 28, 2020
Old 07-15-2019, 11:27 AM   #1
AmbitiousSTI
Member#: 491880
01 RSTI
Default Innovate mtx-d ethanol kit
Anyone run this oppose to the Cobb flex?
AmbitiousSTI is offline   Reply With Quote
Old 07-15-2019, 11:41 AM   #2
Aczwild
Member#: 71721
98 RSTi, 13 Sierra
20 Ascent Touring
I’d recommend their ECF-1 to add in fuel pressure and a wideband as these are very important if you’re looking to run E85. The MTX-D will work since it has the 5v output signal that the AP/tuner needs
Aczwild is offline   Reply With Quote
Old 07-15-2019, 12:27 PM   #3
subaru_gc8
Member#: 29292
2004 WRX wagon
thats not a flex fuel kit. you know that right?
subaru_gc8 is offline   Reply With Quote
Old 07-16-2019, 11:42 AM   #4
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
That's just a gauge.
bdubblu is offline   Reply With Quote
Old 07-16-2019, 12:18 PM   #5
Aczwild
Member#: 71721
98 RSTi, 13 Sierra
20 Ascent Touring
I guess I should have clarified as well with my post. These gauges are not a direct “swap” for the Cobb kit, but they can be used to run E85 as you can use the 5v output and wire it in through the TGV connector as Cobb does with their kit. See the DIY Flex Fuel Kit for under $100 thread for reference. Obviously you’ll need to do additional wiring and a tuner that knows that they’re doing
Old 07-17-2019, 06:11 PM   #6
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Right... so I don't see why you couldn't make it work.
Old 07-17-2019, 06:16 PM   #7
1VIPWRX
Member#: 107554
yellow
Doing what your thinking as we speak. I have that setup now and just had the harness made to plug into the rear o2 plug. you will need to purchase a flex fuel sensor and some hardware to get it hooked up to the fuel lines.
1VIPWRX is offline   Reply With Quote
Old 07-18-2019, 03:36 AM   #8
AmbitiousSTI
Member#: 491880
01 RSTI
It has the full kit with the sensor that’s just the photo
Old 07-18-2019, 03:38 AM   #9
AmbitiousSTI
Member#: 491880
01 RSTI
I figured my v3 AP could read any ethanol sensor I just didn’t know how well this one worked or where I would wire the plug for it. Once you get yours set up would you pm me a picture?
Old 07-18-2019, 03:39 AM   #10
AmbitiousSTI
Member#: 491880
01 RSTI
V6 ej207 no tgvs where would I wire it to if I did go this route.
Old 07-18-2019, 03:40 AM   #11
AmbitiousSTI
Member#: 491880
01 RSTI
I’ve also contemplated getting the AEM sensor seeing how that is more known and the same price range would the wiring be the same as the innovate?
Old 07-18-2019, 11:28 AM   #12
Aczwild
Member#: 71721
98 RSTi, 13 Sierra
20 Ascent Touring
Well, that changes things a little. What ECU are you running and how are you planning to tune the car? Depending on those answers you may not be able to run E85, or anything above the standard pump 93 with E10
The Innovate products are pretty rock solid that there is no need to go with AEM (honestly I’ve had better luck with Innovate than AEM).
Old 07-18-2019, 11:51 PM   #13
AmbitiousSTI
Member#: 491880
01 RSTI
02 wrx harness and ecu with v3 AP
Old 07-30-2019, 11:06 PM   #14
1VIPWRX
Member#: 107554
yellow
Innovative gauge has a output for the ecu . Connect that to the rear 02 sensor plug . Harness i had a small harness made .
Old 09-07-2020, 10:33 PM   #15
Dori Ninja
Member#: 73974
04 RSTi
You did this for the non-tgv set up, yeah??
Dori Ninja is offline   Reply With Quote
Old 09-16-2020, 05:04 PM   #16
1VIPWRX
Member#: 107554
yellow
Na , did this to have flex fuel
Old 09-17-2020, 06:07 PM   #17
Fino
Member#: 417685
'03 V7 STi, 4.44
Sonic Yellow
So this works fine with a subaru ECU? The issue with the GM flex fuel sensors is that they don't output a 0-5V signal that the ECU reads, just a PWM signal. Does the Innovate gauge convert the signal so it can be directly wired in and used to tune with? If so this is great for people that don't want to spend the money on the Cobb kit but are still handy enough to splice a few wires.
For those wondering, if you don't have TGV connectors anymore you can use the rear O2 sensor wire.
Fino is offline   Reply With Quote
Old 09-17-2020, 06:52 PM   #18
Aczwild
Member#: 71721
98 RSTi, 13 Sierra
20 Ascent Touring
Yes, the innovate gauges convert the signal to a 0-5v output. Just had my ‘02 WRX swapped RS tuned for flex fuel using the e85 output signal through a tgv sensor and the wideband output through the rear o2 sensor (as previously mentioned, I’m using the ECF-1). Note to do this on the early model 16bit ECU’s you have to go opensource
Old 09-18-2020, 11:57 AM   #19
absubie
Member#: 196235
2016 WRX Limited
Pure Red
I just recently installed one of these kits in preparation for flex on my 16 WRX. I just need to wire up the harness for the rear o2 before it's time to start tuning. Found a sweet deal deal on Amazon for like $160 with the sensor, so I couldn't pass it up. Accuracy seems pretty good for reg e10 pump. Range is always between 10.2-10.8. Fabbed up a diy "cubby pod" replica for it.
absubie is offline   Reply With Quote
Old 09-28-2020, 06:28 PM   #20
Dori Ninja
Member#: 73974
04 RSTi
But on an engine that did not come with tgvs is what I'm asking, as to why you wired it this way instead of into the tgv connector...
Old 10-18-2020, 11:46 AM   #21
ChaHlubPaj
Member#: 483820
2018 WRX Limited
CWP
Have steps on how to accomplish this? Very interested in how you went about it.
ChaHlubPaj is online now   Reply With Quote
Old 10-22-2020, 12:47 PM   #22
absubie
Member#: 196235
2016 WRX Limited
Pure Red
For the wiring, I used two tap a fuse into the dash fuse box. Bottom one for power in an empty 12v slot - attached to red wire of gauge, and one upper one in the illumination fuse slot for the light dimmer - attached to the white wire of gauge. Both need a 5v fuse in the outer slots of the tap a fuse for the gauge. I just grounded it to a frame bolt behind the center console where it's mounted.
For the gauge pod, just cut it out of a spare piece of metal I had leftover from the box I fabbed for my Perrin intake. Picture below before install.
