Welcome to the North American Subaru Impreza Owners Club Wednesday October 28, 2020
Old 08-23-2020, 04:47 AM   #1
enginewitty
Member#: 516851
Default mileage vs. issues list
If one doesn't already exist, can we get a common issues list for our cars posted on here?
I realize how we drive, how its modded and a host of other things will affect the wear and tear differently, but I'm thinking along the lines of Subaru's notorious head gasket problem. What other things commonly go? for what years, models and when?
enginewitty is offline   Reply With Quote
Old 08-23-2020, 07:31 PM   #2
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
I have a 2006 WRX Limited wagon I bought new. In over 200k miles, every piece of running gear has been replaced -- some more than once. Even if you buy something 5 years old, it's a gamble. Once you hit 10, 15 years or more it's a certainty you are buying a money pit.
I guess you can say for modding a WRX, a big issue can be the 5MT.
Dave D. is offline   Reply With Quote
Old 08-24-2020, 03:04 PM   #3
mr_electric_wizard
Member#: 516877
Yep, totally. My mechanic buddy always says to wait until things break before replacing things. Obviously this doesn't hold up when it comes to brakes and suspension, but for engine stuff usually. These car's ain't cheap to rebuild.
mr_electric_wizard is offline   Reply With Quote
Old 08-24-2020, 03:22 PM   #4
Jack
Add Lightness
Member#: 13699
not my president
(From General)
It really depends on the model. From memory with my own cars:
NA EJ25: head gaskets anywhere from 80k miles up.
everything: the end links tend to break. I've seen them on 2 different gen outbacks around 70k miles.
Wheel bearings: They typically last about 4 miles in Subarus.
Turbo cars with screens in the oil feed lines: Figure problems develop depending on how long you wait to change oil.
Old 08-29-2020, 11:41 AM   #5
NoTorq
Member#: 456717
15 Sti
15 STI
104K MILES
Protuned at 60k
Steering rack fail
Front strut bearings fail
Currently have to add 1qt oil every 750 miles
NoTorq is offline   Reply With Quote
Old 08-29-2020, 08:36 PM   #6
rtv900
Member#: 428511
2016 STI
16 sti
112k miles
one set of pads and rotors
otherwise nothing more than general maintenance
rtv900 is offline   Reply With Quote
Old 09-17-2020, 12:27 PM   #7
krenberry
Member#: 394464
2016 WRX catless lol
6MT Crystal Black Silica
16 WRX - bought brand new
Currently at 115k miles (Stg 2 since 40k)
Nothing other than general maintenance (brakes, rotors, filters, etc.)
Take care of your car, and your car will take care of you!
krenberry is offline   Reply With Quote
Old 09-17-2020, 12:44 PM   #8
samb
Member#: 177235
2016 Focus RS
2002 WRX Wagon
2002 WRX Wagon
229,000 miles, bought it in early 2008 with 127,000mi on it.
- Center Differential
- Steering Rack
- Brake Calipers (rust)
- Parking Brakes (rust)
- Accessory Belt
- Shocks and springs
- Front Axles, ball joints, and tie rods (rust)
- Windshield Wiper Transmission
- HVAC blower motor relay
- A/C system (eventually removed it)
- Leaking seals
- Coolant Expansion Tank (corrosion)
- Timing belt (replaced on schedule, but found it had skipped a tooth during a rally-X 50,000 miles earlier )
- Rear end links (age)
I'm sure there's some stuff I'm leaving out and other things that would fail had I not already replaced them. I keep a detailed log but I'm too lazy to go get it. If I could sum up used turbo Subaru ownership with one word it would be "tinkering." I'm constantly tinkering with the thing. That's fun for me though and it's not my daily driver so I don't mind having it sit for long periods of time.
samb is offline   Reply With Quote
Old 09-17-2020, 01:12 PM   #9
raulz888
Member#: 509899
2017 WRX
2017 WRX with 60k miles. Had the AC compressor go out, which resulted in almost full AC system replacement. No other problems. Getting ready to do plugs, pads, differential/transmission fluid in short order.
raulz888 is offline   Reply With Quote
Old 09-17-2020, 01:32 PM   #10
18cbs
Member#: 478639
2018 sti
cbs
2018 sti
10.8k miles
Stock dd
On 2 or 3 occasions there was an error with SRH. Problem went away by restarting.
On 2 occasions I couldn't get into any gear even after restarting. I had to start in 1st so it can do its lunge and afterwards was able to move.
18cbs is offline   Reply With Quote
Old 09-17-2020, 03:45 PM   #11
Jedi03
Member#: 491095
2009 STi Blue
09 sti modded
160k miles
all fluids flushed at 112k when purchased
timing belt @112k
3 alternators across the last 2 years, probably autozone issue
power steering pump o-ring failed ~140k
AC clutch went out ~130k
Driveshaft replaced at ~120k more recent inspection found all bearings in need of replacement
headgaskets done ~130k due to dropping stuff in the cylinder while intake was off
Secondary air pump valve failed ~120k...did airpump delete
Found cracked firewall ~120k and fixed with rivets
Everythign else has been replaced for longevity and reliability of the engine!
Love driving the car and have been told 2x that based on how i take care of it will be my forever car lol!
Jedi03 is online now   Reply With Quote
Old 09-17-2020, 04:07 PM   #12
knesek
Member#: 508145
2007 WRX Wagon
Satin White Pearl
my 5 speed is on the edge at 81k miles.
Timing belt at 75k
Cv joints at 75k
I think the alteratnor is having trouble starting at 78k
knesek is offline   Reply With Quote
Old 09-28-2020, 01:55 PM   #13
marcusuriah
Member#: 514653
Have you walnut blasted your intake valves?
marcusuriah is offline   Reply With Quote
Old 09-29-2020, 09:15 AM   #14
krenberry
Member#: 394464
Yes. Valves cleaned at 100k with a compression test and 2nd spark plug change. Everything looked good!
Old 10-02-2020, 08:48 PM   #15
Bluefoton
Member#: 141373
2019 Crosstrek Sport
6MT
2008 2.5i. Lasted 250 000 km till HGs blew (2019).
Beyond that, no repairs needed whatsoever. Only changed the clutch, brakes, some bushings, and all the usual maintenance items.
Old 10-12-2020, 12:03 AM   #16
Casanibanton
Member#: 519318
125k 07 LGT, front axles, clutch fork, clutch
Casanibanton is offline   Reply With Quote
