Welcome to the North American Subaru Impreza Owners Club Tuesday December 18, 2018
Old 01-14-2007, 12:35 AM   #251
AKESREX
Member#: 110401
P silver -original owner
Nope. Apparently you only find that item on the STI. Wish it were that easy.
.........and unfortunately the insane tapping continues
AKESREX is offline   Reply With Quote
Old 01-16-2007, 04:35 PM   #252
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
3. passenger Door rattle - this seems to be wiring rattleing against the inner door panel or the cover. Use some sticky foam and wrap wires..
Can someone answer...where does this rattle sound like it is coming from? I have a rattle in the front passenger door that sounds like it is coming under the controls of the door but possibly above and to the right of the speaker...it could be loose speaker equipment from the install of my MB quarts, but I was wondering if it could be this as well.
Has anyone had this and notice a larger volume of rattle when the bass is up? I don't notice anything with music turned off.
Matth3w is offline   Reply With Quote
Old 01-16-2007, 07:45 PM   #253
SUBYDOODIE
Member#: 71490
05 cgm wrx
rubbing axles haha
will warranty cover the rearview mirror rattle when it only rattles when i turn up the radio? (upgraded my system with a 12in sub)
SUBYDOODIE is offline   Reply With Quote
Old 01-16-2007, 07:49 PM   #254
jezzy
Member#: 121883
doubt it.. you decided to install a 12" aftermarket sub which causes the rattle that you're experiencing..
jezzy is offline   Reply With Quote
Old 01-16-2007, 07:57 PM   #255
Gregor
Member#: 100824
If you haven't performed any sound deadening, that's the first place to start. if you have performed sound deadening, you might need a little more. Or at least firm up the speaker baffle, door card and interior door panel. Also locate any resonant or rattling pieces and quiet them down.
Gregor is offline   Reply With Quote
Old 01-16-2007, 11:11 PM   #256
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
any particular culprits>?
Old 01-17-2007, 04:28 PM   #257
Gregor
Member#: 100824
For a speaker rattle, its a good idea to take care of the entire door, and not focus on a single rattle. This will help improve the speaker's performance, block out noise, and address the other rattles that will occur with higher levels of vibration (larger bumps in the road, bigger amp).
Check out what these guys have done. That should give you a good starting point. If you still prefer to do it piece meal, take off the door card and start tapping with your fingers in the area you heard the rattle. On any spot that rattles add some silcone caulk, sticky back felt, or sticky back foam. Use zip ties to tie up any loose wires. Look for any areas where there will be plastic to plastic contact and use one of items mentioned to add a cushioning layer.
Old 01-17-2007, 07:30 PM   #258
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
thanks for the advice. I seemed to have fixed the problematic rattle. I used felt pads all around my crossover for my tweeter and zip tied wires.
now I just need to take care of the roof rattle caused by too much bass. maybe I'll drop my headliner and put deadening up there. not sure if that will help or not.
Old 01-17-2007, 07:52 PM   #259
jimtweet
Member#: 52225
2004 wrx 1966 stang
1973 porsche
i have the fix to all rattles,....
turn the damn radio up...
i was about as anal as someone could be with rattles, i took apart my ENTIRE interior, from carpet to headliner to dash, gutted, and tried to fix every little one, it worked for about a month, but between coilovers, 40 series tires, and the amount of work done to our cars....i have jsut learned to deal with them, you will drive yourself nuts tryin to find them and fix them
jimtweet is offline   Reply With Quote
Old 01-17-2007, 09:23 PM   #260
Matth3w
Member#: 94597
2003 Corvette Z06
Black/Black
the problem with turning the radio up, is it INCREASES the rattles
Old 01-18-2007, 10:02 AM   #261
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Ummm...No.
Hank3 is offline   Reply With Quote
Old 01-18-2007, 02:31 PM   #262
nich0lai
Member#: 111538
2003 wagon go vroom
bug covered
I have two noises I would really appreciate some help with.
The first is my tach/speedo seems to buzz during decel if I go above 4k rpm's. It is so bloody annoying. Sometimes I can hold the buzz if I hit the magic rpm, usually about 4200.
The second is my passenger door seems to vibrate to certain tones on the stereo, only certain tones though!
Both seem like harmonic vibrations but the first one is REALLY making me nuts. If a dealer replaces the speedo does it go on my title as unverified mileage? I have had them pull out and reinstall the darn thing, they couldn't find anyting wrong.
Thanks!
nich0lai is offline   Reply With Quote
Old 01-18-2007, 11:51 PM   #263
jason.g
Member#: 88467
2005 WRX
All black everything.
If the dealer replaces your speedo, they have to , by law, have the new speedo set to your exact current mileage. We have done it numerous times under warranty at my dealership...it happens more often that you think.
jason.g is offline   Reply With Quote
Old 01-19-2007, 02:24 AM   #264
nich0lai
Member#: 111538
2003 wagon go vroom
bug covered
Thanks alot~!
Old 01-23-2007, 02:06 PM   #265
Hank3
Member#: 16157
'03 Mazda P5 <><
Originally Posted by Carizme View Post
I found the "VIN plate rattle" It in fact does not have anything to do with the actual VIN plate. The rattle is coming from the vent pointed at the driver side window. The vent tube is an attachment to the main vent. The point where the smaller vent tube slides into the main vent was causing friction. Thats why when you push down on the VIN you are actually placing pressure indirectly onto the dash piece that holds the defogger vent and the rattle goes away
The Solution: Remove the defogger vent. Then wrap it with Adhesive-backed felt on the outer tube area. The felt was purchased at Wal-Mart for $.79 its in the crafts area. Re-install tube and presto!
Results: No rattle, well at least not that one anymore
Bump on how to get this piece out
Old 01-23-2007, 05:01 PM   #266
only1agam
Member#: 56183
Originally Posted by Flat4 STI View Post
My 04 WRX has/had several.
Drivers side door handle,where you pull the door closed would rattle.
Fix:3m double sided tape on the bottom of it where the screw pokes through.
Steering column top plastic rattled.
Fix: 3M double sided tape,Once you take off the top piece of plastic, nearest the steering wheel theres a piece of plastic that sticks up,I used two layers to touch the column plastic pieceAlso about the middle of the steering plastic piece i put another piece of 3M there also.Kinda hard to descibe.
Rear deck area rattle where third brake light is
Fix: Center seat belt plastic cover in trunk was loose,the piece that covers the retract part,Silicone around top edge to hold it in place.
Many more to find still but now i have some ideas where to look
Thanks to all
where exactly is this? b/c mine rattles
only1agam is offline   Reply With Quote
Old 01-27-2007, 06:40 PM   #267
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
14 Hyundai Borenata
Need help, massive rear deck rattle.
It sounds like the ENTIRE rear deck is slapping something when the bass hits. Not just some small plastic cover, but as if the whole rear fibreboard (or whatever it is) deck is hitting metal. I tried to alleviate this before, but it didn't help at all.
ScubaruImpreza05 is offline   Reply With Quote
Old 01-28-2007, 11:05 PM   #268
ScoobySnacker
Member#: 105303
2003 WRX
+1
BTW, i have not seen this thread and it is doing wonders for my mental state while driving. When i hear rattels i begin to wonder around the road and make Maneuvers that i usually wouldnt
ScoobySnacker is offline   Reply With Quote
Old 01-30-2007, 05:47 PM   #269
Chas Metivier
Member#: 27504
2002 WRX sedan
WR blue
Originally Posted by WRXRallyBlue View Post
I have a rattle in that area, but if I open the glove box the rattle doesn't go away - if anything it gets worse. If I whack on the top of the dash where the airbag is it induces the rattle. Any ideas?
I have this same rattle, I slap the lower left corner of the airbag and it gets worse (is induced). I have taken out the glove box, upper vents and clock pod and cup holder to try and isolate it, no luck. It sometimes goes away if I run the heat through the vents for several minutes, perhaps this expanded some plastic and temporarily stops the rattle.
ANY OTHER SUGESTIONS??
Chas Metivier is offline   Reply With Quote
Old 01-30-2007, 06:39 PM   #270
mikecoscia
Member#: 105846
2006 Impreza WRX STi
WRB w/gold rims
I just noticed this too esp with the colder weather. It does go away after the car heats ups. If I open the glove box still rattles. Could it be the passenger side defroster?
mikecoscia is offline   Reply With Quote
Old 01-30-2007, 07:07 PM   #271
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
I haven't figured it out..
WRXRallyBlue is offline   Reply With Quote
Old 01-30-2007, 07:16 PM   #272
LowUFO
Member#: 36495
2004 WRX
Black Pearl
I get a sound like the windshield creaking/cracking as I go over bumps coming from my passenger side dash area too. Only hear it when its minus whatever outside. I'm ready to go Columbo and pull the whole dash out on my day off-Friday..
I'll post results or lack thereof..
LowUFO is offline   Reply With Quote
Old 01-30-2007, 09:48 PM   #273
drewzter
Member#: 39879
2008 Infiniti G37S
Graphite # 73 FS
Default Are you kidding?
Originally Posted by STIdrivr View Post
I have a 04 STI with 30,100 miles. The little ring on the shift nob that you can spin around rattles. It sort of clicks in place but not really tight so it still rattles a little. Should I just super glue it or does it need to be able to move around?
Only glue it if you don't need a Reverse gear.
drewzter is offline   Reply With Quote
Old 01-30-2007, 09:54 PM   #274
Chas Metivier
Member#: 27504
2002 WRX sedan
WR blue
Coming home today I pressed on that thin strip of plastic along the innermost edge of the wind shield and it went away temporarily. I think it might be that piece others have had trouble with. Is it put in with those rattly white plastic clips?
Old 01-31-2007, 12:44 AM   #275
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
ive been going nuts over this one weird LOUD rattle.
If i stay consistant at a high RPM with partial throttle, i hear a loud vibration/rattle coming from my rear driver side door/b-pillar area. could be somewhere else but when i drive it sounds like its coming from there. and let me tell you.... its LOUD
Subie FA20 is offline   Reply With Quote
SF5 forester thread doublej Member's Car Gallery 20 07-26-2012 02:30 PM
Can We Get a DIY Thread Going? STIckySTIfee General Community 17 04-03-2008 01:00 PM
Can we get another ice thread going? forced4 Texas Impreza Club Forum -- TXIC 0 01-17-2007 12:41 PM
Can we get an OT sing-a-long going? BEGIN! snvin Off-Topic 27 12-01-2005 02:15 PM
