Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 10-18-2018, 10:37 AM   #1
theevbo
Member#: 485290
Default Aftermarket HID headlights issue
Hey guys,
I purchased a 2011 WRX a few months back and the previous owner had installed some sort aftermarket HID headlight kit. I’m not super familiar with these kits but it looks like the stock projector housings with HID bulbs. Drivers side went out yesterday and when I pulled off the rear cap it looks like the wires have been spliced together.
I’ve never been very happy with the light output, probably the worst of any car I’ve ever had. Returning to stock is perfectly acceptable but I worry that since things have been cut and spliced I might run into some issues.
What are the options on replacing these? Any advice appreciated.
https://ibb.co/kuigO0
https://ibb.co/gfrCVf
https://ibb.co/etb1O0
https://ibb.co/fpweAf
theevbo is offline   Reply With Quote
Old 10-18-2018, 02:46 PM   #2
theevbo
Member#: 485290
Upon further digging and pulling things aside it looks like there are two plugs that attach further down stream, so to speak. So I reckon they're not actually spliced after all. All I may need are H11 replacement HID kit bulbs. Yes?
Old 10-18-2018, 03:15 PM   #3
Obviously Tyler
Member#: 395955
2018 Mazda 3 GT
2018 Crosstrek
If you want to avoid problems with HID bulbs, you should go back to the stock halogen.
Or try LED bulbs, good ones. Less messy and less heat.
Obviously Tyler is offline   Reply With Quote
Old 10-18-2018, 03:40 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Option 1. Toss the HIDs and put the proper halogen bulbs in, done.
Corollary to Option 1- Instead of H11's, install a set of H9's for a true lighting upgrade without the downside of aftermarket HID's.
https://forums.nasioc.com/forums/sho....php?t=2083911
Old 10-18-2018, 07:57 PM   #5
theevbo
Member#: 485290
Is it that easy to just revert to stock? That would be my preference.
Old 10-18-2018, 08:34 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It depends whether the factory harnesses and connectors are intact and not hacked up. If they are ok you should be able to just unplug the HID's and plug in the halogens. If they're chopped up you'd need to get replacement H11 connectors and properly splice them onto the harnesses. Wiring/electrical not your thing? Find a good local shop and have them do it the right way.
The use of wire nuts on that installation is horrific.
Old 10-19-2018, 11:03 AM   #7
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
On my 2009 Impreza, I used an HID kit without problems.
35 watt 4300K H11
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
$50.51 with shipping
CRAZYHAWK is offline   Reply With Quote
Old 10-20-2018, 06:39 AM   #8
theevbo
Member#: 485290
Looks as if the factory harnesses are no longer there. Iíve got a set of hid bulbs coming tomorrow as a interim fix until I can get them rewired back to stock. Thanks for the advice.
Old 10-20-2018, 12:28 PM   #9
CRAZYHAWK
Member#: 198067
WHITE Premium
You will need AMP bulbs.
