10-22-2004, 06:35 PM | #1 |
Vendor Sales Rating: (95)
Member#: 33174
RMIC
Vehicle:Chat Email or Phone! 888-457-2559 |
New Perrin STi Short Shifter! Kartboy Legacy Shifters! More inside
We just got the new perrin STI Short Shifter in stock. It mounts to bottom of the stock shifter. There is no modification required for install. They are 79.99 Shipped inside the 48 states. Let me know if you have any questions.
We also have the following in stock. Exedy WRX Hyper Single(inludes Clutch, Flywheel, Pressure Plate, Pilot Bearing, Throw out bearing) - CALL FOR PRICING!!!!!! Exedy WRX Twin Plate(inludes Clutch, Flywheel, Pressure Plate, Pilot Bearing, Throw out bearing) - 1500.64 Exedy STI Single Plate(inludes Clutch, Flywheel, Pressure Plate, Pilot Bearing, Throw out bearing) - 1135.26 SHIPPED!!!!! Exedy Impreza Lightweight Racing Flywheel(2.5L Only) - 411.08 Shipped Exedy Impreza Single Plate Organic Clutch(2.5L Only) - 330.75 Shipped Exedy WRX Lightweight Racing Flywheel - 411.08 Shipped Exedy WRX Single Plate Organic Clutch - 498.01 Shipped Cusco WRX Hyper Single Clutch Set - 1321 Shipped Cusco WRX Twin Plate Clutch Kit - 1748 Shipped STI Engine mounts - 132.99 Shipped STI Pitch stop mount - 47.45 Shipped STI Transmission Mount - 69.30 Shipped Kartboy WRX or Impreza Shifter and Bushings combo - 120 Shipped Kartboy STi Shifter and Bushings combo - 175 Shipped Kartboy WRX/Impreza/legacy Shifter Bushings - 30 Shipped Kartboy WRX/Impreza Shifter - 100 Shipped Kartboy STI Shifter - 150 Shipped Kartboy STI Shifter Bushings - 32 Shipped Kartboy 05+ Legacy Short Throw Shifter - 110 Shipped Let me know if you have any questions. Ben 801.619.1779 [email protected] aim: rallysportdirect www.rallysportdirect.com Last edited by RallySport Direct; 02-23-2005 at 12:59 PM. |
11-09-2004, 03:49 PM | #3 |
Member#: 33174
RMIC
Really with the way the perrin shifter is designed. You can adjust it so short that it would be to hard to shift it from gear to gear. It is from 0%-80%. at some point with will have to modify the body to get it to 80% but it is posible for you to get to that point.
That is what makes this shifter different from the kartboy and the kartboy knockoffs. You can set it to what you feel comfortable with. Some people like just to to have it set for them and install it and forget about it. And others like to adjust it. Really the choice is up to you. But we do offer both products for this reason. Let me know if this answers your quesiton. Ben |
11-23-2004, 01:21 AM | #6 |
Member Sales Rating: (3)
Member#: 67128
Vehicle:2001 996TT seal |
wanna know more on the perrin SS
how reduced does it come, out of the box?? can it be adjustedd easily?? can i use the KB bushings with it (stock stinks) PM me info, and a price, with KB bushings, okay?) ESE |
11-23-2004, 09:55 AM | #7 | |
Member Sales Rating: (5)
Member#: 34960
MAIC
Vehicle:What would baby Jesus say of OT? |
11-23-2004, 12:44 PM | #8 |
Member#: 33174
RMIC
Esemes - you got a PM
Undepelo - The picture in the quote is the STi shifter. The one is the picture you posted is the WRX one. Ben |
12-05-2004, 04:09 AM | #11 |
Top Scoob 019
Member Sales Rating: (2)
Member#: 43630
Vehicle:2004 GT40R-built 2.5 604 whp @1.8 BAR on VP109 |
hey ben.
interested in the kartboy shifters and bushings. wot would be the delivery to australia and time frame for arrival? you can pm me back if you like. Regards Tino Last edited by tino; 12-05-2004 at 04:15 AM. |
12-06-2004, 05:23 PM | #12 |
Member#: 33174
RMIC
dashiet - That isn't a shift knob that is the new pivot point for the shifter. You reuse the stock shifter rod and change the pivot point on the bottom of the shifter.
JasonG - You have a PM Tino - Shipping to australlia is going to cost quite a bit. I am guessing delivery of about 2 weeks. We can only accept wire transfers from out of country customers. So we would need to get that all straightened out. Give me a call or an email/om if you have any questions. Ben |
12-20-2004, 12:34 PM | #18 |
Member#: 3293
Vehicle:'20 Ascent '15 XTerra P4X |
Correct me if I'm wrong please...won't this shifter actually be taller than stock when adjusted to have a shorter throw?
To decrease throw, you will be making the shifter longer. this will be making the shifter even taller than stock. I think the stock shifter's pretty tall already - maybe I'm wrong. |
12-20-2004, 03:58 PM | #19 |
Member#: 33174
RMIC
[quote=Brahmzy]Correct me if I'm wrong please...won't this shifter actually be taller than stock when adjusted to have a shorter throw?
Read Post Below Ben Last edited by RallySport Direct; 12-22-2004 at 02:09 PM. |
12-22-2004, 01:35 PM | #20 |
Member#: 3293
Actually the closer the pivot ball is to the fulcrum point, the longer the throw is to make the pivot ball travel the same distance. So, if you want to shorten the throw, you would move the pivot ball further(read longer) from the fulcrum point, thus increases the overall length of the shifter, which in-turn will make for a taller shifter.
This is not necessarily a bad thing for some folks, as long as they're aware of it before purchasing. |
12-22-2004, 01:53 PM | #21 | |
Member#: 33174
RMIC
I don't know what the heck I was thinking that day. You are correct by making it longer you will be adjusting the throw to shorter. So with the perrin you can adjust the shifter height to be shorter but in turn you will make the shifting motion longer. If you would like the shifter to be shorter(height wise) you should go with the kartboy. He takes the length from the top and puts most of it underneath the pivot point to in turn make the shifter shorter throw and length. Thanks for clearing that up I will edit my post so people reading this thread will not be confused in the future. Ben |
12-23-2004, 12:31 PM | #22 |
Member#: 33174
RMIC
The transmission mounts will work back and forth. Meaning that you can use a 5mt mount on a 6mt and a 6mt mount on a 5 mt. Subaru has different part numbers for the upgraded mounts. So I would recommend going with the 6mt mount if you have a 6mt and a 5mt mount if you have a 5mt. The difference between the 2 is unnoticable if there is a difference.
ST410224S000 - 6mt part number ST4100055200 - 5mt part number We can get you either one. The price is the same on either. Ben |
Similar Threads | ||||
New Perrin STi 6spd Adjustable Short Shifter | JamesBernard | Car Part Reviews | 13 | 03-08-2011 10:30 AM |
Perrin STi Short Shifter | Absolut_Boost | Drivetrain | 3 | 09-21-2008 09:00 PM |
Brand New Perrin WRX Short Shifter and Bushings | Box3r4 | Drivetrain | 8 | 04-28-2008 10:51 AM |
FS: Brand new Genuine STi short throw shifter STI air filter (dealer options) | BillyC | Private 'For Sale' Classifieds | 8 | 12-16-2005 05:55 PM |
Brand new Product STi Short Shifter for the STi with Titanium shift knob | ESX Motorsports | Vendor 'For Sale' Classifieds | 4 | 01-19-2004 01:03 AM |
