10-28-2009, 02:41 PM | #1 |
Member#: 78627
Vehicle:1995 Impreza L Coupe Red |
10-28-2009, 07:19 PM | #2 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
On a 95 there is just 1 attached to the fuel pump.
Larger access panal on the passenger side. Do not take the fuel pump out if the tank is full or close to it. It will leak out all over the place. There is a drain bolt on the tank if you need it. |
10-29-2009, 02:21 PM | #3 |
Member#: 78627
Deleted
10-29-2009, 06:54 PM | #4 |
Member#: 13910
NESIC
Vehicle:2005 Legacy GT blue |
the one that has a round looking one is seems to be one that compares readings from the fuel level that is on the one with the pump.. I think it has to do with keeping the fuel level from floating all around on the gauge.
Defi fuel pressure sender location? | 06steelgraysti | Electrical & Lighting | 2 | 12-17-2006 01:57 PM |
Oil Pressure Sender Location | Ramon_12345 | General Community | 5 | 12-31-2004 11:18 AM |
oil pressure sender location on 04 STi | t00r t0g | Interior & Exterior Modification | 2 | 11-13-2004 11:49 AM |
Fuel Pressure sender location... | 8Complex | Normally Aspirated Powertrain | 10 | 05-19-2001 05:21 PM |
('93-'01) oil and temperature sender locations | ins8ibl | Impreza Forum | 3 | 05-15-2001 04:29 AM |
