06-10-2005, 11:39 AM | #1 |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
TurboXS Tuner/Tuner Pro/Tuna Owners: Ever Replace Your Bosch/VW Sensor?
I've noticed some posts in the forums here where Tuna owners have had to replace the Tuna's wideband sensor. This poll is an attempt to guage whether this is a widespread phenomenon, or merely isolated to a few unlucky owners.
If you've ever replaced your Tuna's sensor for any reason, pleases vote. Also, it'd be useful if you would also post here and describe why you got a new sensor and how many miles or how long you used the old sensor. One symptom of sensor failure seems to be that the sensor will seem to work fine until you get on the boost. Then the sensor will inexplicably start reporting higher and higher A/F ratios until it exceeds 25:1, at which point the Tuna display will show --.- and a UTEC log will show >25:1. If you experienced that symptom, you need only say "The usual problem." If you've never had to replace your Tuna's sensor, please feel free to vote, too, and to also describe in a post how long your Tuna's sensor has been working trouble-free. Oops. Thought I creating a Poll. Guess I screwed up.
06-10-2005, 12:08 PM | #2 |
Member#: 54597
Vehicle:08 'Busa, 08 ML63 10 Multistrada, 996 Targa |
I had a VW sensor in there for around 15,000 miles of hard abuse (lots of backfires in the exhaust and crap like that). When I switched downpipes, the threads on the O2 sensor bung were a little screwy and trying to re-install the O2 sensor screwed up the threads on it as well. So I bought another sensor. At the time of its death, it was still working fine.
So I don't think mine counts, but free bump FWIW, I killed the factory front O2 sensor during that time. The failure symptoms were kinda like the "usual problem" above, but a little different. After I got on boost for a while (and had high exhaust backpressure, which I believe was the cause of the failure or at least the symptoms), the sensor would read full lean until I let off the gas for 5-10 seconds. So I would cruise with my fuel trims pegged and AFRs in the 10s until I coasted down. I'm guessing cooling the sensor off helped somehow. Then it would read fine again until the next time I spooled the turbo. |
06-10-2005, 02:22 PM | #3 |
Member#: 37731
ive had my tuna for 14k miles. was working (seemingly) fine until maybe 2k miles ago. jorge suggested that i recalibrate it since he saw his was off, but it wouldnt calibrate because it couldnt get up to operating temp. soooo...i need to get a new one but just havent gotten around to it. i really havent done any major tuning in 4k miles or so, so its not a big deal right now.
06-10-2005, 03:20 PM | #4 |
Member#: 29963
Vehicle:04 sti silver |
Mine had trouble getting up to temp for the free air as well... I had to drive a little with it in the free mod and then it would recalibrate..
edit: I only have around 3k on it. Last edited by wrex03; 06-10-2005 at 04:28 PM. |
06-10-2005, 04:01 PM | #5 |
Member#: 36528
Vehicle:2002 Impreza Wrx Silver |
Mine was a little more then a year old, with maybe fifteen thousand miles on it. At first I noticed the a/f ratio at idle wasn't so close to 14.7 to 1. It was more like 16.5 or 13. Then I noticed the boost was off while on boost. I tried to do a free air test, and it wouldn't heat up. Got the error function at that point. I was kinda wonderin why it seemed to be heating up and what not b4 I tried to do the test..... Anyways, replaced the expensive bosch sensor with the less expensive vw/bosch sensor. Works fine, but I had to splice in the connector from the old sensor to the wires of the new sensor(since the more expensive one diesn't have the same connector as the less expensive one).....
06-11-2005, 08:44 AM | #6 |
Member#: 2468
South East
Vehicle:08 RS4 05 STi - Gone |
Bosch/VW, 4k, no issues to date.
06-11-2005, 10:58 AM | #7 |
Member#: 49831
NWIC
Vehicle:2008 Get Tuned Now Knowledge is Power |
We have had 6 different tuners with probably 6-8 sensors replaced. In my personal car I have 15K miles on the sensor and it works fine. Tim's car has gone through a couple sensors now, even faster than our dedicated tuning units. Since Tim typically does not run leaded fuel this was of concern to us. After looking at the location of his sensor we noticed that it does not point down at an angle greater than 10 degrees. When you cold start the car water can condense in the sensor causing the heater to fail. We believe this is the reason why he killed 2 sensors in a few thousand miles.
It is common for the sensor to report normal AFRs at idle, and then under boost go off scale lean when they fail. We usually see that in our dedicated tuning units. It is unfair to use our tuning units to determine the life span of these sensors since they get installed 4-5 times a week into a car, and commonly see cars that run in the low 10:1 AFRs. I do not believe Jeff or Mick have had to replace their sensors yet, but I do not know how many miles they have either. We all have the Bosch sensors. Basically our experience is if you install them correctly, and treat them right we have not had one fail yet. If you abuse them they die. Personally I am a little concerned with mounting the sensor to close to the turbo. They have a heater in them to get them up to the correct temperature, but they have no way to lower the temp of the probe. Putting the sensor right up against the turbo just seems like a poor choice. I like to have them 18" downstream of the turbo, cat location permitting. Jarrad |
06-13-2005, 02:08 PM | #8 |
Member#: 35136
Vehicle:2002 WRX WRB |
The usual problem. 1 year 15 thousand miles.
06-13-2005, 03:41 PM | #9 |
Member#: 21267
Vehicle:STI, EWG 8cm Green UTEC/ECUtek/WI & SD tune |
15 Months
12k miles Bosch sensor v1.5 software Sensor in TurboXS race pipe at approx 20degree angle facing downward. Live in Canada with temps from -30f to +90f NO issues |
06-13-2005, 03:50 PM | #10 |
Member#: 37731
concensus: put a WBO2 sensor in the bung behind the turbo in some downpipes (godspeed) or take out the stock narrowband O2 sensor, and plug it in there (and get a MIL eliminator or equivalent)?
06-13-2005, 04:53 PM | #11 | |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
http://www.innovatemotorsports.com/resources/lm101.php |
06-17-2005, 07:22 PM | #12 |
Member#: 15350
Vehicle:2002 WRX Sedan Midnight Black |
I'm at about 15K miles with my Bosch that comes with the LM-1. I'm replacing soon because I constantly get "sensor timing" errors that are a result of the sensor going bad I believe.
Just to note, my sensor is installed 6" or so behind the turbo, so it is subject to lots of heat. My brother works at VW and can get the sensor for ~$42, so I'm going to try the VW bosch next. -jason |
06-19-2005, 01:36 PM | #13 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
.....is there a list of cars that have this sensor, stock......I'd like to jack one(several) out of a boneyard next time I go....
06-19-2005, 01:56 PM | #14 |
Member#: 6124
Vehicle:2000 NFR AP1 S2000 '07 Honda FIT sport (5MT) |
Caddy Catera I believe still uses the Bosch, as for the V-dub one, I have it at work. I'll see if I remember to post about it, and if so I'll update the list for you.
Jorge (RiftsWRX) www.ProjectWRX.com |
06-19-2005, 02:52 PM | #15 |
Member#: 52043
Vehicle:04 sti |
mine hasn't worked from day one. it will only read 14.7-14.5 or "ERR".
i was told by turboxs that the sensor was bad, and i ordered a vw harness and wb. i hope it works this time. |
06-19-2005, 04:56 PM | #16 | |
Member#: 2992
NESIC
http://www.wbo2.com/lsu/default.htm I'm not sure why you'd want to buy a used wideband sensor when you can buy a new one for $38.29 plus S&H from here. BTW, here's Bosch's USA site to look up Bosch USA partnumbers for a particular year/make/model/engine: http://www.boschusa.com/AutoParts/Pa...PartFinder.asp |
06-19-2005, 06:07 PM | #17 | |
Member#: 16200
...Jon....I did say 'jack' one.....who said ANYTHING about buying one??? I just needed to know which one to 'jack'. ...thanks for saving me $40 |
06-19-2005, 07:04 PM | #18 |
Member#: 60324
Vehicle:1998 RS |
I've had mine pro tuna (Bosch i believe) in for just shy of 20K miles. It's plugged into the stock location on a helix DP (far back). It's in full time, readings are on point.
06-19-2005, 08:26 PM | #19 | |
Member#: 2992
NESIC
06-20-2005, 08:16 AM | #20 | |
Member#: 54597
06-20-2005, 09:19 AM | #21 |
Member#: 52043
Vehicle:04 sti |
UTEC or TUNER firmware? i just recieved a new UTEC because of some coilpack issues...so that should be ready to go.
06-20-2005, 11:03 AM | #22 |
Member#: 54597
Tuner firmware.
06-23-2005, 08:29 AM | #23 |
Member#: 52043
Vehicle:04 sti |
ok. so i replaced my bosch type, with a vw harness and sensor. still isn't working. is my tuner bad? it reads either 14.7-14.8 or Err. this is so friggin frustrating. how do you get a firmware reflash for the tuner? the turbo xs website?
06-23-2005, 11:21 AM | #24 | |
Member#: 54597
It's on the TXS web site. Just flip the dip switch (I think it's switch 4? Check the manual), then run turn the car (and tuner) on, then run the flash program on your laptop. TWhen finished, turn the car off, flip the switch back down, and restart the car. Should be fine. Don't forget to perform a calibration also. |
06-23-2005, 01:17 PM | #25 | |
Member#: 60324
Vehicle:1998 RS |
Utec, Tuner Pro and NEW Bosch wideband sensor | antonio_sti | Engine/Power/Exhaust | 0 | 09-09-2009 12:53 PM |
Need replacement Tuner Pro Bosch WBO2 sensor.. suggestions? | AaronWRX | UTEC | 23 | 07-28-2008 07:10 PM |
TurboXS UTEC and TurboXS WB02 Tuner- Bosch sensor | Peeblesmx445 | Engine/Power/Exhaust | 2 | 11-19-2007 11:39 PM |
FS: TurboXS Tuner w/ VW sensor | memo3 | Private 'For Sale' Classifieds | 8 | 07-20-2006 10:21 PM |
turbo xs tuna tuner w/vw sensor barely used. | kenlee | Private 'For Sale' Classifieds | 1 | 06-20-2005 10:40 PM |
