05-23-2001, 04:52 AM | #1 |
Member#: 711
Vehicle:1993 Rx7 R1 Yellow |
MY99 How Hard to convert to rear wheel drive????
Ive heard how people have done it for the dynos and stuff, im kinda what to do it to play around for while. What does it consist of? Also i have a hydrolic lift and garage to use so thats not a problem.
05-23-2001, 05:41 AM | #2 |
Member#: 2462
SCIC
Vehicle:2012 Audi A4 Avant S-Line Titanium |
Just remove your front drivshafts!
Jon |
05-23-2001, 08:10 AM | #3 |
Member#: 3726
Vehicle:2001 2.5RS Blue Ridge Pearl |
Just remove your drive shafts???? Dude, do that and all your trans fluid wil come flinging out as soon as you drive. Bad idea.
05-23-2001, 08:18 AM | #4 |
Member#: 2072
He forgot to mention...
Stuff rags in the holes! |
05-23-2001, 08:45 AM | #5 |
Member#: 2462
SCIC
There ya go! Improvise!
05-23-2001, 10:01 AM | #6 |
Member#: 1367
Vehicle:2000 Impreza 2.5RS Blue Ridge Pearl |
Oh man, not someone else who wants a rear-wheel drive Subaru! We just talked about this a few weeks ago (camaroman's post). Buy a RUSTANG!!!
Seriously though, why would you want to take a car that was purpose-built for AWD and make it RWD?? The whole idea of buying a Subaru is the AWD. If you have an automatic, there is a fuse you can pull to put it into front wheel drive, but PLEASE don't deface your poor scooby and make it into a RWD car. A concerned AWDriver, Dan |
05-23-2001, 10:24 AM | #7 |
Member#: 711
What i love my AWD drive. Also i have a manual transmission so no fuse for me. I just what to play around and have something diffent to do, plus i dont have any money to buy new parts so i figure i have to work on my car somehow...
05-23-2001, 10:50 AM | #8 | |
Member#: 821
Greg |
05-23-2001, 11:39 AM | #9 |
Member#: 1501
NESIC
Vehicle:2009 WRX wagon Dark grey |
Here you go:
http://www.i-club.com/ubb-files/Foru...ML/003834.html If it's just to play around, you might want to think twice. |
05-23-2001, 03:22 PM | #10 |
Member#: 1346
Couldn't you do something to screw with the center differential? Isn't that what controls the AWD system/transfer?
05-23-2001, 06:45 PM | #11 |
Member#: 2359
NESIC
Vehicle:2001 Impreza 2.0 WRS |
Probbly, they do that on many of the WRX's, but I don't know if you can get them to be 100/0 I thought it was only like 60/40 or something along that lines.
*shrug* Korey |
05-23-2001, 06:55 PM | #12 |
Member#: 2646
I'm not sure what the answer is but, about the center diff...
A differential can split power 0/100 or 100/0. The power tries to take the path of least resistance, which means if you were to disconnect the front driveshafts or something similar all the power would want to go to the front. (One wheel spins and the other does nothing, right?) The viscous limited slip would limit it but would it would be fried in no time. What you need is someway to LOCK the differential to force a 50/50, and then disconnect the front somehow. The viscous only works if there is a speed difference front to back and locking the diff will prevent that. It's possible I suppose, and I think that's how some did it, but I don't think it's easy. Dave [This message has been edited by NebScoob (edited May 23, 2001).] |
05-24-2001, 04:28 AM | #13 |
Member#: 3873
Vehicle:. Paradise is like Disney with hookers |
There should be a way to modify the center diff. from an automatic to go RWD when power is cut instead of FWD... then it should be possible to replace your center diff with said modified automatic lsd. I stress the SHOULD because I have never tried it and don't know enough about the particulars involved.
Converting Impreza to Rear Wheel Drive | OhtaGerbilHero | Subaru Conversions | 74 | 06-04-2011 12:40 AM |
AWD converted to Rear Wheel Drive? | Zdawg_42 | Transmission (AT/MT) & Driveline | 0 | 04-06-2009 12:01 AM |
Ford to bring back rear-wheel-drive in the U.S. | AVANTI R5 | Non-Subaru News & Rumors | 10 | 03-24-2008 10:08 PM |
converting 2 rear wheel drive? | 06t-wrex | Newbies & FAQs | 6 | 10-05-2006 12:09 AM |
How to switch Auto to rear wheel drive? | ImprezedRS | Normally Aspirated with bolt-on Forced Induction Powertrain | 1 | 09-23-2001 09:55 PM |
