Welcome to the North American Subaru Impreza Owners Club Monday April 22, 2024
Old 09-25-2011, 03:49 PM   #76
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
you'd have to drill a hole into the trunk for the hinge
blakkboxer is offline   Reply With Quote
Old 09-26-2011, 02:58 AM   #77
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
I've been playing with this a little. Hopefully I'll be able to figure this out. My trunk tension rods weren't swapped after my third trunk swap. I got lazy. I had the STi rods in there on a wingless trunk and so eventually my mounts for the rods snapped off. Now I have to hold up my trunk by hand.
arco is offline   Reply With Quote
Old 10-11-2011, 10:50 AM   #78
mrchyes
Member#: 294069
98 Forester
Green
gas things dont operate on hinges...just gotta connect them and line it up correctly...
mrchyes is offline   Reply With Quote
Old 12-22-2011, 09:30 PM   #79
lowishsti
Member#: 273735
2007 STI
So i took my carbon trunk off and put my sti trunk back on, damn this thread came in handy. I had no idea how those things went back on. Props for this thread.
lowishsti is offline   Reply With Quote
Old 06-02-2012, 09:47 PM   #80
jtw9303
Member#: 245806
2004 WRB STI
2010 WRB STI
Old thread, New bump! Reading this thread and learning the mechanics made swapping the tension rods a breeze! Thank you for posting such a well communicated, step by step process!!!
jtw9303 is offline   Reply With Quote
Old 06-06-2012, 03:12 AM   #81
JPX
Member#: 44504
1996 Legacy L Sedan
It's good to see a fresh write up on this topic. My 96 Legacy sedan had a broken torsion spring. And that made the lid quite heavy for the family to use.
I had picked up the stronger GT lid torsion springs at the junkyard. And spent some time wrestling them into the car. It worked great - kind of nice the stronger springs opened the trunk lid fully when unlatched instead of simply unlatching and opening slightly.
Unfortunately the junkyard spring broken a couple of months later. I bought new ones on-line and the installation went a lot better.
So good on you for the detailed photos and explanation - best online I've seen so far!
JPX is offline   Reply With Quote
Old 08-16-2012, 10:28 PM   #82
AdnoFal
Member#: 280307
Beauty writeup!
I've got to do this this weekend.
AdnoFal is offline   Reply With Quote
Old 02-25-2013, 10:22 PM   #83
wrx720
Member#: 253514
2002 VF30 WRX
psm
Cool
Hey guys! is there any physical appearance between the three torsion rods?
I've have seen few different colors on the web. mines black on psm wrx. the reason why I asked cause I upgrade to sti wing and never realized I have to changed the torsion rods. the trunk still pop open but have to open like lifting weights.
wrx720 is offline   Reply With Quote
Old 06-16-2015, 04:39 PM   #84
boost-o-matic
Member#: 248364
2010 Huevos grandes
WRX Dom 1.5XTR E85 silver
Hmmm, wonder if any schmuck like me has removed the torsion rods strictly for the weight savings? Wonder how much they weigh. 2-4 lbs is my guess.
boost-o-matic is offline   Reply With Quote
Old 06-16-2015, 07:11 PM   #85
Awd.Son
Member#: 280078
2006 STI
Aspen Hwite
Any one think this is my problem, I would like to know before I remove them.
http://forums.nasioc.com/forums/show....php?t=2729824
Awd.Son is offline   Reply With Quote
Old 07-25-2015, 03:14 PM   #86
skeeter281
Member#: 403893
2015 STi Limited
WR Blue
Default Thanks!!!
+1 to OP for the post. Used it today for my '15 trunk swap. Getting tension bars out was easy, getting them in was quite a bit harder. Thanks again for the help with the write up.
skeeter281 is offline   Reply With Quote
Old 10-13-2015, 03:05 PM   #87
MRSTI28
Member#: 163534
2005 STI
CGM
THANK YOU FOR THIS WRITE UP!!! will be swapping the passenger side hinge out since the bracket holding the tension bar broke yesterday night!
MRSTI28 is offline   Reply With Quote
Old 07-28-2021, 06:52 PM   #88
RAV
Member#: 502113
Thank you
RAV is offline   Reply With Quote
Old 07-28-2021, 06:53 PM   #89
RAV
Member#: 502113
Great write up
Old 02-19-2024, 06:02 PM   #90
Guatiao
Member#: 104264
Chapter/Region: PRSIC
2005 Impreza RS
2024 bump, this post is priceless!
Guatiao is offline   Reply With Quote
How to plug your trunk holes glehn1 Interior & Exterior Modification 31 03-05-2017 10:53 PM
wtt: wrx trunk tension rods for sti trunk tension rods jlam86 VIC Private Classifieds 12 01-04-2007 03:06 AM
How to replace your axle HighRevimpreza Brakes, Steering & Suspension 16 03-13-2006 10:16 PM
Trunk tension rod choice RallyFord Interior & Exterior Modification 3 07-13-2005 02:07 PM
i'm such a nerd, or how to entertain your trunk monkey! catass Off-Topic 3 07-21-2004 11:07 AM
