01-18-2012, 10:28 PM | #1 |
Member#: 293263
MAIC
Vehicle:2002 subaru wrx black |
v7 sti tunning
im coming across a problem when trying to find a tuning solution for my jdm v7 sti ecu, im thinking possibly use a utec but leave the avcs directly pluged into the ecu? any thoughts or other options? its an 02 wrx with a v7 sti swap, blouch16g, and a built trans
01-19-2012, 10:41 AM | #2 |
Member#: 211035
Tri-State
Vehicle:2002 Bugeye Black |
why not open source...?
01-19-2012, 12:20 PM | #3 |
Member#: 293263
MAIC
Im open to anything really, im unfamiliar with open source though
01-20-2012, 06:07 PM | #4 |
Member#: 4986
NESIC
Vehicle:2002 BlzYel JDMSTiv7 GRP 08 FXT |
No problem tuning.
Definitely Open Source. -RomRaider -ECUFlash All downloadable You'll need a laptop, a few cables to data log and flash your ECU and a Wideband O2 will be needed to truly tune it. I don't know if the UTEC would even work. |
01-20-2012, 06:40 PM | #5 |
Member#: 125572
NESIC
Vehicle:2003 03 Baja 05 Baja 2005 Leggy 2007 2.5i wgn |
Forgot to sign out...
01-20-2012, 06:42 PM | #6 |
Member#: 148549
NESIC
Vehicle:95 RHD GC V7 STi 04 WRX, Sold the BlackSTi |
^^^ That was me, signed into my account....
+1 for open source. I'm running an open source tune on my 95 coupe with a full jdm Ver7 sti swap (rhd, ej207, drivetrain, etc.). I love it! |
01-21-2012, 10:47 AM | #7 |
Member#: 293263
MAIC
Can open source control any extras like meth injection?
01-21-2012, 12:38 PM | #8 |
Member#: 241812
South East
Vehicle:2002 Ej207 Sedan 30r Aspen White |
+2 for open source. I have a v7 motor and i've had it tuned several times via open source. I'm even running the smc methanol kit atm, which was also tuned with open source. It's fairly straight forward and in my opinion one of the cheapest routes if you can get a wideband. Id recommend an AEM Wideband since it's so easy to install and romraider friendly. I used an Innovate LC1 for a while, and even though it worked great, it seemed like it required a little more work to install and also needed to be re calibrated fairly often to read an accurate number.
01-31-2013, 12:35 AM | #9 |
Member#: 249130
NWIC
Vehicle:1999 Ver5 STi RA Aspen White |
How's that swap treating you? when you did the swap, was it difficult to convert to RHD? Did u just drill through the firewall? I'm doing a complete ver6 swap into a 95L and am thinking about just leaving it RHD. I'd like to do a ver7 swap, but I'm buying the whole car through auction, so unless I find a gc8 with a swap in it already, that's what I'm getting! Atleast its still a ej207, wouldn't mind the avcs heads tho!
01-31-2013, 09:16 AM | #10 |
Member#: 6886
Tri-State
Vehicle:MY01 EJ207 HTA35r AVCS ON! |
you can tune straight opensource or
use a Utec rev 6b, it has the pass through for the avcs wires and you would be able to utilze speed density and the ability of changing maps on the fly. If you plan to stick with one fuel, I'd go opensource just for simplicity. |
02-15-2013, 12:48 AM | #11 | |
Member#: 184543
NESIC
Vehicle:JDM RHD GM8 Type R 02 6 Speed Bugeye |
+1 utec can also run a solenoid such as water/meth injection. Ignition cut launch control standard... bang bang! Alot of high horsepower cars running it. Not too much info now that turbo xs stopped selling it but the price is rediculous right now if you want one. Was over 900 and can be had now for less than 200 |
Similar Threads | ||||
FS : (OH): 02-03 JDM V7 STi taillights | coolblue05 | Exterior/Styling | 15 | 03-25-2012 04:48 AM |
CA:BIG PORT JDM V7 sti heads,v7 internals,05sti 5zigen fno1rc,sti knuckles,arc,perrin | petawabit | Private 'For Sale' Classifieds | 53 | 04-19-2006 05:09 PM |
Container Landed! V7 STI, V7 STi and Spec C | Kingpin | Engine/Power/Exhaust | 157 | 05-21-2005 10:05 AM |
Container Landed! V7 STI, V7 STi and Spec C | Kingpin | Drivetrain | 69 | 05-09-2005 07:57 AM |
Container Landed! V7 STI, V7 STi and Spec C | Kingpin | Wheels/Tires | 49 | 05-06-2005 07:57 PM |
