Welcome to the North American Subaru Impreza Owners Club Thursday October 18, 2018
Old 11-05-2004, 10:48 AM   #1
orthikon
Member#: 43395
04 WRX mods:
Still fixing the driver
Default whiteline 22mm FSB compatibility
I would like to know if the 22mm whiteline FSB that is for an 02 WRX is compatible with an 04 WRX, both are sedans BTW.
Since I'm buying this one used, should the FSB come with any hardware?
Thanks!
orthikon is offline   Reply With Quote
Old 11-05-2004, 11:06 AM   #2
Scooby Freak
Member#: 40751
'94 SER
It should come with bushings, but the brackets will be re-used. Just check the part number on the FSB. It should be BSF33 or BSF33Z for the adjustable one. If it's painted silver then it is their newer design. If it's painted blue, then it may not have the stops that prevent it from sliding sideways, but it should still work fine.
btw, any fsb for the 02 will fit the 04.
Scooby Freak is offline   Reply With Quote
Old 11-05-2004, 12:45 PM   #3
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Scooby Freak has it all right.
DrBiggly is offline   Reply With Quote
Whiteline 22mm FSB Now What RSB and set-up??? prokaw875 Brakes, Steering & Suspension 4 11-02-2009 10:04 PM
FS: VA: Whiteline 22mm FSB - Wagon Rippen Griffen Suspension/Brakes/Handling 3 03-30-2009 09:42 AM
FS- whiteline 22mm FSB bushings RS drifter Suspension/Brakes/Handling 9 02-06-2009 04:14 PM
FS: Whiteline 22mm FSB & Rocket Rally Short Shifter semaj NWIC Private Classifieds 2 10-01-2007 01:46 PM
